Old 02-21-2025, 07:55 PM   #5201
zicc1835
zicc1835's Avatar
Re: What did you do to your truck today.The 3rd chapter
I bought this highlander/dark saddle skin for another project in 2018 and changed my mind on the color scheme on my Doc & Kim build which is under construction... then I recently found and purchased. my Grand Theft Auto dark blue stepper . I also bought over time from members on the board dark saddle OEM safety belts visors arm rests etc. this was meant to be .....I guess ...so I had a seat I was saving for Doc and Kim purchased new foam from LMC last week my upholstery guy gave the foam a thumbs up and here we
are...stay tuned ill try to do the switcharooo this weekend
zicc1835 is offline   Reply With Quote
Old 02-21-2025, 11:11 PM   #5202
SRU1436
Put a tach in the truck.
SRU1436 is offline   Reply With Quote
Old 02-23-2025, 02:08 AM   #5203
'68OrangeSunshine
'68OrangeSunshine's Avatar
Last night I went out to the supermarket for groceries. The 292 L6 in my '68 C/10 started right up, and the engine was fine on the three mile run. After I got out of the store, it wouldn't start.
Gas gauge read 1/4 tank. Not empty, but I added the 5 gallons from the jerry can in the back, in case it was a fuel problem.
No start.
So I opened the hood and pulled off the HEI Distributor cap. [I was going to change out the Module in case it was burned out.] Aha! the Rotor was loose. Both screws had backed off and it was at a slight tilt. So I screwed the Rotor back on proper and tried again.
No start.
OK, I'd better try that glovebox Module. Meanwhile, searching in the crossbed toolbox, I found a NIB Rotor and an old Distributor cap. The old cap was worse than the new one.
I put the emergency Module in -- I didn't have any fresh White Heat Sink Paste, but there was a prodigeous amount under the bad module, so I put it in dry. The new Rotor went in, then the cap, and I reconnected the Plug lead back onto Sparkplug #1.
It did start, then sputtered and died.
I was unable to get the engine to keep running. Just a few seconds on it sputtered out, dead. Choke had no effect.
So I called a Tow truck. And we got it home after a couple of hours.
Distributor is the Remote Coil type.
The bad Module tested Bad at AutoZone. Got a new one under a Lifetime Warranty.
The Rotor had a Life Warranty at O'Reilly's, so I have a Cap and Rotor on order from them. The counter woman at O'Reilly's said they couldn't test the Module there. They'd taken away the test machine, she said.
[She lied. it's still there.]
Old 02-23-2025, 02:54 AM   #5204
pjmoreland
pjmoreland's Avatar
No start.
No start.
You had quite an evening. I'll bet you're glad this happened in the stepside instead of the Jimmy. I envy the easy access to the distributor.
pjmoreland is offline   Reply With Quote
Old 02-23-2025, 02:02 PM   #5205
zicc1835
zicc1835's Avatar
installed.....
Old 02-23-2025, 05:28 PM   #5206
67C10Step
67C10Step's Avatar
Took advantage of a nice, sunny day to touch up the wood in my bed. I finished this about four years ago but over that time the pine has cracked a bit and was starting to look a little rough.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 02-23-2025, 05:39 PM   #5207
brandnew72
That bench seats looks very cool!
Thsu weekend was a success! Front bagged! Chopping Block control arms were a breeze to put in. No binding, tires sitting on fenders until the right rims are ordered...
Just had to adjust toe after install. Removed front inner fenders and got the shock relocators mounted. Drives nice! Waiting on panhard bar jamb nuts to adjust that. And fixed a small leak in the air tank as well.
brandnew72 is offline   Reply With Quote
Old 02-23-2025, 05:53 PM   #5208
'68OrangeSunshine
Originally Posted by zicc1835 View Post
installed.....
That is a nice seat. Suddenly I'm hungry for Blueberry Pancakes. Don't know why.
Old 02-23-2025, 06:04 PM   #5209
'68OrangeSunshine
Yeah The L6 has the Distributor in a good place.
Good news is I got her running.
Loose Rotor chewed up the inside Cap contacts. Irregular pulses burned out the Module.
Autozone warrantied me a Module. ORAP warrantied me fresh Rotor. Had to buy a new Cap. [Old one off eBay],
Pulled the Crank around to TDC w/5/8'' socket on breaker bar so Lines on HB matched O mark and Rotor pointed to #1 plugwire.
Reinstalled the whole business, hooked up the Batt and she fired right up.
Old 02-23-2025, 10:40 PM   #5210
Johnl48
Temporarily put the front bumper on
Johnl48 is online now   Reply With Quote
Old Yesterday, 09:56 PM   #5211
zicc1835
zicc1835's Avatar
looking good ...you have a part # or vendor you bought the fuel door from you could share with me
Old Yesterday, 10:00 PM   #5212
zicc1835
zicc1835's Avatar
John we are not so distant neighbors hope to see you at the Hot Rod Farm or any of the other shows etc.in NJ goor lookin truck you are building is there a build thread?
Old Yesterday, 10:02 PM   #5213
zicc1835
zicc1835's Avatar
TASTY love it ....
Old Yesterday, 10:17 PM   #5214
Orange Crate
Orange Crate's Avatar
Fixed it.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old Yesterday, 10:18 PM   #5215
Johnl48
No, I haven't done a build thread yet. Trying hard to get it done for the summer shows. Here's a before picture
Old Yesterday, 10:21 PM   #5216
zicc1835
zicc1835's Avatar
amazing .....there are some great inspirational builds here good luck on getting that beauty ready lets try to stay in touch this season
Old Yesterday, 10:57 PM   #5217
KQQL IT
At the body shop.
KQQL IT's Avatar
Spent a day and a half fighting with a friends 454 that wouldn't run.
Pumped 12 gallons of water contaminated gas out. Swapped a carb re verified timing and a quick temporary fuel supply... and som b it ran fine.
Finally tried to get the pv4 proportioning valve installed on old blue... and boxed wrong.
I love old trucks
I love old trucks...
Old Today, 10:19 AM   #5218
67C10Step
67C10Step's Avatar
Thank you! It's not as orange as the photo appears, the stain color is gun stock and toned down a bit when dry.
The fuel filler is a Boyd's Universal Flush Mount Kit. I got it when I installed the Boyd's tank in the rear. Can be found at the link below:
https://fueltankparts.com/products/b...floor-fill-kit
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old Today, 12:42 PM   #5219
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
That seat is beautiful.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
