Old 06-26-2022, 09:05 PM   #826
forestb
forestb's Avatar
Re: How about some pics of Static dropped 60-66
I have gone as low as 5.5 inches in the rear without it bottoming out on the rear axle. 4 in drop coils and 1.5 in blocks. It did not bottom out until I did a 6 in drop.
forestb is offline   Reply With Quote
Old 06-30-2022, 09:50 AM   #827
MT65
Stock spindles, on 86 front xmember and coilovers on all 4 corners
MT65 is offline   Reply With Quote
Old 06-30-2022, 07:10 PM   #828
EricS76
EricS76's Avatar
1966 longbed fleetside. 4” front (2” spring, 2” spindle). 7” rear (5” spring, 2” block). 235/75R15 tires.
‘66 Chevy C-10, long bed fleetside, 350, 3 on the tree, 4-7 drop.
'77 chevy C-10 Custom Deluxe, 350, SM465 4 speed, flatbed.
'80 jeep CJ-5.
‘14 Chevy 1500 Z71…
EricS76 is offline   Reply With Quote
Old 07-01-2022, 09:48 AM   #829
lgh1157
Re: 4x4 to panty dropper
Originally Posted by islander671 View Post
Just kidding, but seriously though lowered it finally. 2 inch blocks to come. A before and after shot
Love this truck
Do you have to notch the rear frame ?
Thx
lgh1157 is offline   Reply With Quote
Old 07-07-2022, 05:45 PM   #830
PowerdbyChevy79
PowerdbyChevy79's Avatar
Heres my 66...
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 07-08-2022, 05:12 PM   #831
theastronaut
theastronaut's Avatar
Front- CPP drop spindles, one coil cut off the stock springs, bump stop bracket completely removed from the LCA, KYB Gas-A-Just shocks, stock 15x5.5" wheels, 1.5' bolt on wheel spacers, 215/75 tires. No rubbing over bumps or when turning full lock.
Rear- D2600 bags bolted directly to the trailing arms, top has short cups to make room for the air fitting. 1.5" drop blocks to keep the bags from being as compressed at ride height. Bump stop shortened but it only has about 1.5" of travel at this height so I need to do a 2" pipe notch. Shocks relocated via the Frizzle Fry method. 8" wheels, 235/75 tires.
theastronaut is online now   Reply With Quote
Old 07-09-2022, 04:36 PM   #832
Angrywood
Just finished my 3 in drop
Angrywood is offline   Reply With Quote
Old 07-09-2022, 04:58 PM   #833
lgh1157
Re: How about some pics of Static Dropped C-10's
Picked this up 2 weeks ago
Went to town on it
2.5 CPP Drop Spindles
3-5 Coils
15" Wheel Vintiques with 205/75 Cokers
Gonna add a 2" block and add a bolt on notch on the rear to get it a bit more level
( i thought i already posted on this thread, but couldn't see it on here )
Old 01-03-2023, 01:31 AM   #834
PowerdbyChevy79
Love it... love the color
1966 C10 "Mary"
Old 01-03-2023, 01:40 PM   #835
Arne
Arne's Avatar
'64 Short Step conversion (born as long Fleet), shortened and lowered by prior owner. I was told 3" both F and R all with POL springs. Wheels are 15x8 with 275/60R15.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 01-03-2023, 02:34 PM   #836
pdxhall
pdxhall's Avatar
Here's mine. 2 1/2" drop spindles and 1" drop coi;s in front and 5" drop springs in the rear with 17" rims.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-14-2024, 08:08 PM   #837
TGRAY
My 62 Shorty with 3/4 drop. 3" on torsion bars and 4" drop springs on rear.
TGRAY is offline   Reply With Quote
Old 02-02-2025, 04:24 PM   #838
6stringer
My 63. 4" drop rear springs, 2.5" drop spindles with 1" drop springs front 295/50/15 rear 235/60/15 front
6stringer is offline   Reply With Quote
Old 02-07-2025, 06:06 AM   #839
PowerdbyChevy79
Looks good..
1966 C10 "Mary"
Old 02-08-2025, 04:29 PM   #840
6stringer
Originally Posted by PowerdbyChevy79 View Post
Looks good..
Thank you! Its been alot of fun building. And a blast to drive.
Old 02-17-2025, 11:59 AM   #841
Slammed96
2.5" drop spindles and 3" coils. Rear is flipped and the 3 overload leafs were removed. If I had to guess maybe 7-8" rear drop.
14 Silverado- 4/6 drop daily
66 GMC short wide Custom Cab- building to be low and cruise. 4.8/t56 swap occurring now. Stupid low static drop
66 GMC 1 ton stepside looooong bed- the tow pig/work truck.
Slammed96 is offline   Reply With Quote
Old 02-18-2025, 11:00 AM   #842
MikeN
MikeN's Avatar
2" drop spindles front, 2" lowering blocks rear
MikeN is offline   Reply With Quote
