Old 02-26-2025, 09:57 AM   #1
1969stepside
1969stepside's Avatar
stepside fender gaskets?
are there any gaskets or anything that i put between the bedsides and the stepside fenders? should i make some or do they just bolt directly to the side of the bed without anything? i ask this because the lip is where the stepside fender rusts out
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 02-26-2025, 10:02 AM   #2
raggedjim
raggedjim's Avatar
Re: stepside fender gaskets?
They came factory with a strip caulk. 3M makes a black strip caulk that works well.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 02-26-2025, 10:16 AM   #3
dagnabbitt
dagnabbitt's Avatar
Earlier models - till 59 I think - used welting. I plan to use it on my 70 when I restore it, seems less messy and probably more forgiving for a klutz like me.
https://www.mar-k.com/partDetails.aspx?LID=13277
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 02-26-2025, 12:03 PM   #4
pjmoreland
pjmoreland's Avatar
Good luck, Rg
That's what I used on my truck, as well.
https://www.amazon.com/gp/aw/d/B000P...b_b_asin_title
pjmoreland is offline   Reply With Quote
Old 02-26-2025, 05:33 PM   #5
72c20customcamper
72c20customcamper's Avatar
Strip caulk the 3m black is what I used too . Hint to apply it is to let it sit in the sun to soften it . It will then flatten out much easier and also easier to use a plastic scraper to remove excess.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-27-2025, 09:02 AM   #6
1969stepside
i have the fender welt but some people told me it would cause rust or something idk seems that the 3m is what most people are going with
Members i Have met
Earl Slick68
Old 02-27-2025, 09:23 AM   #7
A1971Blazer
A1971Blazer's Avatar
Most all the panels and assemblies from the factory were bare metal.
They used caulk and seam sealer to mitigate moisture intrusion. How well that worked? not so much over time.
You see a lot of corrosion above the upper windshield header both inside and outside because the sealer in the drip rail degrades and falls out over the course of time, and most people don't bother to repair it.
As far as the stepside fenders are concerned, the factory assembly manual specifies "plastic seam cement".
I assume the beds were assembled and then painted afterwards.
When I restored the bed on mine, I painted both the side panel and fender before assembly. I'm hoping that will help prevent corrosion between the two over time.
I do keep it in the garage, and I don't drive it in the rain if I can help it, but I do wash it regularly.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-04-2025, 01:29 PM   #8
1969stepside
mine will live in the garage as well the step fenders are oem so i am trying my best to keep them as long as i can cause new ones are so expensive
Members i Have met
Earl Slick68
