![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Anyone attach side molding with silicone glue?
I was not happy with how the sticky pads on the plastic clips made the trim stick out and left gaps so I tried silicone glue on the plastic tabs on a couple of pieces and stuck it on and used tape and wedges to hold it on until it dried. It is really tight to the body and seems solid but I am wondering if it will hold up to flex and vibrations.
The only other way I see to get it tight to the body especially with with the upper trim is to use the push in clips and drill holes for them.
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
Re: Anyone attach side molding with silicone glue?
I actually did the same thing on my 71, just a small dab, but it’s not a show truck by any means , I found the plastic tabs didn’t keep the trim tight to the body
It wasn't on any of these trucks but on a Dodge Caravan.
One of the moldings blew off and the only one I found in a junkyard (OEM was priced outrageously) had a non-OEM double sided tape. It was a bear to get off. To install it I used double sided Gorilla tape and its been on just fine for years.
Best wishes to ya’ll. Sincerely, Jim "To invent you need a good imagination and a pile of junk" - Thomas Edison "I've always wanted to get a job as a procrastinator - but, I keep putting off looking for one - I guess I'll never realize my life's dream - so sad." - Me ![]() My C30 wrecker build/repair/update thread: https://67-72chevytrucks.com/vboard/...d.php?t=855904 |
![]() Join Date: Dec 1999
The double stick tape that comes on the aftermarket clips is to thick. Get some thinner tape from 3M, remove and replace it. 3M has some very thin tape designed for emblems and such. Use all the time at the body shop.
Very simple solution. When installing my molding I will not be using the stick on clips as received.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Active Member
![]() Join Date: Apr 2023
Silicon is not good to attach anything to the body of an automobile as it attracts moisture. Causing rust to form around silicon.
Ask any body man if they use silicon. None of them will. |
Who Changed This?
![]() Join Date: Jan 2013
^ Plus, it's a real bear to make sure it's all gone when it's time to repaint. Talk about fisheye! Maybe products have been developed to avoid it, I haven't painted a vehicle in 12 or so years.
![]() Join Date: Jan 2010
I bought a car 10 years ago and the windshield was cracked. I brought it in for a new one and they removed it and basically after that the car was shot. Previous owner used silicone to put the windshield in and the pillars were rotten and unstructured. Would need complete replacement. It went to the crusher. Don't use silicone
When I was doing auto glass, I hated dealing with the silicone people would sometimes use to try to stop leaks. It does attract water and it's eventually going to vibrate loose, leaving a surface that's hard to get anything to stick to.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Is there a glue that would work then but still be flexible
3M Black Weatherstrip Adhesive works well.
Don't do it, properly clean and use the thinner VHB tape or like you said the clips and drill the holes.
With that said. This would work - https://www.amazon.com/U-Pol-Product.../dp/B002SQY852 |
![]() Join Date: Dec 2014
If you've ever had to remove silicone, you'd find excuses and not reasons to use it.
I was pleasantly surprised by 3m tape. I didn't think it would hold up but it definitely has.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
I found this video very interesting. When I am ready I was considering doing it this way.
https://www.youtube.com/watch?v=TcGBoTphXfc |
#14 | |
#15 |
I thought about trying the neodymium magnets too with the 3m stick on backing to them.
#16 |
3M VHB tape is a much better choice
#17 |
The main issue with the moldings at tape is they are too deep to really attach the tape to anywhere and there needs to be some sort of spacer if you aren't using the plastic clips. I thought about taking the bolt-on clips and grinding off the stud and then putting the 3m tape on them.
The plastic clips just seem to stick out too far even with thin 3m tape?
#18 |
It cowboy Click on the link and watch the video.
#19 |
Just ordered 3 rolls of the 1/2” wide x 0.025” thick x 15 foot rolls.
Excellent video to watch. My top trim was stuck on by stacking pieces of 3m tape. (No filler panel like in the video.) I’m gonna redo it all as there is a 1/16”-1/8” gap of daylight on the trim. Not nice at all....
"If it ain't broken, fix it 'till it is!" |
#20 |
Ok, that is what I am talking about and I wish I had seen that video last week. Much better system and how it should be. My cargo trailer is screwless and has the outer skin attached from the factory with the VHB tape.
