![]() Join Date: Jan 2024
PTFE or AN Fuel Hose?
Which ones the easiest to build with?
Really I'd like to remove all rubber/hose clamped fuel line on my truck. fuel pump->filter (I'd like a glass one to see what's going on)->fuel regulator->carb. There is some fuel line between the gas tank and fuel pump i'd like to do too. What you using? I did watch this... https://www.youtube.com/watch?v=QFJ2...eworksOfficial |
Re: PTFE or AN Fuel Hose?
I moved my tank to the rear with a fuel injection pump for my FiTech EFI. I ran Evil Energy ptfe all the way from the tank forward and back for return line. I also ran it for the trans cooler lines from the trans to radiator to external cooler back to trans. I had never used braded line before went in pretty easy. I used a lot of clamps to hold it to the frame. When I first started the truck, I had zero leaks anywhere. I was definitely pleased and surprised. Also used a 50 and a 100-micron filter hooked back-to-back in the frame rail where I can access it for maintaince. I do not recommend using a glass fuel filter. They have some clear plastic ones you could use temporally if you have been having problems. And this is only with a low-pressure system "stock".
![]() Join Date: Jun 2022
"glass filters have burned down more houses than ex-wives" -- Derek Bieri
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
![]() Join Date: Feb 2022
I don't think PTFE is needed unless you are running high alcohol in the fuel. There maybe other reasons but I can tell you I've not had any problems with standard AN fuel line running Cheveron and other top tier fuel in CA. I run 60lbs in -8 and -6 lines. Same in race car running AP Race Gas 98 unleaded. Aluminum 37degree Conical washers make huge difference in weeping oil line fittings especially if often disconnected. One just saved me on a inverted flair I could not get to seal just last week. Venders don't like to stock because they are very delicate and damage easily making them a little hard to source.
I am no expert by any means, but in my research, it is my understanding that the ptfe has much longer longevity than a standard rubber efi fuel line. I know on race cars you are always changing stuff around and on regular street cars you don't mess with stuff nearly as much unless there is a problem with it. This is what I am hoping for. Finish it and don't worry about it for several years.
Ok, so I'm going to put this, no glass:
filter.jpg so I'm going to go: fuel pump->Regulator->Filter I'm going with Evil Energy once I figure out all the fittings I need. I will need a Good tube cutter too. |
I put new supposedly good rubber fuel line about 6 months ago. I've messed with it pretty much since I put in on, new fuel pump, filter, pressure check, and the line is feeling a little gummy and leaving my fingers black...I should just learn how to bend pipe....but even at that you Still have a few pieces of non metal fuel line here and there (I think?).
#8 | |
![]() Join Date: Nov 2018
Always use the correct size bender for the tubing O.D. you are working with e.g. bending 1/4" in a 5/16" shoe will just flatten your tubing Bend left to right just like you read, you can lay out all your measurements basically end to center, center to center measuring and marking left to right. Always mark a line completely around the tube with a felt marker so no matter the position it's marked. Always bend a wire as to what you want in a scaled down version, this will tell you what direction to bend as it can get confusing and always hold this wire up and compare for correct bending direction, this also helps keep your "File 13" to a minimum. The actual bender will have a "0" or arrow "^" that lines up with the degree you want to bend it. You will get a feel for it as to how much to take it past your desired degree as it will spring back a little. The "L" is what you line up your center mark for 90 deg. bends you just put around the tube and automatically compensates for the "Gain" in other words if you mark two marks 6" center to center your finished bends will be 6" center to center. The "R" is for a "Reverse" bend, sometimes for lack of straight tubing clearance you cannot bend the normal left to right, so you flip the bender around and now you line the "R" up instead of the "L" on your mark for a 90-degree bend There is no "Reverse" bend for a 45-degree bend, you still use the "45" deg. to line up your mark for a 45-degree reverse bend Last edited by Sheepdip; Yesterday at 01:24 AM. |
#9 | |
Hard lines would work harden and become brittle as they flexed
Man, it would sure be nice if that Edelbrock fuel line with filter (above) would screw right into the Edelbrock fuel pressure regulator, and if I'm afforded enough space to get it all in that area right by the carburetor....
![]() Join Date: Dec 1999
I would definitely use the PTFE AN line...
I find the ends are much easier to install properly. It doesn't cost that much more for the PTFE line. My experience has been with the cheap no name kind from amazon. |
As RNS stated, the glass filters with the changeable elements are as safe as the rubber seal will stay.
I had one on my truck for a few years, but I was under the hood just about every day, to tinker with things. One day I happened to smell fuel, and when I touched the filter, I found it was weeping from the seal, onto the intake manifold. No more glass for me, I just change them out every other oil change ![]() There are sealed clear plastic filters available, if you really want to see what’s inside |
Earl's: https://youtu.be/T4rutc9qAOc?si=pcbfUWXntLTB16uZ
I run Earl's AN on my '72 from the outlet to the pump, then I bent up a nice stainless fuel log for the Holley 760 carb. I used these adapters after cutting the nipple from the tank feed: https://www.holley.com/products/plum...ts/AT165006ERL Then out to a Summit 100 micron filter mounted with Adel clamps to the frame. Then the line goes forward into the pump, then to the hard line, and to a 10 micron Summit filter, and on to the fuel log. I can post pics if anyone's interested. |
After some thought I think I'll run the ptfe straight from the carburetor to the fuel regulator and skip that Edelbrock banjo carburetor fitting.
***Probably end up putting the regulator/gauge/filter as one unit on the firewall*** So, I'm going to need: 1.) Screw in male fitting for fuel pump to accept PTFE connection. 2.) PTFE female fuel line connection fitting for the fuel pump fuel line. 3.) PTFE female connector to compatible fuel filter. * Hopefully Fuel Filter and Regulator screw together, No Line Needed 4.) male/female fittings off of regulator. 5.) female fitting to go into carb 6.) And the Big male fitting that screws into the carb to accept the PTFE female fitting. 7.) 15-20 ft of PTFE |
#15 |
You don't need a fuel regulator unless you're running high fuel pressures like 12+ PSI. Most mechanical pumps put out 6-9 PSI @ 80 GPH unless you're using a racing pump.
Couple of tips: AN 6 (3/8) is a good size unless your engine is a beast. Fuel pump fittings will be NPT, either 5/16 or 3/8 likely. Use straight fittings and plan the AN swivel fittings to match so you're not trying to clock the fuel pump fitting. Those fittings do need fuel-compatible sealant like aviation permatex on the pump side. For classic cars, unless you've cleaned the tank it's a good idea to put a 100 micron filter before the pump, and a 10 micron filter before the carb. This catches junk from the tank and ensures clean fuel to the carb. NO GLASS as has been mentioned. Earl's and others make a fitting that will screw directly into the carb if you want to do something different like bend your own. Do yourself a favor and buy a decent set of magnetic AN fitting jaws for your vise, and the aluminum wrenches (NOT ADJUSTABLE) so you don't scrape up the fittings. Buy and be generous using the lube during assembly. I use these shears and they leave a beautiful cut - I don't even wrap the lines before cutting any more. https://www.mishimoto.com/an-line-cu...oaAt9VEALw_wcB Last edited by Willshook; Today at 11:25 AM. |
#16 |
Willshook good call on the lube. I use it on the threads and on the outside of the braded line where the nut goes over it. There is a lot of drag there when you tighten it all up. Also, the aluminum vise jaws do help a lot along with the tools. But not necessarily needed. If marring up the fittings does not matter, then you can get by without them. Here is a video showing how to do it kind of rough but good technic except for no lube. https://www.bing.com/videos/rivervie...27&FORM=VRDGAR
And when ordering separate fittings be sure they are ptfe fittings. They look alike but are different and don't work. And I too use a cut off wheel on a grinder. |
#17 | |
![]() Join Date: Jul 2000
Just found this: https://www.onallcylinders.com/2021/...-your-vehicle/ I recently installed a new carb and think I used 30R7. Guess I'll have to see how well it holds up, and possibly replace with 30R9. Also read about Gates Barricade fuel hose -- almost $10/ft at O-Reilly Auto Parts (!), but $1.75 at RockAuto.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#18 |
![]() Join Date: Nov 2013
The teflon is a little more expensive but you never have to worry about reaction to any type of fuel.
I used hard lines as much as possible and short sections of teflon lines to connect. I used steel lines down the frame and aluminum at the fuel rails. In the bottom left corner, you can see where the braided teflon lines come up from inside the frame rail to the pressure regulator.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
