Old 02-22-2025, 09:26 PM   #26
IT Cowboy
IT Cowboy's Avatar
Re: Another sniper question - which kit / config
I found a mechanic that knows his carbs and older vehicles and he says the throttle link bushing on my Quadrajet is worn out and probably causing a vacuum leak. I found a bushing kit from Cliffs for $75 plus the carb probably needs a rebuild kit. For the cost, time and expense I an considering throwing on a Holly 1406. Any thoughts or virtual beatings to be had.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-22-2025, 11:49 PM   #27
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
If you think you can do the reaming of the throttle plate and installation of the throttle pate bushings, good on you. I had those done by a local shop, since I didn't want to buy Cliff's kit for a one-time job. Rebuilding a Q-Jet is dead simple. Buy Cliff's book; there are things you will learn that will stand you in good stead. I didn't make any modifications that Cliff shows in his book, as my carb is dead stock on a dead stock engine. I did end up putting on an electric choke, though. Checking that there is a vacuum leak at the throttle shaft is easy- just squirt carb cleaner at the primary throttle shaft on both sides- left and right. If the rpm changes, the baseplate is worn and needs the bushings. The secondary throttle shaft does not need bushings, btw.
ETA- you engine will run great with the new carb, because it is new. But it won't actually be calibrated like the general's engineers spent many sleepless nights making sure the settings were correct.
~Steven
Simi Valley, CA
Old 02-23-2025, 05:34 PM   #28
guyryan100
guyryan100's Avatar
As a fellow IT pro, I'll share what I decided about carbs/EFI kits - hope it helps.
An EFI system is definitely an upgrade. Having computer control and an oxygen sensor in the exhaust gives EFI capabiliites a carb just wont have, and its fun to integrate newer tech into old tech.
But I think its a step 2. Don't skip step 1 of understanding how your cab works including basic tuning.
Remember when you learned to drive a manual transmission, and it put you into an elite club of auto enthusiasts who knew this advanced capability? Tuning a cab puts you in an elite group of classic car enthusiasts. And once you replace your carb with EFI, that opportunity is lost.
EFI is an expensive upgrade that will provide some benefit but on the list of upgrades there are many that have a larger benefit both for improving drivability/reliability and learning.
Before I put in an EFI I would consider (in no particular order):
* Power brakes
* Power steering
* LED lights (inside and out)
* Relays for headlights
* Upgraded stereo
* overdrive transmission
* fix leaks
* sway bar
Im still working through that list and hope to do EFI after I get these items done, that in my view have a faster return on the time and money invested. And some of them are techy :-)
Owning a truck our grandparents designed means learning to master the tech they perfected. Carbs are easy enough to learn and get you into that exclusive club everyone wants to be in of elite classic car enthusiasts.
guyryan100 is offline   Reply With Quote
Old 02-23-2025, 06:25 PM   #29
MikeB
MikeB's Avatar
Originally Posted by Steeveedee View Post
I'd pay GM engineers by buying a vehicle with the stuff already trouble shot.../old man
I've heard the Chev TPI system works very well. Had a friend with a mid-80s Corvette and he loved it.
But I'm not sure where you could find one these days, or what it would take to retrofit the system to an older truck.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-24-2025, 03:03 PM   #30
IT Cowboy
IT Cowboy's Avatar
I think the Sniper efi will work with either a spread bore or a square bore intake using an adaptor plate - can anyone confirm this?
Old 02-24-2025, 04:11 PM   #31
MikeB
MikeB's Avatar
Did you get a price from Cliff Ruggles for rebuilding your carb? There sure is lots of Q-jet love from the guys who have them.
As for the Edelbrock 1406, you should be looking at the newer 650cfm AVS2 #1906 instead. The differences are the annular boosters which are great for throttle response, and adjustable air valve secondaries. It's doubtful you'll even need to tune it, except for idle mixture and choke adjustments.
As for a Holley, I'd go with an 80457SA (single inlet) or 80458SA (dual inlet). Either might need a bit of fine tuning, though. They are both on sale now.
Mike
Old 02-24-2025, 05:34 PM   #32
RunsWithScissors
I can confirm. I bought the Sniper2 squarebore and running it on a SBC400 with a spreadbore intake. Tuning is dead simple, basically learns everything itself.
HOWEVER, I wish I had bought the speadbore. I miss the Quadrajet sound.
RunsWithScissors is offline   Reply With Quote
Old 02-24-2025, 05:41 PM   #33
IT Cowboy
IT Cowboy's Avatar
Did you need an adaptor plate or just a spacer or thicker gasket? Also do you have a TH400 trans and need to do anything with the kick down switch or porgramming? The Sniper Quadrajet is only a Gen 1 though and not the same programming and tech as the 2
Old 02-25-2025, 02:46 PM   #34
SCOTI
SCOTI's Avatar
Originally Posted by LS short box View Post
If you decide to stay carbed there is a guy over on corvetteforum.com that rebuilds QJ carbs. He gets great reviews.
Also over LS1tech.com there is a guy that goes by AndrewB. He can remote tune the Holley EFI stuff. He also has good reviews.
AndrewB is an educated, top notch tuner for Holley's Terminator, Dominator, & HP EFI systems.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
