#151 |
![]() Join Date: Aug 2017
Re: Penny
Looking good.
#152 | |
![]() ![]() ![]() Join Date: Jan 2018
Re: Penny
![]() Thanks!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#153 |
Re: Penny
Made some great progress over the past couple of weeks. C-notch is installed on both sides. Also helped dad begin building a ramp for the storage building. Once that’s done, all the lawn and garden stuff will go out there and Penny will be able to go into the garage.
Merry Christmas!
#154 |
Re: Penny
We did end up getting that ramp finished up, so that means Penny finally made it inside the garage. Man, I am glad we were able to make that happen. I have made some great progress this past week. Booster in place, master mocked up, brake lines ran but not completely tightened up yet, and new shoes, hardware, and wheel cylinders installed.
Yesterday I pulled the passenger door panel off and popped the dent out from the inside. There’s still some evidence of the dent but it’s wayyy less! I also pulled the heater box out today after work and discovered a large crack in the heater core. It’s really nice being able to make progress even though it’s dark and cold outside. More progress coming soon!
#155 |
![]() Join Date: Dec 2018
Re: Penny
Great progress, it's definitely nice to be able to work on the truck in from the weather.
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
#156 |
Re: Penny
Make me happy to see a frame cleaned up like that. Very nice
#157 | |
Re: Penny
Thanks! It’s just a rattle can rebuild, but that certainly helps with preserving what’s there.
#158 |
Re: Penny
Got some more work done over the past week. Continued work on the heater core, but ran into a snag. It appears the blend door actuator is bad and I broke the bled door actuator plastic piece. Found someone else on the forum had already made one out of sheet metal, so I ended up doing the same thing. Worked out well!
I spent the afternoon today cleaning up the 350, so should be able to paint it tomorrow with the false spring we have this weekend. Gonna take advantage of that while I can!
#159 |
Re: Penny
Took advantage of an absolutely fantastic February day to paint the engine and bellhousing. I decided to repaint with the original color: GM Corporate Blue
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 02-03-2025 at 08:10 AM. |
#160 |
Re: Penny
Engine sure turned out nice, great job.
#161 |
Re: Penny
Nice!
#162 |
Re: Penny
Thanks fellas!
#163 |
Re: Penny
During a couple evenings last week, dad and I worked on getting the engine and transmission back in the truck. New clutch, new flywheel, all bolted together, and swung into place. Looks right at home there!
Also discovered that I should’ve tried to track down a correct bellhousing instead of using one from a 60s truck. I didn’t think to check where the clutch z-bar landed on the drivetrain side and just assumed it was the block. Whoops. So next step will be making a bracket that’ll mount off the two spots in the block and stick past the rear so that the z-bar can fit in the correct spot
