Old 02-23-2025, 05:29 PM   #1
awryexperiment
Antenna Ground Ring
Hi Fellows,
I am wondering if anyone has run across a similar problem where their antenna has developed a wiggle.
My 72 C20 has a fixed mast antenna located in the factory hole (right side of the wiper cowl near the pass door). I removed the cowl and found there's a rectangular soft metal "ground ring" under the sheet metal as part of the mounting bracket.
The problem is that my ground ring developed a crack so it cannot keep the antenna mounted rigidly to the cowl. I haven't been able to find this part reproduced separately, so I would need to buy a whole new antenna kit.
Has anyone had a similar problem? Was there any way to fix the problem without replacing he entire antenna?
thanks.
awryexperiment is offline   Reply With Quote
Old 02-23-2025, 06:33 PM   #2
mr48chev
mr48chev's Avatar
Re: Antenna Ground Ring
This is where photos could help a lot. Not only of the inside and the ring but the outside so those in the know can tell if it is a "Genuine GM" factory style antenna or aftermarket.
I haven't had an issue on my 71 and am sure I have the original antenna but on some other rigs have had problems where someone replaced a broken original antenna with an aftermarket antenna that almost fit but almost close enough only counts in horseshoes and hand gernades.
My ongoing truck projects:
Old 02-23-2025, 07:27 PM   #3
awryexperiment
Thanks, I'll grab a few photos. I'm almost certain its not the factory antenna, but a period replacement.
Old Yesterday, 09:27 PM   #4
Richard
Going to be hard to recommend a fix on an old aftermarket part that may not be common. Maybe with pics? Here are two replacements that are original reproductions. I have the fixed mast one and it is just like an original. Have talked to others that have used the telescopic version and they said the same.
Fixed mast https://classicparts.com/1967-72-ant...tationary-mast
Telescopic mast https://classicparts.com/1967-72-antenna-telescopic
Unfortunately the price has almost doubled since mine was purchased.
Richard
