1968 350 With Edelbrock Carb and Intake Dies Out...
Starts Up nice runs good, but after about 5-10 minutes of driving slow or at idle it starts dying out. this happens warmed up and at about anything around 1.3K rpm or below. If I pick up the rpm to 2-3K it will run good up in higher rpms, but it will start running bad again and die out if I let the rpms go down.
There's lots of gas in the glass filter at the carb and it doesn't blow smoke and I run hot plugs 26s. I *think the plugs are loading up (I need to read them!)...also some guy told me I need some sort of carb work...I hope it's not that, heck, I Really hope it's not valves or ring work..... Whatcha Yuh All Think.....Thanks! |
![]() Join Date: Feb 2016
Re: 1968 350 With Edelbrock Carb and Intake Dies Out...
Does it do it with the gas cap removed?
What kind of ignition are you running?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
It sounds like a carb issue to me, specifically in the idle circuit. I’d start by adjusting the idle mixture. I don’t know Edelbrock carbs but have adjusted and/or rebuilt a few Holleys and a Rochester Quadrajet. There is plenty of info on the internet to get educated on how to work on them. I used to be intimidated by carburetors and working on them but it’s not as difficult as you might think.
![]() Join Date: Nov 2013
I can't confirm it because I'm a Holley guy, but I've heard that the Edelbrock carburetors don't like more than 5-6 psi of fuel pressure?
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Almost sounds like a vacuum leak.
Once warmed up, spray some carb cleaner or brake cleaner around the base of the carb and along the intake manifold where it mounts to the heads. If the engine RPMs flair up then there is a vacuum leak. |
#6 | |
May not apply, but thought I'd mention it - In addition to fixing the previous rich fuel issue, later on I had similar symptoms where my truck would load up at stoplights during short runs and would have to put it into neutral to keep it from dying. It turned out to be a bad ignition coil on the year-old GM HEI causing weak spark. It would idle fine, but stumbled under a load. Installing a new (and hotter) Davis Unified Ignition coil & module fixed my issue. Sidebar: The increased dwell in the DUI module made a noticeable difference in throttle response, so I bought one for my brother's '69 Chevelle 396, which woke his car HEI up too. Also fires up instantly all year, no choke.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
My brand new mechanical fuel pump is rated at 6.5-8 psi, that's what the spec sheet says. Yeah, there's a lot of pressure there because when I remove the filter that's on the carb side gas flies out of it!
I got points. I have sprayed carb cleaner everywhere...except right at where the carb mounts to the intake. The spark plugs I got in there now are only 6 months old. I'm getting ready to read them. I also have a brand new set. And yeah, there is a lot of pressure when I take the gas cap off..... Man, I'm just dyin to mess with those (2) brass colored adjustment screw at the front of the carb but I don't even know what they adjust. Thanks for your help! |
#8 | |
Start with the fuel psi. It's a well known issue for the Edlebrocks. Just my opinion.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
The fact that it runs well at first is encouraging. Did you install the Edelbrock carb recently? I run no more than 5 - 5.5 psi of fuel pressure (& have a fuel pressure gauge to watch it). Any more than that will likely cause fuel flooding problems.
As samert111 mentioned, you might want to check the base of the carb for leaks when it warms up to make sure it's got a good seal on the intake. Speaking of carb seals, I use an Edelbrock 9266 heat insulator gasket to keep the carb from absorbing heat from the intake, otherwise vapor lock/percolating can happen. I highly recommend an insulator gasket if you're currently using a standard one. You didn't say which model Edelbrock carb you have, but this manual covers most models: https://edelbrock.com/pub/media/wysi...ers-manual.pdf The two screws up front are the idle mixture screws, covered on page 6 of the manual.
Okay, so I'm going to get a "Fuel Pressure Gauge" and a "Fuel Pressure Regulator"? I guess from Autozone or Amazon? But first check some YouTubes on the subject. And I will look into this: "Edelbrock 9266 heat insulator gasket". Yeah, and I'm going to have to hunt down what intake and carb I got.
Thanks! |
Oh, and my truck came with the Edelbrock carb and intake. It was hacked together and left to sit in the New Mexico Desert for 10 years. it was/is running when I got it about a year ago.....this problem started sometime around the time I switched it from an electric fuel pump to a mechanical one....I know, I know maybe vapor lock. But this problem didn't happen right away, probably like (2) months after I switched it....and I've experienced vapor lock in other vehicles, this probable doesn't seem to *act like Vapor Lock.
Ok, I am studying this, but I'm going to have to ask, what brand & part number fuel regulator and gauge any of you guys using?
I have a mechanical fuel pump with no return port. Thanks... |
Did your problem start when you did something else (like replace the fuel pump) or has it never run well? If I were you I’d do some more troubleshooting before throwing parts at it. Just my $.02.
Disregard my last post. I just saw your post #11.
#15 |
#16 |
Yep, well okay.
I'm going to follow this guys lead with the Edelbrock set up. With the heat sink block and fittings I'm getting close to $300. Damn! that means I'm going to have to let my ole lady know about the purchase and she will complain! Oh Well! It'll be a week or two..... https://www.youtube.com/watch?v=HzuU...leCarSolutions https://www.youtube.com/watch?v=EXLi...leCarSolutions Thanks Everybody! |
#17 |
![]() Join Date: Jun 2022
Does that 5-10m mark coincide with the choke closing?
Could it just be leaning out once the choke stops enriching the mix?
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
#18 |
Chokes not hooked up...
#19 |
![]() ![]() Join Date: Jul 2002
do you have the choke wired open then? Your mixture might be too rich once it warms up with out the choke open to let in more air.
#20 |
Oh boy my lack of terminology at 6AM, I'm gonna call them the "butterflies", they are open. I'm guessing there are (2), they are both open. By what means I don't know but they are always open.
I'm leaning towards the pressure reg and the carb to manifold heat insulator. I've already warned my wife ($)! I still need to read the Edelbrock Manual and this other guy I know wants me to open the carb up. Me? the guy who doesn't know much...started off thinking the spark plugs are loading up with gas. I will get a look at it today....... |
#21 |
Ok, I sprayed a bunch more Carb Cleaner, focusing at Carb to Manifold: No Surging.
It looks like there already is a carb to intake insulator. It does look like one of the "Butterflies" is kind of shut. I do have a guy that knows some about carburetors coming over with his timing light and vacuum gauge this evening. I'm still going to get the regulator and stuff. Here's some pics, (the Edelbrock and Chrome was there when I got it)! Carb # 3.JPG Butterfly 3.JPG Intake 3.JPG Spacer 3.JPG |
#22 |
Ok, I wired that "Butterfly" opened all the way. Drove the truck about 10 miles and let it idle for about 5-7 minutes at ~700-800 rpm, didn't sputter or die out.
We'll see, the shade tree carb guy's headed of here. Thanks! |
#23 |
It may be cranky on first startup, especially in cold, but I had that on several of my trucks, wired choke open all the time.
#24 |
Can you just rotate the choke all the way lean to keep the choke flap open?
#25 |
The engine started sputtering out again even with the "butterfly" wired open.
Shade Tree Carb Guy came over with his Napa gauges and test equipment. Pulled a spark plug and it had Black soot Big Time. ..... I'm getting TEN PSI of pressure out of my Fuel Pump! ....and the guys that said to get a regulator 10 posts back are rolling their eyes and shaking their heads... I'll Be Back.......... |
