Old 11-21-2024, 02:31 PM   #51
pjmoreland
pjmoreland's Avatar
Re: Decals for 8000 RPM Tach and Vacuum
Originally Posted by 1967GMCC20 View Post
Are the repo tachs at Summit any good?
I haven't used one, but they're probably the same as the tachs all the other vendors sell.
pjmoreland is offline   Reply With Quote
Old 11-21-2024, 02:34 PM   #52
1967GMCC20
1967GMCC20's Avatar
I will check one at next time to Summit.
Maybe I can update Tach, Vac at same time.
1967GMCC20 is offline   Reply With Quote
Old 11-21-2024, 02:45 PM   #53
pjmoreland
pjmoreland's Avatar
If you are wanting to install tach and vac in a standard gauge cluster that didn't have them originally, then you will need the following additional components:
1) Front and back tins (the main metal housing pieces for the gauge cluster). Member 70shortfleet can modify your existing tins for you.
https://67-72chevytrucks.com/vboard/...d.php?t=792563
2) Lens - You can modify your existing lens with the decals I sell
3) Flexible circuit board
4) Tach wiring harness
Those last two items can likely be purchased from Summit, too.
Old Yesterday, 04:16 AM   #54
D-n-Tyke
Interested in one of the 8000 RPM templates if you still have one. Let me know how to get you payment
D-n-Tyke is offline   Reply With Quote
Old Yesterday, 10:37 AM   #55
pjmoreland
pjmoreland's Avatar
Sending PM
