Old 02-06-2025, 08:11 PM   #501
raggedjim
raggedjim's Avatar
Re: Previous owner '68
Originally Posted by zicc1835 View Post
that $hit works
It works for me! I love high dollar trucks, but people want to see trucks and cars they could actually afford.
raggedjim is offline   Reply With Quote
Old 02-07-2025, 10:10 AM   #502
loudchevy
loudchevy's Avatar
Great progress on the rust repairs!
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 02-07-2025, 10:44 AM   #503
raggedjim
raggedjim's Avatar
Thanks! Still have lots more to do. Bought more welding wire yesterday!
Old 02-17-2025, 06:42 PM   #504
raggedjim
raggedjim's Avatar
Still working at the cab, I knew it would be a challenge but I have time and patience.
The cowl was rotted out on both sides, so I patched it up. I know, i excel at mediocracy, but I am the future previous owner.
Old 02-17-2025, 06:43 PM   #505
raggedjim
raggedjim's Avatar
Firewall from the outside.
Old 02-17-2025, 06:47 PM   #506
raggedjim
raggedjim's Avatar
I can hear all the young turks shouting "Get a better cab!".
Nope, I shall wallow in this pit of rust and despair and will come out of the far side burnt, bruised, and victorious.
At least that is the plan.
Old 02-18-2025, 10:57 AM   #507
loudchevy
loudchevy's Avatar
If you have time and patience, you'll get it done!
Scott
2003 Tahoe Stock
Old 02-18-2025, 11:16 AM   #508
raggedjim
raggedjim's Avatar
Luckily I'm retired so I do have more time than some of you younger guys.
As far as patience, it comes and goes! I've quit this build 4 times, but restarted the next day!
Old 02-19-2025, 06:51 AM   #509
72 tigger
72 tigger's Avatar
I admire your persistence and work
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 02-19-2025, 09:32 AM   #510
raggedjim
raggedjim's Avatar
Thanks! It keeps me busy for sure.
Old 02-19-2025, 06:29 PM   #511
raggedjim
raggedjim's Avatar
Got the kick panel and a-pillar welded in.
Old 02-19-2025, 06:34 PM   #512
raggedjim
raggedjim's Avatar
Also welded up some rust spots on inner kick panel. I'm seriously thinking about deleting the vents, the repairs needed are above my ability and I never used the ones in my other trucks. Are there any guys out there that have done this and regretted it later?
Old 02-19-2025, 06:39 PM   #513
pjmoreland
pjmoreland's Avatar
Nice progress on the rust repairs. The only reason I like having a vent on my '68 is so I can leave it cracked open to allow somewhere for the pressure to escape when shutting the doors. I've considered adding a pressure relief valve in the door frame like the later trucks have.
pjmoreland is offline   Reply With Quote
Old 02-19-2025, 07:34 PM   #514
raggedjim
raggedjim's Avatar
I thought about that but I have to wonder how tight these trucks are. Heck, most of the cab corners are wide open that I have seen. I like the idea of having the vents but I'm really going to have to do some thinking to keep them. I actually thought about buying some of the 60-66 vents (which bolt in) and making them fit.
Old 02-19-2025, 09:07 PM   #515
68Gold/white
If theres a simpler/hopeful better vent solution, we'd all like to see that!!!
68Gold/white is offline   Reply With Quote
Old 02-20-2025, 10:10 AM   #516
raggedjim
raggedjim's Avatar
Well, I've been thinking about these. Now if I can get one of my 60-66 buddies to give me one for testing, since I have no idea what the size is on these.
Of course I'd get rid of the levers and go with a more 67-72 opening scheme but I think you could cut out the offending 67-72 vent and slide this one in???
Old 02-20-2025, 10:24 AM   #517
raggedjim
raggedjim's Avatar
Or one of these mounted high on the drivers side.
Old 02-20-2025, 06:34 PM   #518
raggedjim
raggedjim's Avatar
This is why I cut into the cab supports even when they look okay from the outside. Full of sand, dirt, and rust.
Old 02-20-2025, 06:35 PM   #519
raggedjim
raggedjim's Avatar
At least the b-pillar looks pretty good.
Old Yesterday, 07:29 PM   #520
raggedjim
raggedjim's Avatar
A-pillar also looked good but given all the crap I've pulled out of the rockers and other pillars I decided to cut it off. Good thing, it was stuffed.
Old Today, 10:07 AM   #521
loudchevy
loudchevy's Avatar
Wow, that is quite the dirt pile and furball you removed from the rockers!
Scott
2003 Tahoe Stock
Old Today, 10:35 AM   #522
raggedjim
raggedjim's Avatar
Actually it all came out of the a-pillar and b-pillar!
The rockers had their own pile.
Old Today, 01:21 PM   #523
zicc1835
zicc1835's Avatar
lots of progress since last looked
zicc1835 is offline   Reply With Quote
