#576 |
low n' slo
![]() Join Date: Mar 2009
Re: 67-72 Electric speedo
heres what i got which should be about done...but id like to add a few things to update this. its very time consuming and trial and error but i love the stock finished look. i ran an 80s camaro tach in mine along with the battery gauge guts in the ammeter face...so its a little different.
to get the factory paint off the lens...use Purple Power. it dissolves it VERY easy. be very careful with it and dont let it run to the other printed areas. the green paint i found was at Hobby Lobby. it comes in a little small spray can and it matches VERY well imo. i did 3 coats and it came out nice. i found a 2 wire light socket on amazon that fits pretty good. the base is rubber and does have 4 locking tabs but they fit very nice. if you need to add holes...go just UNDER 5/8" on the hole (i used a drill step bit). all the 5/8 will make it a little loose which is why you see the silicone on one of them. i havent plugged this in to check on the truck yet so cant comment on that yet (truck isnt even running yet) for the fuel gauge...i cut out the stock red lens for the oil and temp lights. instead, i cut the high beam and service engine plastics off the old s10 gauge. cut to fit, then mask off and paint over the words not being used or that will show..then you can glue them to the fuel gauge. gives you a stock-ish way to get a high beam indicator and SES light without drilling into anything
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 08-05-2022 at 03:08 PM. |
#577 |
low n' slo
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#578 |
Looks good! Nice find on the paint, that makes it easier.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#579 |
Eric I wold like to order a set of decals. Do you still have?
#580 |
Bringing this back up as I am interested in a set of the decals also.
#581 | |
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#582 |
low n' slo
like the actual lens? i cut them off the original gauge and glued the ones from the s-10 on. or are you talking how do they light up?
#583 |
Sorry for the vague question. I was mainly asking how you glued them down. Also, how did you get the old ones off without ruining the gauge?
#584 |
low n' slo
if i remember correctly that red film just pulls right off leaving the holes blank. then, you cut the s10 gauges to fit over them and leave enough to cover the holes. i used super glue to fix them back to the gauges. hope this helps!
#585 |
I am having trouble finding 18–20-gauge sheet metal in my area. Would 22-gauge aluminum work ok?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#586 |
60-66 Nut
Personally I think .027" thick aluminum is too thin and flimsy.
#587 |
So I went cheap and bought a small cooking sheet from Wally World for $7. It felt pretty sturdy so I cut my piece out of that. It's aluminum but I think it should work and is easy to work with so far.
#588 |
I'm interested in a couple of sets of the decals/kits.
1950 Chevy 3100 Pontiac 350, TH350, Chevelle subframe... 1969 Chevy C/10 350, TH350 family owned since new 1996 Camaro Z28/SS #884 LT4 top end, M6, T-Tops... the project 2012 Camaro ZL1 #608 Stock LSA, M6 the Beast 2008 Chevy 2500HD LTZ Z71 CC/LB, 6.6L, Tuned w/ EFILive... |
#589 |
![]() Join Date: Dec 1999
If wanting a stock type check engine light in the dash cluster for an LS swap. Acquire a gas gauge from a 40 series + truck with a diesel engine. IIRC the light up position on bottom right of gauge says "engine" Have a cluster with an air pressure gauge to use in my truck and it has this gas gauge. Been a long time since I have looked at it. Maybe different but was appropriate, just remember I am going to use this as an SES light on my truck.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 05-10-2024 at 02:48 AM. |
#590 |
So I think I waited too long to paint my lens. The adhesive stuck to a few of the numbers and did not come out looking too good. I also was not a pro at removing the centers of the zeros and such. I was worried about that part and rightfully so. If I did not destroy the template removing it I think I would try again.
#591 |
So I test fitted things together and all the imperfections in the painting are covered up by the black insert and you can't really see them. Cool! Oh and I contacted Krylon about my little short cut spray can (thank you guys for the hint) not having a mixing ball inside and they are sending me a refund. I did not ask for a refund but they insisted. I zip tied the can to a reciprocating saw blade and shook that baby for five minutes. No ball. But mixed great and worked fine. A great way to shake up old paint cans.
Kooky idea... Has anyone thought of using the voltage gauge out of the S-10 dash in this conversion? Would it even work?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; Today at 10:59 AM. |
#592 |
60-66 Nut
There is a thread on this forum somewhere, showing retrofitting a squarebody volt gauge into a '64-'66 dash. I would thing a '67-'72 dash would be similar in that aspect?
