#526 |
This is not what I was hoping to find in the box.
I returned it. EFI upgrade on hold. |
#527 |
![]() Join Date: Mar 2021
Re: '72 Cheyenne K10
That sux ^^^^ it almost looks used ........
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#528 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
That sucks.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#529 |
Putting my old truck to work today. Picked up materials to redo the deck on the back of my house. 24 16ft Trex boards on the rack - no problem!
#530 |
Took a trip out to the Thompson Fire area the other day to help a buddy recover some items from his RV. Good excuse to drive the 4x4.
#531 |
Hopefully his stuff survived. Nice to see you post.
#532 |
Thats the way I like to see them
#533 |
Today I started a project that has been on my list for a little while - electric fans. The engine temp always stays cool while driving, but it gets warm in the summer sitting at idle for any length of time. This should fix that.
Cost for everything was about $600 with coupons, so this is not a cheap upgrade. Parts: - Maradyne Jetstreme 2 (MJS26K) dual electric fans - Maradyne 185° fan controller wiring harness (MFA102) - Jegs Jetstreme mounting brackets (555-52117) - Vintage Air trinary switch (11086-VUS) - Tuff Stuff 100amp alternator (7127D12) As you can see in the photo below, the previous owner cut the bottom half of the shroud off to make clearance for the body lift. And yes, I know a new shroud might have solved the problem. |
#534 |
landarts
![]() Join Date: May 2005
That will be a good upgrade. Love the way your truck turned out.
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
#535 |
I got the fans installed today and started on the wiring. It took two sets of brackets - I cut the end off of one set and used them as spacers so that the shroud would fit properly against the radiator. The bottom brackets just sit on top of the frame. I might drill and attach them to the bottom of the core support, but it seems really secure as is. The top of the fans are attached with 1/4-20 clip nuts to the top radiator brackets.
There's a stupid amount of room between the engine and radiator now. I like it. |
#536 |
![]() Join Date: Apr 2008
Looks nice!
71 C10 72 K20 72 K10 Super Kirk |
#537 |
I finished up the fan wiring, but the fans didn't kick on when I tested it. I discovered the inline fuse for the fan relay was blown, so I replaced the fuse and the fans came on. I am letting the engine cool off a little then I will test it again.
The alternator that I ordered was not in stock, so I am still waiting on that. And like I said yesterday, the space between the engine and radiator is huge. |
#538 |
It immediately blew another fuse.
After researching, I found in fine print on page 13 of a Maradyne sales brochure that the Jetstreme 2 (dual fan) requires a dual fan adapter harness (MFA111). It's a second relay for the second fan. I'll get that ordered and report back here when I have a chance to get it installed. Last edited by jimbosprint; 11-24-2024 at 07:05 PM. |
#539 |
Today I installed the second fan relay. Credit goes to Maradyne for making it easy to connect to the first relay. Now both fans kick on without blowing fuses when I ground the sensor wire. I also swapped the thermostat housing with an adjustable one to make a little clearance for the sensor.
The new 100amp alternator is here, and I ordered a new alternator bracket which shipped today. I'll put a fresh belt on too. |
#540 |
I may have opened a can of worms.
![]() Moving the upper radiator hose caused a leak. So it is off to the radiator shop. And the Ebay seller made a label but didn't ship my alternator bracket. Probably didn't even have the part. |
#541 |
Ace Radiator here in town was fast to fix my radiator! $79 is a lot better than a new radiator.
It's all back together with a new lower radiator hose. I also used up the old can of engine degreaser that I had in my shed. Still waiting on Ebay alternator bracket. |
#542 |
It is super frustrating that this factory alternator bracket does not adjust correctly. With the new alternator the belt is super loose adjusted all the way to the end of the bracket. I don't understand why at all, and I was mocked on Facebook for asking the question.
UPS finally has the Ebay bracket I ordered. Saying Monday. |
#543 |
The Ebay alternator bracket showed up today, but the tension rod is too long to attach to the bracket bolt and too short to reach the intake. I ordered a shorter tension rod from Amazon that should arrive tomorrow.
Changing the alternator is turning out to be more of a challenge than the electric fans. ![]() |
#544 |
It works!
![]() The shorter tension rod is still almost too long, but it works. I think the bracket is ugly, but it works. The fans kick on and off as necessary, the engine stays cool, and the battery charges. And I got some cheap floormats. |
#545 |
landarts
Hey Jim, just wondering if you ever got around to installing the Sniper EFI?
#546 |
No, I returned the Sniper EFI.
#547 |
I built a K10 out of Lego!
![]() I am extremely happy with how it turned out, but there are still a couple things the C10 guys will notice. The wheelbase is one brick longer than I would like for it to be a short bed, and the bed is two bricks short of being a long bed. Changing to either causes a domino of compromises and reengineering. Maybe I will make a larger scale model that is better. Features: - 1/15 scale (12.5" x 5.5" x 5.5") - Working steering - Doors open - Detailed interior - Tailgate opens - Hood opens - V8 engine - Radiator - AC evaporator case - Driveline - Exhaust pipes - Disc brake rotors - Printed 80 page 8.5"x5.5" instruction book |
#548 |
nice! ill have to check that kit out! hope it comes in med olive green
-------------- 1970 C/10 LWB build thread: https://67-72chevytrucks.com/vboard/...d.php?t=847860 IG- Tip70 https://www.etsy.com/shop/Tip70Designs |
#549 | |
#550 |
Really nice day for a drive in the old K10.
Tags |
ochre |
