2 Questions on CPP Disc brake Kit
I just put the CPP front disc brake kit on my truck. I had two questions. The kit came with a rubber gromet in the picture below. I am not sure what that was for and didn't see a place in the assemble to use it. Did anyone else get one of these in their kits and figured out what to do with it?
The other question is with the brake line hoses. They seem very long. I am wondering when the wheel is turned all the way towards the crossmember if they will kink. Anyone else have this issue with the CPP kits? Thanks, Rob |
Re: 2 Questions on CPP Disc brake Kit
I think they wedge those in the calipers to keep the piston from coming out of the bore during shipping. They're not used anywhere on the truck itself.
For the brake hose, I just twisted mine enough to add a loop to to take up the slack.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I used the same kit as well. I couldn't figure out the donut either, so left it out.
I did the same with brake line. Twisted and confirmed it wasn't rubbing. I did put one of those protective sleeves over the hose just to be sure it wouldn't rub through as quick if there was movement. Its the kind of sleeve that is a series of tight coils. Ultimately, I want to order shorter houses. |
#4 | |
Rob |
I Installed the Right Stuff front power disc brake conversion on my 65 C10. Can someone recommend a pre bent line kit that they have actually used. So far I have tried Right Stuff, CPP and Inline Tube. They all have fitment issues. Right now, I am not interested in making my own lines but that may change. I don't mind paying for something that actually fits and looks good.Thanks, Hairball
![]() Join Date: Sep 2006
You should be able to use mid 70's brake lines. I didn't use CPP's brake conversion. I used mid 70's spindles and ball joints along with the brake lines. I tired to just post a picture but couldn't so here is the whole thread. Picture is in the first post. http://67-72chevytrucks.com/vboard/s...d.php?t=727826 I think your hose is the same length as the mid 70's. It might be the location of your hard line that is doing it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; Today at 11:17 AM. |
#7 | |
Rob |
#8 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
71-72 they were on a tab on the front side of the crossmember. 73-87 ran the hose all the way to the frame rail. Also on the front side.
