Old 02-10-2025, 08:56 AM   #1
1project2many
Heavy Duty Front Brakes
I'm working on a project to recreate the "heavy duty front brakes" option available for '67-'71 1/2 ton trucks. I'm using parts from a few different models. So far I've collected NOS front drums from a '67-'71 3/4 ton G van; backing plates, wheel cylinders, and hardware from a '59-'64 full size car, and NOS hubs from a '63 1/2 ton as these are six lug and use tapered wheel bearings. I've also collected a few different sets of shoes since aftermarket information is a bit muddy. If this works it will give 11" X 2.75" brakes vs OE 11" X 2.00" brakes.
The goal is to assemble the parts to see how they fit together before disassembling the truck. Does anyone have a stock spindle they would be willing to part with for a reasonable price? Or does anyone know of a source for a reasonably priced spindle? '55 - '59 definitely work, but GM parts books show the same forging number from '47 - '59 although they have a different part number before 1950.
Thanks,
Last edited by 1project2many; 02-11-2025 at 09:20 AM. Reason: Edited years HD brake option was available.
1project2many is offline   Reply With Quote
Old 02-10-2025, 05:48 PM   #2
mr48chev
mr48chev's Avatar
Re: Heavy Duty Front Brakes
I see no mention of "heavy duty brake option in the GM heritage center archives.
Three years of GM heritage center archive brake info does not show any option on brakes for 3100 trucks> I am just curious as to where you got the info on Heavy duty brake options for a TF 3100.
My ongoing truck projects:
Old 02-10-2025, 09:47 PM   #3
1project2many
There's a listing in the old parts books for front backing plates for 55-59 1/2 ton trucks with heavy duty brakes. I haven't found anything in sales literature about it though.
I'm happy to post a link to the parts listing tomorrow.
Old 02-11-2025, 09:55 AM   #4
1project2many
This has been a while in the making. I had to go back to my notes. The HD brake option was actually for 67-70 2WD trucks.
I started with Raybestos 2058 which is listed as fitting 55-58 trucks.
https://www.raybestos.com/brake-drum-2058.html
This is a six lug finned drum, 3" deep, which does not match the TF truck drum so I was curious. After some searching I found GM 3964550, listed for 67-79 C10 w/ HD brakes and 70 G20.
http://www.gmpartswiki.com/getpage?pageid=221001
Working from that listing I find backing plates 3957193 and 3957194, also for the early '70s G20 and C10, with note "field fix only to convert 1/2 ton truck front brks to 3/4 ton."
After that it's a matter of piecing parts information together. There's conflict because some sets of shoes listed for HD brakes are sized at 11-5/32" X 2.75" and others are listed at 11" X 2.75" but the drum max diameter is 11.09" so it's definitely not made for an 11.156" shoe. Passenger cars after '58 also used 11" X 2.75" front brakes and folks older than I have installed passenger car hubs and drums onto TF trucks. I'm planning to stay with six lug wheels but the backing plates and hardware are still usable. The '63 truck hubs are just to satisfy my own curiousity to see if the later hubs with tapered rollers will fit onto the older spindles.
If you happen to know of a source for a reasonably priced spindle, I'd be grateful. There's a rusty pair on Ebay for $125. I'm not sure if that's a fair price but I'm hoping to spend less.
Old 02-11-2025, 07:43 PM   #5
mr48chev
mr48chev's Avatar
I don't know of any spindles. Back in the day when my buddy who passed away a couple of weeks ago was subframing TF trucks on a regular basis he usually had a couple of axles in the scrap pile before hauled it off to the scrap yard. I raided that pile more than once for pieces. He would raid my pile for pieces too so it evened out.
Old 02-21-2025, 10:56 AM   #6
1project2many
Thanks for the reply. Yeah, I'm having the same trouble here. Most of the old hotrodders I knew have passed away or gotten rid of their spare parts pile. There's fewer junkyards around and most focus on new cars. Something will come up, or I'll just use the spindle on the truck once the weather warms up.
Old 02-21-2025, 11:36 PM   #7
mr48chev
mr48chev's Avatar
You might want to hit Sid at Dropped Axle up for a spindle. He isn't dropping axles on a regular basis as he is only doing a batch every once in a while to take to a swap meet but he is selling parts he has left on the shelf.
https://droppedaxles.com/
Old Today, 10:13 AM   #8
1project2many
Thanks mr48. I'll see what's available at Sid's.
