Old 02-18-2025, 07:57 PM   #201
pjmoreland
pjmoreland's Avatar
Re: 72 C10 for my 25th wedding anniversary
Nice work getting that turn signal switch replaced without cutting the wires.
They made two versions of the turn signal lever. The other version was for tilt columns and it had less of a bend to it. I installed one on my truck to get more clearance between the lever and the steering wheel. It ended up increasing the space by a little over an inch. I posted some photos of it in post #10 of this thread:
https://67-72chevytrucks.com/vboard/....php?p=9259098
The straighter tilt version can be purchased here:
https://classicparts.com/1967-72-tur...l-lever-w-tilt
pjmoreland is online now   Reply With Quote
Old 02-19-2025, 01:04 PM   #202
sfont66
sfont66's Avatar
That’s great info! Exactly what I needed.
Thanks for sharing, and providing the link to the correct part.
I never knew what the difference was between the tilt and non tilt levers.
I haven’t received the turn signal parts yet, hopefully they will arrive today. I was able to disassemble the column enough to get the wires out intact, so I should be able to reassemble just the same.
I will have to check out the lever I ordered, I may reconsider heating and bending it if it will ruin the chrome . It also cost more than the one from Classic Parts, so returning it may be the best option.
It’s nice to know that the tilt lever provides better clearance without having to modify anything.
Thanks again for the info!
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, FAST 102/102, FIC injectors,BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 02-19-2025, 09:04 PM   #203
sfont66
sfont66's Avatar
Some off the parts I have ordered have arrived.
Comparing the original parts to the new, the original non tilt turn signal lever above the replacement. The bend looks very close as expected, I may return it though, and get the one for a tilt column thanks to info shared by pjmoreland.
The red hazard on the turn signal switch does not match the color of the original.
The original is a brighter red, while the replacement is duller, almost maroon.
Not a huge deal, because my truck is far from original, but if it was going in a restored truck, or a nice original survivor I would be disappointed. Especially since it’s advertised as the “ correct original red hazard knob”
More in a bit….
Old 02-19-2025, 10:37 PM   #204
sfont66
sfont66's Avatar
I had a little time to start putting the turn signal switch back into the column.
The switch harness came with the connector depinned. I guess in some cases it would be helpful, and aid in chasing the wires through the column and dash, but in my case since I pulled the old one out with the connector, I decided to push the wires into the connector and install the switch the way it came out.
Old 02-20-2025, 03:50 PM   #205
sfont66
sfont66's Avatar
Had a chance to finish up with the turn signal switch wires , getting them run along the bottom of the column and wires tucked back under the dash. Not difficult, I just don’t fit very well between the pedals and the seat laying on my back anymore.Then trying to see what I’m doing while tucking the wires back into place.
But in all not too bad.
I decided to bend the lever almost straight to gain clearance.I don’t think it was stressed too bad. I did it without heating it up. I just put the flat end in the vice and pulled on it slowly by hand until it was where it needed to be. If it ever fails, I will buy the non tilt lever.
Old 02-20-2025, 04:00 PM   #206
sfont66
sfont66's Avatar
Few more, all finished up
Old 02-20-2025, 04:39 PM   #207
pjmoreland
pjmoreland's Avatar
Nice, and straightforward solution. It's great that the chrome didn't crack.
Old 02-20-2025, 10:21 PM   #208
sfont66
sfont66's Avatar
I think it turned out Ok, everything works as it should. If the replacement lever fails in any way, it will give me a reason to change out the steering wheel to something different, and then go to a tilt lever.
Again thanks for the info and the link
Old 02-20-2025, 10:40 PM   #209
sfont66
sfont66's Avatar
The 3” exhaust tube and some bends have been delivered, so I can finish the rest of the exhaust. Same route as current exhaust, just increasing from 2.5” to 3”
The old throttle cable is just a little too short, so I had to get another one of those as well.
More to come….
Old 02-20-2025, 11:02 PM   #210
sfont66
sfont66's Avatar
My new injectors from Fuel injector clinic arrived. When talking with them they recommended the 525cc LS2 injector. I also needed adapters to convert from the EV1 connector on the Holley terminator harness to the EV6 connector on the new LS2 injectors. I’m not sure I like the adapters they sent, they are long and a bit bulky, not sure how they will look. So I ordered a different type from Michigan Motorsports, they are more compact and provide another option.
Tomorrow I hope to figure out brackets to mount my old fuel rails to the FAST Intake. I know the rails will fit, but I’m pretty sure the existing brackets will not work…..
Old Yesterday, 09:30 PM   #211
sfont66
sfont66's Avatar
As mentioned, the Summit Racing fuel rails for Ls1/Ls6 fit the FAST 102 cathedral port manifold…… but the brackets do not. It’s possible that there are aftermarket brackets that would work, but I could not find any.
I made 4 brackets from pieces of steel (angle iron) cut 1” wide with 5/8” legs.
Each bracket is slightly different than the other depending on the side it is used and front to back.
Because of the way the mounting holes are drilled in the rail the bolts for the rails are very close to the bolts to attach the bracket to the manifold.
The nut’s needed one side to be ground down flat. I then soldered them to the bracket.
Old Yesterday, 10:10 PM   #212
sfont66
sfont66's Avatar
One set of holes on the rails puts the bolts for the rails and the bolts to mount the brackets to the manifold even closer, this required a stand-off with the side ground flat, and the nut ground a bit for clearance.
In the end it would have been easier to just sell the Ls 6 Fuel rails and Buy the correct Holley or FAST fuel rails. That could have taken a while,(I’m still trying to sell some nearly new injectors)I also don’t have the money for new rails at the moment, and need to finish a bunch of stuff before spring. So this will have to do for now.
Next I need to modify the Ls6 throttle cable bracket slightly, and install the new longer throttle cable.
Then some exhaust work.
Old Today, 12:11 AM   #213
Tip70
Tip70's Avatar
those brackets look great! Nice work!
1970 C/10 LWB
build thread:
https://67-72chevytrucks.com/vboard/...d.php?t=847860
IG- Tip70
https://www.etsy.com/shop/Tip70Designs
Tip70 is offline   Reply With Quote
Old Today, 10:34 AM   #214
sfont66
sfont66's Avatar
I do like the look of the Billet brackets on the Fast Fuel rails,so simple and clean looking, but at $250+ I have to delay that purchase for a while and use what I have.
It’s a balance of time Vs money. If it was already summer, and I was busy with work and other projects around the house, I likely would have just purchased the FAST fuel rails that fit and look great. This would then save me some time, allowing me to move on to other things.
