Old 02-18-2025, 02:22 PM   #1
MikeB
MikeB's Avatar
Door threshold hold down screws
I'm sure most of you have had the problem where the hold down screws hog out the holes in the floor and no longer grip the sheet metal screws. So you end up using larger screws, but eventually they no longer grip the holes.
I'm considering drilling out the holes and installing rivet nuts for 10-24 machine screws. Have any of you done this? Any cons you can think of?
OK, after doing some research, my best bet looks like 10-24 machine screws with speed nuts like these:
https://www.homedepot.com/p/Everbilt...0118/204274180
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-18-2025, 04:31 PM   #2
dagnabbitt
dagnabbitt's Avatar
Re: Door threshold hold down screws
I always thought sheet metal screws (non stainless ones, too) for that was an odd choice. I think rivnuts would be a great idea.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-18-2025, 05:09 PM   #3
LS short box
Couple thoughts.
First weld up the existing holes just a bit so the stock screws can get a bite.
Or take a strip of 18? gauge sheet metal and tack weld it to the jam and drill new holes?
Old 02-18-2025, 05:35 PM   #4
pjmoreland
pjmoreland's Avatar
I've had success repairing the holes by holding a heavy chunk of steel against the bottom surface of the floor followed by striking the hole from the top with a hammer a few times. This will flatten the metal out, and it will collapse the hole inward.
pjmoreland is offline   Reply With Quote
Old 02-18-2025, 05:41 PM   #5
chewychevy67
So instead of using the original sheet metal type screws for my sill plates I decided to use t nuts like this. They sit in the hole you drilled and give you extra thread for a real threaded bolt. Nut gets welded/glued on the flange to the body underneath and it will tighten better without stripping and it will still look like a truss head from the top. I used shorter bolts than what was in these photos and they are phillips head for a factory look.
chewychevy67 is offline   Reply With Quote
Old 02-18-2025, 06:33 PM   #6
MikeB
MikeB's Avatar
Thanks for the advice! I ended up ordering some #10-24 stainless truss head screws, serrated nuts, and washers from Bolt Depot. Can't believe how much I was overthinking things!
If you guys have never used Bolt Depot, I strongly recommended them. They have all grades of nuts and bolts at very low prices, with dimensions and drawings on each one of them! You can buy small quantities and they don't gouge you on shipping. Every stock number comes in its own labeled zip-lock bag. https://boltdepot.com/Catalog
Mike
Old 02-19-2025, 06:36 PM   #7
Getter-Done
Getter-Done's Avatar
Great idea.
I like those type of tee-nuts.
The early bird gets the worm,
85 Chevy K-20
Old 02-19-2025, 06:40 PM   #8
Getter-Done
I have used Bolt Depot.
I really like their selection and prices.
85 Chevy K-20
