#26 |
![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Re: Another sniper question - which kit / config
I found a mechanic that knows his carbs and older vehicles and he says the throttle link bushing on my Quadrajet is worn out and probably causing a vacuum leak. I found a bushing kit from Cliffs for $75 plus the carb probably needs a rebuild kit. For the cost, time and expense I an considering throwing on a Holly 1406. Any thoughts or virtual beatings to be had.
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#27 |
Who Changed This?
![]() Join Date: Jan 2013
If you think you can do the reaming of the throttle plate and installation of the throttle pate bushings, good on you. I had those done by a local shop, since I didn't want to buy Cliff's kit for a one-time job. Rebuilding a Q-Jet is dead simple. Buy Cliff's book; there are things you will learn that will stand you in good stead. I didn't make any modifications that Cliff shows in his book, as my carb is dead stock on a dead stock engine. I did end up putting on an electric choke, though. Checking that there is a vacuum leak at the throttle shaft is easy- just squirt carb cleaner at the primary throttle shaft on both sides- left and right. If the rpm changes, the baseplate is worn and needs the bushings. The secondary throttle shaft does not need bushings, btw.
ETA- you engine will run great with the new carb, because it is new. But it won't actually be calibrated like the general's engineers spent many sleepless nights making sure the settings were correct.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; Yesterday at 12:45 AM. Reason: nights |
#28 |
![]() Join Date: Sep 2001
As a fellow IT pro, I'll share what I decided about carbs/EFI kits - hope it helps.
An EFI system is definitely an upgrade. Having computer control and an oxygen sensor in the exhaust gives EFI capabiliites a carb just wont have, and its fun to integrate newer tech into old tech. But I think its a step 2. Don't skip step 1 of understanding how your cab works including basic tuning. Remember when you learned to drive a manual transmission, and it put you into an elite club of auto enthusiasts who knew this advanced capability? Tuning a cab puts you in an elite group of classic car enthusiasts. And once you replace your carb with EFI, that opportunity is lost. EFI is an expensive upgrade that will provide some benefit but on the list of upgrades there are many that have a larger benefit both for improving drivability/reliability and learning. Before I put in an EFI I would consider (in no particular order): * Power brakes * Power steering * LED lights (inside and out) * Relays for headlights * Upgraded stereo * overdrive transmission * fix leaks * sway bar Im still working through that list and hope to do EFI after I get these items done, that in my view have a faster return on the time and money invested. And some of them are techy :-) Owning a truck our grandparents designed means learning to master the tech they perfected. Carbs are easy enough to learn and get you into that exclusive club everyone wants to be in of elite classic car enthusiasts. |
#29 | |
![]() Join Date: Jul 2000
But I'm not sure where you could find one these days, or what it would take to retrofit the system to an older truck.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
