Old 02-14-2025, 04:37 PM   #301
Chaparralman1974
Chaparralman1974's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
Looking great Scott! You are making a ton of progress. Are you going to run the wire bundle up on top the firewall like the factory? I am thinking about doing that, but I don't like how the ignition wire comes down the center of the firewall to get to the distributor if that makes sense.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 02-14-2025, 05:37 PM   #302
loudchevy
loudchevy's Avatar
Clay
The picture of the engine bay in my last post has everything for the engine wired in it. I sealed up the channel on the top of the firewall so there was no place to route wires in. In this pic you can see where I ran my wire loom for the coil, tach, and electric choke behind the engine/top of the transmission to right under the distributor. Then in another loom I ran the oil pressure and water temp sender wires to those sensors and routed it adjacent to the frame rails. The black split sleeve loom helped blend all the wires into the black frame and wheel wells.
I went a little crazy on zip ties, but they make everything look clean and organized. I still want to wrap the wires showing coming out of the fuse block a little better at some point as well.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 02-15-2025, 09:46 AM   #303
Chaparralman1974
That looks clean Scott! I may try that rather than go over the top of the firewall. What did you use to seal up the edges of the fuseblock? Is that seam sealer?
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 02-15-2025, 10:07 AM   #304
raggedjim
raggedjim's Avatar
Nice work on the wiring in the engine bay. It looks really clean.
raggedjim is offline   Reply With Quote
Old 02-17-2025, 09:50 AM   #305
loudchevy
loudchevy's Avatar
Clay
This is what I used around the fuse block. I have plenty left if you want a couple of strands.
https://www.eastwood.com/ew-flexible...-bk-2-lbs.html
Thank you! I'm pretty happy with how it turned out.
Scott
2003 Tahoe Stock
Old 02-17-2025, 09:58 AM   #306
KevinK7
KevinK7's Avatar
Indeed, that firewall/engine bay looks VERY clean
Looks like Eastwood is relabelling "3M Strip Caulk", ...great stuff for sure
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 02-17-2025, 10:07 AM   #307
loudchevy
loudchevy's Avatar
Just a few things got wrapped up this weekend. I dropped the starter and got the power and solenoid wired, finished routing the rear light wires to the back cross member, and I finally got the parking brake installed.
I had to modify the cable on the parking brake a little bit as I tucked the exhaust up and that interfered with the stock routing. I ended up making a new passenger side bracket from some 1" flat stock and welded a threaded rod on the end to replace the long rod that way hitting the exhaust. Or course I couldn't find the clamp that holds cable to the parking brake assembly, so I had to order a new one. I'm sure I'll find mine after it gets here. I had found the bolt for it, but the clamp wasn't with it. I'm sure I put it somewhere safe I get a picture one night this week.
Hopefully some lighting parts will show up this week so I can get the grille bolted on the front and see some bright lights and blinking
Scott
2003 Tahoe Stock
Old 02-17-2025, 10:10 AM   #308
loudchevy
loudchevy's Avatar
Thanks! Ya it's pretty much the same as the 3M stuff.
Scott
2003 Tahoe Stock
Old 02-17-2025, 12:00 PM   #309
pjmoreland
pjmoreland's Avatar
Great progress. Hooking up the battery will be a big milestone, and it looks like you're getting close.
pjmoreland is offline   Reply With Quote
