6>8 Plugless........
![]() Join Date: Sep 2007
Bed side tool box parts (Hoard)
I've been searching and scavenging all the affordable bed side tool box parts I can muster up. My first truck, a 1969 Chevy Longhorn, had a bed side tool box. Unfortunately, I didn't save that part when I parted that truck out. When I built my 72 I wanted to add one but couldn't find a decent one at the time. Now I have a few in various states. I'm working on having enough pieces to make 2 complete bed side tool boxes. Anyone have any they wanna let go?
![]() One of these tool boxes is locked and has something heavy in it. I'm guessing it is a jack. I need to get it to Leon to have him un lock it and make me some keys.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
All about them K’s
![]() Join Date: Jun 2014
Re: Bed side tool box parts (Hoard)
Nice stash brewing there. Looks like you’ve got a couple decent doors, that’s the hardest part it seems. Don’t drill the lock what ever you do! Took me a couple years to get another one for my K20 after I drilled it out. The doors you’ve got look really decent. I bought the whole tool box bed from a guy on here 5-6 years ago. Got really lucky and the door is perfect not a single spec of rust. I’ve got an outer opening cut stashed away to repair the little bit of rust in the bottom of mine below the door. Parts are out there, you’ll find them eventually.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
![]() Join Date: Jan 2010
Any 73-76 tool boxes in your stash with this piece that covers the lock from the inside on them?
#4 | ||
![]() Quote:
#5 | |
All about them K’s
#6 | |
The Older Generation
I have a fiberglass tub laying in the back of the Green '67, and a couple of lock pieces. I think it is the lock bolt and the cover that goes over it and screws to the inside of the door.. LockDoc
#7 | |
Here are some other pieces I recently got from some fellow board members.
#8 | |
All about them K’s
I had no idea that rockers were hard to get right now. I’m sure it’s because of the Kungflu.
So, I am currently restoring (well, mostly fixing rust) on my bedside toolbox (1971). The original lock is gone, replaced by PO with a door lock. So, I made it work, but when in unlocked position, you cannot remove the key. The door rust repair took me weeks (mostly just work weekends). Now I am fixing the opening in the bedside. Luckily, the box is in good shape.
But, my tool box is painted white. Were they natural (blackish) fiberglass when delivered new? Where are the cut/tape lines (i.e. back of door, through box) on two tone trucks |
All about them K’s
Best I know, this is the original finish. My bed is original paint but solid dark olive poly so I don’t know where the exact tape lines would be on a two tone. I would guess anywhere covered by the trim like the normal beds.
Let me see if I can dig out one of my 2 tone doors and get a pic or you. The tool box inserts are just natural black fiberglass on all the ones I've had/seen.
I guess my question is the door solid color on the back or does two tone wrap the door (front and back). I know where the line is on the front. My thought is that is similar to the main doors in that the white (minor color) just wraps around as far as the door skin wraps around and then stops. So the back of the door would be body color (not white). Then, what about the recess that the box mounts to? Does the white color line pass through the recess or stop somewhere?
I know a lot of questions...definitely not right on my truck. Hope this is not hijacking the thread...good stash that I wish I had ![]() |
Every 2 tone one I've seen the white is split in the opening but the back of the door is the bottom color like a cab door.
Here is a picture of an opening to sort of show the paint split.
Has anyone found anymore or wanting to sell theirs? Member, Uncle, in Georgia has a Longhorn bed with a tool box I'd love to have but he's pretty far from me. Has anyone ever heard you couldn't get a tool box on a factory K truck? I've had a couple of members tell me this but I had 2 K20s that had them so now I am curious if they were original or bed swapped.
#15 |
Junior Member
![]() Join Date: Dec 2022
hi folks, I have a 72 cheyenne super C20 longbed that I'm in the process of restoring. It has a factory bedside toolbox. I believe I will be able to restore the door itself, however the inner latch mechanism and the hinges are rusted out.
Has anyone found a way to reproduce them using CNC or the like? Thanks in advance! Brian Hiltscher Last edited by LockDoc; 09-03-2024 at 05:31 PM. |
#16 |
![]() Join Date: Mar 2024
I see a guy is selling the hinges on eBay. Search for "VK2 Toolbox Hinge"
Ellensbrother Making the World Better One Truck at a Time 1970 C10 — Blue Lou 1977 C10 — Copper Kid; 1986 GMC Sierra 1500 — Brown Pearl; 1999 Chevy Suburban 1500 — Silver Lining; 2011 GMC Yukon XLX 1500 — Black Max Ellensbrother's Albums |
#17 |
Active Member
![]() Join Date: Feb 2009
I have the hinges. exact reproduction of an original hinge. $95 for a set of 3, shipped to lower 48. Also have several rear brackets that I have built to hold the box under the bed, $25/set.
Have two nice boxes - make an offer. Papa Smurf
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
#18 |
Active Member
Ttt
#19 | ||
Always on the hunt...
![]() Join Date: Sep 2006
![]() http://67-72chevytrucks.com/vboard//...d.php?t=732092 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#20 |
Mel, Appreciate you making the rules clear to us. Here's an alternative perspective on the issue, not a defense for what we've done. The hinges being offered for sale have proven impossible to find, so independently two of us had the hinges reverse engineered and manufactured new ones. Not for commercial gain, but to serve the like-minded members of this forum. We've both independently made personal investments to obtain the obsolete parts in economic minimum order quantities. Since the minimum order quantities yielded surplus hinges, the residual ones are for sale. I don't expect to turn a profit and may not break even. Neither of us are vendors. We just love these trucks and will be thrilled if our investments in fact can help others. One final note: One of the references is clear-it points to a listing on eBay, not a posting on the forum. Thank you for your leadership.
#21 | |
#22 |
Guilty as charged for using same username in two online forums. Again I'll note that I am not a vendor and have no plans to become one. The only Auto Parts being offered for sale on eBay are the surplus hinges. And they are not being offered on the forum and never were.
#23 | |
Mel never once contested why you made hinges. Nor did they contest how much money you were intending to make. The only thing Mel contested was you Ellensbrother selling items on the forum without being a vendor. So then you post that you never offered them on the forum. But literally 5 posts earlier is a post from Ellensbrother quoting an eBay ad selling items from yourself lol ![]() |
#24 | |
All about them K’s
#25 | |
