#51 |
Re: 1970 Jiffy Mount Tire C10 build
-------------- 1970 C/10 LWB build thread: https://67-72chevytrucks.com/vboard/...d.php?t=847860 IG- Tip70 https://www.etsy.com/shop/Tip70Designs |
#52 |
![]() Join Date: Oct 2012
I love these decals! Looking forward to seeing the interior door panels finished.
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#53 | |
#54 |
Here are some progress pics of the door panels. They are going together good, just need to figure out some spacing on the door and panel with the handles and also how to mount the pull strap, because the bracket is a bit bulky than I was hoping.
#55 |
Those door panels are looking sweet
#56 |
thanks man! they are coming together
#57 |
I like those panels!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
#58 |
#59 |
Started mocking up the raised bed floor. I was able to pick up some wheel hubs and some wood. Earlier last year I got a good deal on some metal bed strips as well. All Im missing is some square tubing to start building my frame.
In the future, I will C notch the frame. So I left the original hubs in and have the new ones in place. This will give the look Im looking for and also be ready later. You'll have to stick around and see if this turns out how I planning ![]()
#60 |
I was able to figure out a good mounting spot for the handle pull and have the panels installed. Now seeing the shot from the inside, I'm thinking I may have to make some kick panels
Tags |
1970 |
