Old 02-04-2025, 10:55 AM   #1
rbruno68
2 Questions on CPP Disc brake Kit
I just put the CPP front disc brake kit on my truck. I had two questions. The kit came with a rubber gromet in the picture below. I am not sure what that was for and didn't see a place in the assemble to use it. Did anyone else get one of these in their kits and figured out what to do with it?
The other question is with the brake line hoses. They seem very long. I am wondering when the wheel is turned all the way towards the crossmember if they will kink. Anyone else have this issue with the CPP kits?
Name:  Rubber Gromet.jpg
Thanks,
Rob
rbruno68 is offline   Reply With Quote
Old 02-04-2025, 11:13 AM   #2
theastronaut
theastronaut's Avatar
Re: 2 Questions on CPP Disc brake Kit
I think they wedge those in the calipers to keep the piston from coming out of the bore during shipping. They're not used anywhere on the truck itself.
For the brake hose, I just twisted mine enough to add a loop to to take up the slack.
theastronaut is offline   Reply With Quote
Old 02-04-2025, 01:32 PM   #3
6stringer
I used the same kit as well. I couldn't figure out the donut either, so left it out.
I did the same with brake line. Twisted and confirmed it wasn't rubbing. I did put one of those protective sleeves over the hose just to be sure it wouldn't rub through as quick if there was movement. Its the kind of sleeve that is a series of tight coils. Ultimately, I want to order shorter houses.
6stringer is offline   Reply With Quote
Old 02-07-2025, 10:54 AM   #4
rbruno68
Yes, I may end up looking for shorter hoses too. I will try the loop that you both recommended and see how that goes. I don't want to change these out till I see how the steel brake lines work. I bought pre-bent lines from Inline Tube, so want to make sure I don't have to make other modifications.
Rob
Old Yesterday, 06:48 PM   #5
hairball
I Installed the Right Stuff front power disc brake conversion on my 65 C10. Can someone recommend a pre bent line kit that they have actually used. So far I have tried Right Stuff, CPP and Inline Tube. They all have fitment issues. Right now, I am not interested in making my own lines but that may change. I don't mind paying for something that actually fits and looks good.Thanks, Hairball
hairball is offline   Reply With Quote
