Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 01-08-2025, 08:04 PM   #1
brandnew72
New to the forums!
After some waiting I got approved to post and reply.
I've had this 72 c10 long bed for a few months and have been chipping away at it. Little stuff here and there. Picked it up already lowered, shaved, with a mild 350 and 4 speed SM465. Lots of stuff complete, really wanting to make it an enjoyable vehicle, not a show truck by any means.
The forum has been a lifesaver for many things and I can't wait to hopefully contribute!
Thanks guys!!!
brandnew72 is offline   Reply With Quote
Old 01-09-2025, 09:53 AM   #2
Louisvillekytruck
Re: New to the forums!
Welcome
Louisvillekytruck is offline   Reply With Quote
Old 01-09-2025, 10:01 AM   #3
Rickysnickers
Rickysnickers's Avatar
Old 01-09-2025, 11:36 AM   #4
Getter-Done
Getter-Done's Avatar
Welcome to the forum.
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 01-11-2025, 11:44 AM   #5
RenoKeene
Florida Edition
RenoKeene's Avatar
Welcome aboard! Got truck pics?
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 01-11-2025, 01:13 PM   #6
D.B
D.B's Avatar
Welcome, we all like pics. So, post as many as you can.
Darrell
1972 Cheyenne Super C20 (My Fun Drive)
2000 S10 Xtreme (My Drag Truck)
D.B is offline   Reply With Quote
Old 01-11-2025, 04:35 PM   #7
brandnew72
I'll get a couple up today. Bed is off right now for front panel replacement and frame coating.
Old 01-14-2025, 06:15 AM   #8
brandnew72
Here is one photo. Bed is still off. This is the day it rolled off the trailer.
Lots done since then but most things would be not visible.
Old 01-14-2025, 07:44 AM   #9
D.B
D.B's Avatar
Cool, thanks for the pic. Keep us posted with any updates.
Darrell
Old 02-15-2025, 06:28 PM   #10
brandnew72
Big success today with plumbing the air tank, wiring up the power and relay controls for the compressor, mounting the paddle valves, adding a cutoff switch for the pressure switch in the cab. Wrapped up as the rain swooped in. Maybe can get some plumbing done from paddle valves to tank this weekend as well.
Last 2 weekends got the front bed panel replaced, diff gasket fixed, painted all the frame I could reach with the bed off, installed a POL panhard bar, drop blocks, shock mount relocation brackets and notch all completed. Bolted then welded where I could. 4 degree shim seems to keep her vibration free.
Mounted compressor and tank in the bed due to the petcock valve being on the bottom of the tank. Ended up being very clean, as I never claim to have phenomenal wire management skills. I'll have some photos uploaded in a bit of the work.
Old 02-19-2025, 06:01 PM   #11
brandnew72
Got the rear done. Went to adjust my panhard bar and noticed no jamb nuts came with it! POL is sending a pair.
Back lays out on the diff. Panhard needs about an 1/2" of adjustment for oassenger tire to clear the inner fender lip.
Upside is my current rim/tire setup equals a 22x9.5 with a 265/35/22 tire. So I'll know where I sit once the Chopping Block arms are on and bags installed up front. That will help decide what size rim to use in the future. Hoping to get the front done this weekend. We will see.
