Old 02-21-2025, 11:56 PM   #1
Luke87gt
Luke87gt's Avatar
I6 250 to v8 350 conversion questions
Hello, my 1969 c10 (3OTT manual) currently has an i6 250 and I have a 350 small block sitting in my garage. I’ve read about the swap on this forums and have a pretty good idea of what’s involved but would like to ask for your help to eliminate some gaps
First, I understand that the 350 can utilize the i6 engine location, mounts, clutch, flywheel, starter.
a.) although I understand that the i6 trans and flywheel will work, I’ll replace these anyway. Given that, I plan to go with a v8 clutch/flywheel which is slightly larger in diameter if I recall. Wondering if anyone has any recommendation for a good value clutch/flywheel for a v8 that is strong, won’t kill my left leg, and reasonably priced? I actually don’t know the year of my 350, how can I be certain I’m buying the right clutch/flywheel?
b.) I’ve read that the block needs to be drilled and tapped for a clutch pivot ball? Can anyone steer me to a part number or link for this? It would help to know the drill/tap sizes
c.) does anyone have a picture of where the pivot ball needs to be located on the block? I’ve read that it’s self explanatory once the engine is in the car but I will be doing the drilling/tapping with the engine out of the car.
I think these are the last details I need. Thank you in advance!
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-22-2025, 09:02 AM   #2
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: I6 250 to v8 350 conversion questions
No you don't need to drill for the pivot ball. However you do need the correct bracket for the pivot ball and a different Z-bar for use with the SBC
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is online now   Reply With Quote
Old 02-22-2025, 09:54 AM   #3
Getter-Done
Getter-Done's Avatar
Here is some pictures and info in the Old Thread below.
Link: https://67-72chevytrucks.com/vboard/...+bar+stud+size
The early bird gets the worm,
85 Chevy K-20
Old 02-22-2025, 11:23 AM   #4
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
you actually dont need to change the bracket or Z bar if the motor is still set back in the I6 location. Im still running all my I6 stuff on my clutch setup.
With a small block there should already be a threaded hole kind of in the middle between the dipstick and oil filter and the ball screws into that.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 02-22-2025, 11:39 AM   #5
Luke87gt
Luke87gt's Avatar
Motor will be set back in the i6 location for Porsche 911 F/R weight distribution (jk). But ya, will use the rear positioning which is set back.
My understanding is that you then do need to drill the block but can use all the bar hardware from the i6.
Maybe I can take a pic of what holes are there on my 350 later today.
1969 C10 Shortbed
Old 02-22-2025, 11:56 AM   #6
Luke87gt
Luke87gt's Avatar
Interesting, so you never had to drill/tap?
I’ve read multiple posts here of i6 to v8 conversations saying that was necessary (in addition to needing to cut 1/2” from the bar)
1969 C10 Shortbed
Old 02-22-2025, 12:14 PM   #7
Getter-Done
There is this bracket if you can find or fabricate one.
Here's a frame bracket.
https://www.ebay.com/itm/28584162943...3ABFBM5KXP5qVl
Here some pictures and possibly a place to buy?
https://4speedconversions-com.3dcart...k_linkage.html
85 Chevy K-20
Old 02-22-2025, 02:48 PM   #8
67 twins
All I know is the stock setup has a bracket. It does not thread into the block.
Chris
Old 02-22-2025, 09:34 PM   #9
Luke87gt
Luke87gt's Avatar
So there are two holes there for the bracket which is good news.
What I need to figure out now is what do I need in order to connect my 6cyl Zbar to my 350 *if* the engine is to remain in the 6cyl position (set a few inches back from where Chevy put 350 in trucks from the factory)
1969 C10 Shortbed
Old 02-22-2025, 11:19 PM   #10
pjmoreland
pjmoreland's Avatar
Since your engine won't be in the standard forward SBC position, a standard SBC bellcrank mount wouldn't be in the right position. I believe you would need one of these studs that screws directly into the forward hole in the engine block.
https://classicparts.com/1963-84-clu...ank-block-stud
pjmoreland is offline   Reply With Quote
Old 02-23-2025, 01:11 AM   #11
Luke87gt
Luke87gt's Avatar
Thank you, just ordered it
Although it is surprising to hear it’s the front hole and not the rear hole given that the engine is being set back? I guess it’ll be obvious once the engine is in.
1969 C10 Shortbed
Old 02-23-2025, 01:17 AM   #12
pjmoreland
pjmoreland's Avatar
The bellcrank bracket on the frame is in the same position regardless of the engine position. If the engine is moved rearward relative to the stock position, then the engine mounted stud moves forward to compensate.
Old 02-23-2025, 01:20 AM   #13
Luke87gt
Luke87gt's Avatar
Visualized that improperly.
You sir are correct, thank you
1969 C10 Shortbed
Old 02-23-2025, 02:35 AM   #14
pjmoreland
pjmoreland's Avatar
Post a photo of the rear of the engine. That should help with sorting out whether your engine has a one-piece or two-piece rear main seal. This will help in determining which type of flywheel you will need.
Old 02-23-2025, 02:54 AM   #15
mr48chev
mr48chev's Avatar
He has an 010 block 4 inch bore two piece seal,
My ongoing truck projects:
Old 02-23-2025, 03:07 AM   #16
mr48chev
mr48chev's Avatar
When John and I did the swap in his 70 we left the transmission where it was and as I said earlier left the transmission and bellhousing in the truck and unbolted the engine from the bellhousing. Moving the SM465 would have mean cutting a new hole in the floor for the shifter and building a new front half for the drive shaft. In truth I don't believe that the transmission moves be it six or V8 but you move the mounts on the frame back to the V8 spot.
Checking on the rock auto what options for clutches are listed a 250 could come with a 10 or 11 inch clutch and a 350 came with a 11 or 12 inch leg killer clutch. To my way of thinking unless you are going to actually hook onto heavy trailers and tow them or pull stumps you don't really need a 12 inch clutch. I think my 77 454 has one but that is in a 1 ton dual wheel flatbed with a 10 ft bed with a hoist and it might get asked to tow just about any bumper pull trailer that it can handle. If I drive it in traffic very far I have a hard time walking for a bit because my left knee is throwing a fit about the clutch.
Old 02-23-2025, 03:38 AM   #17
Luke87gt
Luke87gt's Avatar
If I get an 11” clutch and flywheel, does that mean the position of the starter needs to change?
I also wonder why the part numbers for the 11” clutch kit differ between the i6 and v8
1969 C10 Shortbed
Old 02-23-2025, 03:47 AM   #18
mr48chev
mr48chev's Avatar
No, the truck should have a 168 tooth flywheel ring gear in it now.
Unless time to get a flywheel and clutch is short and critical and you can't wait for the brown truck to show up or the parts house to get them in I would wait until I pulled the 250 as it could come with a 11 inch clutch and if it has a granny 4 speed it most likely does. You might look on the spid on the glove box door and see if it shows anything for clutch and if you can't figure it out one of the guys here can put on his decoder ring and get the answer. I know where to find the answers for AD trucks but often have to ask for 67/72 on things like that.
Old 02-23-2025, 10:14 AM   #19
67 twins
The bellhousing crossmember is definitely different & further back in the six cylinder truck
Chris
Old 02-23-2025, 12:10 PM   #20
CAMAROBOY68SS
This is how my whole setup works in my truck.
The Twins:
The "Others"
2017 Camaro SS
Life long Chevy guy
Old 02-23-2025, 06:42 PM   #21
MikeB
MikeB's Avatar
Guys, how much room is there for the HEI cap with the engine mounted in the rearward position?
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-23-2025, 08:17 PM   #22
Accelo
Accelo's Avatar
The HEI fits if the motor is in the stock V8 position
I recommend cutting the feed distributor wire to about 2" in length at the block at the firewall, (It's a resistance wire and looks different from the others). Solder a new 14g wire to it and feed the HEI that way.
The ballast resister is built into the wire.
You will not need the 12V feed from the starter any longer, remove it.
Accelo is offline   Reply With Quote
Old 02-23-2025, 11:47 PM   #23
tim_mc
tim_mc's Avatar
Yep, the HEI clears the firewall when in the rearward I6/4x4 SBC position. I'm able to take the cap on/off. It's just not as convenient as the 2WD SBC forward position.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 02-24-2025, 12:16 AM   #24
MikeB
MikeB's Avatar
It's been 30 years since I upgraded to an HEI, but was thinking that my 69 C10 with a 307 had a ballast resistor, not a resistance wire. Just did some digging and see that I was wrong.
However, I can't believe the amount of bad info out there regarding the function of a ballast resistor or resistance wire. Examples: I read where an HEI would work just fine w/o bypassing the resistance. Also that the resistance had nothing to do with reducing current, but simply reduced the voltage to the coil. (Must have been for vehicles with the 6-volt coil option.) Some real geniuses among us!
Mike
Old 02-24-2025, 12:27 AM   #25
Luke87gt
Luke87gt's Avatar
Good to have confirmation
Thank you for posting
1969 C10 Shortbed
