Old Yesterday, 10:29 PM   #1
Getter-Done
Getter-Done's Avatar
Help Decoding Exhaust Manifolds.
If I remember correctly,
Someone on the forum has a Book that covers the Castings numbers on Intake and Exhaust manifolds.
I used my Normal searches and some of Same Cast # manifolds that I found on E bay looks different.
I think it has something to do with the LH 24 & RH 6 under the casting #.
So Here is my Question.
Does anyone know what this Pair of Exhaust Manifolds came off of?
Left manifold has a casting # of 3832473 with LH 24 under it.
Right Manifold has a casting # of 3838956 with a RH 6 under it.
Thanks in advance for the help.
My guess is a 69/70 307cid.?
The early bird gets the worm,
84 Chevy K-20
Old Today, 02:02 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Help Decoding Exhaust Manifolds.
Top one is 3932473 which is a LH 1969-70 2WD. The LH 24 refers to the side and which mold it was cast in. K series 4WD trucks use a RH straight dump manifold 3932465 on both sides.
3838956 does not exist. However, 3896956 is a '67-'70 RH manifold for 2WD 307, 327, 350 W/O A.I.R.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old Today, 03:42 PM   #3
Getter-Done
So the second number is a 9.
That makes sense.
Thank You so much.
84 Chevy K-20
