![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Do I need a fuel pressure regulator?
I keep reading that the Rochester carb likes lower fuel pressure around 6-8 lbs? Does a replacement fuel plump provide too much pressure and should I put in a regulator or just a pressure gauge for now or neither is really needed.
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
Re: Do I need a fuel pressure regulator?
Possible your vacuum gauge includes a fuel pressure function. Used to be a common combo. Does it have a 2nd arc of numbers from 0~8 or such?
If the pump is working correctly, then a Q-jet shouldn't need a regulator. BUT we all know that QA is a often skipped step these days. |
![]() Join Date: Jun 2002
I've used them before without any regulation, but this last engine I put on an Edelbrock fuel pump that is supposed to limit fuel pressure without a regulator. I have the part number in the garage if you want it.
If you do run a regulator don't get the round dial type. The gaskets fail and pose a fire risk.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; Yesterday at 11:12 AM. |
