Old 02-16-2025, 09:35 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Anyone attach side molding with silicone glue?
I was not happy with how the sticky pads on the plastic clips made the trim stick out and left gaps so I tried silicone glue on the plastic tabs on a couple of pieces and stuck it on and used tape and wedges to hold it on until it dried. It is really tight to the body and seems solid but I am wondering if it will hold up to flex and vibrations.
The only other way I see to get it tight to the body especially with with the upper trim is to use the push in clips and drill holes for them.
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-17-2025, 12:19 AM   #2
xs-cash
Re: Anyone attach side molding with silicone glue?
I actually did the same thing on my 71, just a small dab, but it’s not a show truck by any means , I found the plastic tabs didn’t keep the trim tight to the body
xs-cash is offline   Reply With Quote
Old 02-17-2025, 02:09 AM   #3
jhe.1973
jhe.1973's Avatar
It wasn't on any of these trucks but on a Dodge Caravan.
One of the moldings blew off and the only one I found in a junkyard (OEM was priced outrageously) had a non-OEM double sided tape. It was a bear to get off.
To install it I used double sided Gorilla tape and its been on just fine for years.
Best wishes to ya’ll. Sincerely, Jim
"To invent you need a good imagination and a pile of junk" - Thomas Edison
"I've always wanted to get a job as a procrastinator - but, I keep putting off looking for one - I guess I'll never realize my life's dream - so sad." - Me
My C30 wrecker build/repair/update thread: https://67-72chevytrucks.com/vboard/...d.php?t=855904
jhe.1973 is offline   Reply With Quote
Old 02-17-2025, 02:49 AM   #4
Richard
The double stick tape that comes on the aftermarket clips is to thick. Get some thinner tape from 3M, remove and replace it. 3M has some very thin tape designed for emblems and such. Use all the time at the body shop.
Very simple solution. When installing my molding I will not be using the stick on clips as received.
Richard
Old 02-17-2025, 03:19 AM   #5
58 Special
Active Member
Silicon is not good to attach anything to the body of an automobile as it attracts moisture. Causing rust to form around silicon.
Ask any body man if they use silicon. None of them will.
58 Special is online now   Reply With Quote
Old 02-17-2025, 11:44 AM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ Plus, it's a real bear to make sure it's all gone when it's time to repaint. Talk about fisheye! Maybe products have been developed to avoid it, I haven't painted a vehicle in 12 or so years.
~Steven
Simi Valley, CA
Old 02-17-2025, 01:28 PM   #7
chewychevy67
I bought a car 10 years ago and the windshield was cracked. I brought it in for a new one and they removed it and basically after that the car was shot. Previous owner used silicone to put the windshield in and the pillars were rotten and unstructured. Would need complete replacement. It went to the crusher. Don't use silicone
chewychevy67 is offline   Reply With Quote
Old 02-17-2025, 05:22 PM   #8
truckster
truckster's Avatar
When I was doing auto glass, I hated dealing with the silicone people would sometimes use to try to stop leaks. It does attract water and it's eventually going to vibrate loose, leaving a surface that's hard to get anything to stick to.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 02-17-2025, 05:50 PM   #9
IT Cowboy
Active Member
IT Cowboy's Avatar
Is there a glue that would work then but still be flexible
'72 C10 / 402
Old 02-17-2025, 11:08 PM   #10
truckster
truckster's Avatar
3M Black Weatherstrip Adhesive works well.
Old 02-18-2025, 11:16 AM   #11
Jason Banks
Jason Banks's Avatar
Don't do it, properly clean and use the thinner VHB tape or like you said the clips and drill the holes.
With that said. This would work - https://www.amazon.com/U-Pol-Product.../dp/B002SQY852
Jason Banks is offline   Reply With Quote
Old 02-18-2025, 12:27 PM   #12
dagnabbitt
dagnabbitt's Avatar
If you've ever had to remove silicone, you'd find excuses and not reasons to use it.
I was pleasantly surprised by 3m tape. I didn't think it would hold up but it definitely has.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old Yesterday, 10:45 PM   #13
Rick Bollinger
I found this video very interesting. When I am ready I was considering doing it this way.
https://www.youtube.com/watch?v=TcGBoTphXfc
Rick Bollinger is offline   Reply With Quote
Old Today, 03:20 AM   #14
Richard
Brilliant idea. Thank you for posting! Though personally I think there is no need for "primer" or to fully cover the back of wider moldings. Jmho, the 3M tape works well with a clean surface.
Richard
