Old 07-28-2020, 12:07 PM   #26
jjzepplin
jjzepplin's Avatar
Re: Old Yeller 4x4 upgrade
I ordered a silicone Trans pan gasket for the 700R from Moroso and it seems to be a good choice. I put it in yesterday but it got too hot for me to put the fluid in. I have a drain plug on the pan that has a plastic seal. I want to change the gasket out for aluminum maybe before I put the fluid in. Just a thought. Not exactly sure where my leak was coming from as the rubber gasket I removed was not in that bad of shape and was not split. I know I have a leak at the speedo cable but that is further down the line and obvious. Gonna try some seals for the 205 speedo output soon.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-07-2021, 09:20 AM   #27
jjzepplin
jjzepplin's Avatar
Well I got the wrong seals for my speedo output on the NP205. I will get the smaller ones and try that. I have the bigger ones for free to whoever wants them. I am also getting the brackets to install the Sanden Compressor for the A/C sorted out while she is down. I already have a new A/C line kit and the crimper on the shelf as well as the cross flow condenser. I may also upgrade the evaporator to the 1973 up style. Don't know. I did also acquire some 1973 ish Stock hubcaps. Those Dana 60 fronts were expensive. Now I am searching for Stock Steelies to fit them so I can lower this beast back down a little.
Old 03-13-2021, 04:12 PM   #28
hammerfast
https://www.summitracing.com/parts/w...00805/overview
hammerfast is offline   Reply With Quote
Old 03-14-2021, 06:13 AM   #29
jjzepplin
jjzepplin's Avatar
Welcome to the site! Yeah I saw those. They are nice but expensive. I was thinking more like some used Furd Van wheels. Cheap and 7" wide. I am eventually going to bring this truck back down to earth and 10? wheels might look weird. I am getting older and this might be my old grandpa truck.
Old 02-19-2025, 05:46 AM   #30
jjzepplin
jjzepplin's Avatar
Well I bought a new property and it flooded pretty good with Hurricane Helene. There is no house there yet so no losses. This may end up being my high water rescue vehicle.
Old 02-19-2025, 05:47 AM   #31
jjzepplin
jjzepplin's Avatar
I think I have a small leak at the rear main seal. Guess I am going in for that soon. I may wait til I move.
Old 02-20-2025, 10:26 AM   #32
connorm
What's the rescue vehicle looking like these days???
connorm is offline   Reply With Quote
Old Yesterday, 11:13 AM   #33
jjzepplin
jjzepplin's Avatar
So I have not done much to the truck except fixing the small leaks. It still runs awesome but I need to replace the tires. They look fine but are 2010 Goodyears. I toy with the idea of selling it someday but then I start it up and the feeling goes away. I need to paint it. I bought a 60 gallon compressor for painting it but now I need all the materials. I was goint to take the body lift off of it but it seem as though I need to notch a rear bed brace for the fuel tank that's now under the bed.35-40 gallon tank I think.
