#5201 |
![]() Join Date: Mar 2011
Re: What did you do to your truck today.The 3rd chapter
I bought this highlander/dark saddle skin for another project in 2018 and changed my mind on the color scheme on my Doc & Kim build which is under construction...
![]() are...stay tuned ill try to do the switcharooo this weekend
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#5202 |
Put a tach in the truck.
#5203 |
![]() Join Date: Feb 2002
Last night I went out to the supermarket for groceries. The 292 L6 in my '68 C/10 started right up, and the engine was fine on the three mile run. After I got out of the store, it wouldn't start.
Gas gauge read 1/4 tank. Not empty, but I added the 5 gallons from the jerry can in the back, in case it was a fuel problem. No start. So I opened the hood and pulled off the HEI Distributor cap. [I was going to change out the Module in case it was burned out.] Aha! the Rotor was loose. Both screws had backed off and it was at a slight tilt. So I screwed the Rotor back on proper and tried again. No start. OK, I'd better try that glovebox Module. Meanwhile, searching in the crossbed toolbox, I found a NIB Rotor and an old Distributor cap. The old cap was worse than the new one. I put the emergency Module in -- I didn't have any fresh White Heat Sink Paste, but there was a prodigeous amount under the bad module, so I put it in dry. The new Rotor went in, then the cap, and I reconnected the Plug lead back onto Sparkplug #1. It did start, then sputtered and died. I was unable to get the engine to keep running. Just a few seconds on it sputtered out, dead. Choke had no effect. So I called a Tow truck. And we got it home after a couple of hours. Distributor is the Remote Coil type. The bad Module tested Bad at AutoZone. Got a new one under a Lifetime Warranty. The Rotor had a Life Warranty at O'Reilly's, so I have a Cap and Rotor on order from them. The counter woman at O'Reilly's said they couldn't test the Module there. They'd taken away the test machine, she said. [She lied. it's still there.]
#5204 | |
![]() ![]() Join Date: Jan 2005
