Old 08-19-2024, 09:40 AM   #826
6DoF
6DoF's Avatar
Re: Project: Tow-Rat (Lil' Blue)
one more check mark on the list! one more item added
got the "feet" cut off the job box to make it shorter and got that screwed down into the bed. my front bed lip was just a TAD thick and had the box overlapping the bed door by like 1/4". small trim and good to go. the new list item though is cutting the box down more by sectioning out like 3-4". it doesn't impair my vision out the back, but it's just a bit big/intrusive cosmetically i feel like. that's a figure Matt problem.
a now Matt problem will most likely be a lot of banging and clatter from the box.
front end is jacked up so i change the lower shock bolts. one has rubbed a really bad groove in the pass front tire, it's not nice. i need to get some button head bolts to replace the hex and swap this tire with one of the inner duals.
6DoF is offline   Reply With Quote
Old 09-30-2024, 07:43 AM   #827
6DoF
6DoF's Avatar
racking up the miles now, the wife wants to take it any chance we can. the fuel filler is working great, except i have to drop the pass side of the truck like 2". the crossover tube is too flat and will back up the foam into the nozzle where it clicks off. then the motor so obviously wants more fuel and trying really hard to not just let it eat, i'm not ready to build the top end yet.
finally stopped working on the new shop long enough to do a few things this weekend.
air bags, small changes made a huge difference. the front i had not matched the bag max compression to the truck's full bump, i was able to add a 1" spacer under the bag and still get full drop. that's probably 2.5" out at the wheel. so now full height is 125psi, not the 160 i had been running. not only does it fill WAY faster, on the first tank even, but softening things up made it all work so much better. even found the air leak in the front left line and got it sealed.
then onto the back bags. 4 was still a good idea for load, but ONLY if i need load capacity. i unbolted the bottom of the load bag, dropped the truck, and plugged the bag/line. when the truck lifted, the bag stays compressed and just along for the ride with the chassis. this takes the rear from 35psi ride to 80. way more spring works a lot better with the shocks and matches the front better. the ride was already good, but now it's down right amazing. firm and connected, all while floating along.
3rd try ordering hinges for the bed hatch and finally got what i needed. hinges up really nice, and they are pinned to just slip off when up if i'm working back there. the side tilt gives me so much more room for working in there.
one thing that's driving me nutz, and not sure i'll ever be able to do anything about ... is this engine and transmission leaking oil. there is no way anything under this truck will ever rust now
Old 10-28-2024, 08:25 AM   #828
6DoF
6DoF's Avatar
while i worked on the barn this weekend, the wife got bored enough that i actually talked her into washing/patina saucing the 55!
3 coats of sauce, one whole bottle. didn't have the huge cosmetic change that they always show in the pictures, but made a huge change in feel. in the pic below it still needed a post-wipe and did get less shiny thankfully.
it's obviously sealed now though, the rust that velcroed to the microfiber rag the first coat wasn't by the 3rd. makes me feel way better now if the occasional rain happens.
Old 02-03-2025, 09:25 AM   #829
6DoF
6DoF's Avatar
dang ... took enough of a break again to fall to page 2, i gotta stop that.
well i'm back at it, we got big plans this year. not just driving it as much as possible or getting the engine turned up more once i know it's safe, but a few long-distance trips with the airstream. for that we need to wrap up a few functional things
- lower JobBox for better rear visibility
- lower rear view mirror for better rear viz
- finish wheel arches and build tailgate for a functional bed (add bed mat)
- rear bumper and closeout panel
- front bumper
- replace the horn that fell out
- park lights, reverse lights, dome light switch, cargo light
- OneGauge for extended engine monitoring and data logging
- Trailer brake controller
was already in fab mode after finishing up some tube fenders on a buddies jeep, so i just started cutting. sectioned 5" out of the JobBox by leaving 1" on the floor for rigidity and shoved that back inside the box. kept the floor sides straight and more easily keep water out with stitch welds and some seam sealer. time to paint the inside a light color to help find things, seal the rust, and stop rust dust from getting on everything. i think the lower box looks WAY better now that you can see the whole rear window.
also got the tailgate hinge section together with bits i had laying around. crushed some black pipe in the press to form a double-d liftoff hinge like modern trucks. hopefully get the steel i need to finish it today.
Old 02-05-2025, 09:08 AM   #830
6DoF
6DoF's Avatar
for just cutting down the factory chains, i'm really excited with how level the tailgate turned out! got the sheet laid out to plate that in and then on to the fender well. we'll have a functional bed in no time.
i really want to try 3D printing some stamping dies for thin sheet. make a '6DoF' badge or something. the 16g CORTEN i have won't work, but i think i have a sheet of duct work patch i could try it with. then rivet or tack weld it onto the tailgate. maybe some AL sheet and counter sunk screws so they don't stick up into the gate?
Old 02-05-2025, 09:37 AM   #831
dsraven
single skin sheet or plate? what's your flavor?
nice plan and execution. I like how it is removeable.
Old 02-05-2025, 02:02 PM   #832
6DoF
6DoF's Avatar
so the plan is 16g CORTEN sheeting on the inside only. the illusion of the factory gate look giving it some depth. the sheet will only be 11.5" wide, so it should be more than substantial enough.
CORTEN for anyone interested is "weathering steel". it's the rusty looking exposed steel you'll see skinning buildings, or used to build statues. nice part is it's still nice strong steel. think of it like "brown stainless".
the US steel building is fully clad in bare CORTEN. as a solute to Pittsburgh, when we built our house here, we did a CORTEN wainscotting. i still have a bunch of leftovers that i'm working thru. nice part for this truck however is i can leave it bare and it'll match! i'll have to at least paint the tubing though, probably just a basic black.
Old 02-07-2025, 10:23 AM   #833
KevinK7
KevinK7's Avatar
Thumbs up Re: Project: Tow-Rat (Lil' Blue)
Excellen work as usual. Although subtle, the JobBox cutDown looks great, as you noted no longer blocking the back window
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 02-07-2025, 12:01 PM   #834
Jason 56
The tailgate is looking great. Can’t wait to see the final result. You’re new shop looks amazing!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 02-18-2025, 02:39 PM   #835
6DoF
6DoF's Avatar
tailgate is done, but it really needs a stamped, patina, CHEVROLET cut out and riveted on there.
closeout panel is done including hitch hole, pin is easy to get to thru the hatch or by going under the bumper. also probably need some kind of hitch cover for an emblem or something down there.
fender wells are plated on the inside finally, just need metal worked. also still needs the tie-in to the bed side. but I'll mess with that after i pop the bed sides off for better mounting hardware.
OneGauge ordered, and right now it looks like it will be able to pass info to the Dakota dash so i don't have to have my phone connected all the time. that will be huge if it works and i can have warning lights on the dash.
Old 02-18-2025, 04:13 PM   #836
dsraven
looks good. what kinda clearance for the bumper interference do you have when opening the gate, looks close
do you have access to a bead roller you could make your own stylized emblem? or maybe make a template from MDF with your emblem inset and clamp the parts tight then hammer the emblem into the steel? good chance of getting a lot of distortion pretty much any way you do it unless you find an old gate, cut out the emblem and then fit it into the new gate and weld it in.
Old 02-19-2025, 09:17 AM   #837
6DoF
6DoF's Avatar
tailgate hinges mid bed at the lower tube. the sheet down to the bumper is fixed and tucks up behind the gate hinge tube. once it's not single digits outside i'll get a much better picture of the whole thing with the garage door open.
this 16g CORTEN wouldn't take stamping or rolling well, but i have thought about trying some stamping with 3D printed dies. i've seen a few video's of the plastic actually holding up great. something i could rivet or tack weld on. i think my ideal would be to cut up an old gate for Chevy logo, but a 6DoF logo might be cool for the hitch cover.
Old 02-19-2025, 10:45 AM   #838
dsraven
What does 6dof represent? something significant for you I am thinking.
Old 02-19-2025, 11:39 AM   #839
6DoF
6DoF's Avatar
6DoF is an engineering thing, 6 Degrees of Freedom. Basically just means total freedom. it started out as a boat name but quickly just became my thing.
my profile pic is a visual representation of it too
The 6 degrees of freedom is a representation of how an object moves through 3D space by either translating linearly or rotating axially. A single degree of freedom on an object is controlled by the up/down, forward/back, left/right, pitch, roll, or yaw.
Old 02-19-2025, 12:54 PM   #840
dsraven
Alright then. Beyond my pay grade. Lol.
Old Yesterday, 11:32 AM   #841
6DoF
6DoF's Avatar
busted out the borrowed TIG again last night and laid down some perfectly function, perfectly ugly welds. tried to "weave" them better, but the welder was already maxed out and just didn't have the balls to really do what i needed. so i just made sure i had enough material and made it look like the factory cast-in mounting boss. really pretty happy with how it turned out over-all. a little time to let the oxidation match and shouldn't be able to tell.
i didn't want the drill and tap shavings getting stuck in the core to later get into the engine, so i back-purged it with a leaf blower worked awesome! highly recommended
she's now ready to get PSI and temp sensors so i can have data after the turbo's but before the intercooler. needed? no. but I'm really interested to check efficiencies and be able to see what changes little things make. soooo many ppl are skeptical of the water-to-air setup, will also be nice to have data of who's right!
Old Yesterday, 12:17 PM   #842
KevinK7
KevinK7's Avatar
As usual, some awsome work
I believe youre gate is heavier steel, but it sounds like a similar plan
I found a bent up stepside gate that I couldn't pass up for the price. (Link in sig for addit. photos)
'68 C10 50th
Old Yesterday, 02:53 PM   #843
6DoF
6DoF's Avatar
exactly!
it looks like that chevy gate would be a direct replacement for the reading ... that's crazy
