Old 07-31-2020, 08:52 AM   #151
jjzepplin
jjzepplin's Avatar
Re: 72 2wd project "No Daggum Money"
I am going to use the factory F-body radiator and condenser/fan unit and modify my support to fit it all. I monkeyed around a bit yesterday and I think I have come up with a pretty good fit. My rad support is a 69/72 model and should be a 67-68 so I can experiment with this one and do final modification to the correct model when the time comes. I am going to try to use as much of the factory AC as well except the Sanden compressor will be utilized. The bracket for that is not cheap and with my Sanford and Son mentality, It is hard to plink down the duckets for such an extravagance. I guess the rest of it was cheap enough. Pics to come.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-14-2020, 01:22 PM   #152
slowcpe
slowcpe's Avatar
any updates? Curious to see how your transmission crossmember fits.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 09-15-2020, 05:50 PM   #153
jjzepplin
jjzepplin's Avatar
Sorry for the lag. I set the cross member up in the frame and set the trans on it and it fits pretty good without the spacer provided. I have not yet cut the holes in the frame as I was just so happy it fit. The trans is a little high and hits the tub tunnel towards the rear and right where the cover will be. I have seen where some have just cut this area but I am looking at possible shifter options because I really want the old Hurst Feel of a quarter stick but my current shifter is B-M and is solid with no way of bolting on my old stick. I thought I posted pics here but will get some soon. I also have been working on installing the Trans Am stock master cylinder and think I have come up with a solution and have it pumping dry right now but with a custom shaft to the cylinder I think it will be just fine. What a mutha to figure out the angles though. Nice part is that if it goes haywire down the road I can just go to the parts store and boom I'm back on the road. No special order Wilwood stuff. I just got a new job and I am deemed "Essential" so small back burner for this but I will snap some pics in the next couple days.
Old 01-02-2021, 11:44 AM   #154
jjzepplin
jjzepplin's Avatar
So I am a slacker but am getting ready to do some work. I know I know. Some pics of the crossmember. Not fully installed as I have to take it out and get it powder coated but still a GREAT buy and a GOOD fit! The exhaust may get changed out before I fire it up but the member leaves ample room for the duals.
Old 03-07-2021, 09:10 AM   #155
jjzepplin
jjzepplin's Avatar
Not much progress with my new job making me study micro organisms and highly complicated multi faceted algebraic problems. I did order a Tick remote bleeder kit with the one man type bleeder. I have not installed it yet, but it looks to be of good quality. I know I have to address the rusted rocker box in the pic but I was thinking that might be a retirement job. I just want to get out and drive this thing. It's been 14 years since I've driven it and that rust has not migrated much. It sits in a garage now though.
Old 03-30-2021, 07:54 AM   #156
jjzepplin
jjzepplin's Avatar
I installed the Tick bleeder system and would recommend it to anyone. It is long enough to fit right back in the clutch master so BAM! I don't even see this system making a mess at all when bleeding the clutch. I am still wrestling with spending any money on this project. This is probably the most I've spent in years. I have that LQ9 sitting in the corner and was thinking that when I sell my rental property I just might splurge and top the LQ9 with a MAGNUSSEN. Sleepy thread pending... That should cure my spending thriftiness.
Old 11-29-2022, 12:12 PM   #157
jjzepplin
jjzepplin's Avatar
Well I finally installed a proper Flip kit in the rear and am ready to order a driveshaft. I am thinking 3" aluminum. There's one on ebay by Coleman Racing for $380. Sure would save me some time.
Old 04-16-2023, 11:17 AM   #158
jjzepplin
jjzepplin's Avatar
Well my ebay flip kit was crap and the U bolts stripped at 130 lbs torque. Guess that's better than during a burnout. I was thinking of matching them up at the junk yard to some stock GM stuff or having some custom made. I guess not finishing this quickly may have saved me some injuries.
Old 02-07-2024, 07:16 AM   #159
jjzepplin
jjzepplin's Avatar
Alrighty. I am getting back on this and I need you all to get on me for updates. I think my torque wrench is broken or does not work upside down. I also went to the junk yard and cut a section from a 2007 Denali fuel tank to get the fuel pump mounting ring that I hope to graft to my existing poly tank. I found a fella on Ebay that will make stainless rings with bolt holes to sandwich it to my tank. I also picked up the pump from the Denali. I think it should work ok and seems like there is enough room under there. PIcs to come. If the Denali pump does not work, I will try a 2010 Camaro pump. Should plop right in. Stay tuned. HAHA
Old 02-20-2024, 03:43 AM   #160
jjzepplin
jjzepplin's Avatar
Here's what I have so far.Attachment 2338220
Old 02-23-2024, 12:33 AM   #161
LT7A
Whoa. You're back.
Old 02-23-2024, 06:32 AM   #162
jjzepplin
jjzepplin's Avatar
YES! I just have to get this thing running! I have the drawings back from the manufacturer for my Fuel pump mounting rings. Hopefully I can order them today. I guess it will be easy to clean the tank once I put a big hole in it for the pump. The old sending unit was literally a chunk of rust. When I put it in it was intact and working. Best I can figure is squirrels were up in there peeing on it or something. That is some rapid deterioration that I don't think I can blame on the new gas.
Old 02-25-2024, 07:08 AM   #163
jjzepplin
jjzepplin's Avatar
Also getting some work done on my Electronic Speedo. I sure hope it works with this Tremec trans.
Old 02-18-2025, 09:45 PM   #164
jjzepplin
jjzepplin's Avatar
So the fella on ebay ghosted me and I had to make my own stainless rings for the fuel tank. I am getting ready to try to install the ring on the tank. I think I have to put the heat gun on some of the irregularities before final installation. I also installed a Strange 1350 yoke on the 12 bolt as I had to replace the seal anyway. Figured I would upgrade a bit so I could get a mean driveshaft. Pics to come. I also see a small leak from the rear main seal. 150,000 miles so I guess this will be easy to replace. Can I just pop it in or do I have to realign all the crud? Still new to LS base engines.
Old 02-23-2025, 10:28 PM   #165
jjzepplin
jjzepplin's Avatar
So this is what I have for the fuel tank so far. I think the pump needs to go down further in the tank. The sealing rings are 1/8" Stainless Steel. The bolts to hold them together are Allen headed Stainless.
The pump is from a 2007 Denali and should put out 55-60 psi.
Old 03-02-2025, 01:18 AM   #166
jjzepplin
jjzepplin's Avatar
Does anyone think I need to set the pump lower in the tank? not sure how the fuel will get into that bucket on the bottom of the pump. I see some of them have a barb possibly for a corner to corner supply line inside the tank. Thoughts? Or should I just install it and see what happens. I think it sat at the bottom of the original tank.
Old 03-02-2025, 11:02 AM   #167
raggedjim
raggedjim's Avatar
It looks like there would be a pretty big gap from the bottom, I think I would try to get it closer to the bottom.
raggedjim is offline   Reply With Quote
Old 03-02-2025, 11:04 AM   #168
D.B
D.B's Avatar
I may be wrong in saying this. But I think you have three lines. You have a vent line, a line from the pump to engine or regulator and a return line. The return line goes back to the bucket to always keep fuel around the pump's pickup.
Darrell
1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck)
2000 S10 Xtreme (Black Magic) (My Drag Truck)
D.B is offline   Reply With Quote
Old 03-02-2025, 01:04 PM   #169
jjzepplin
jjzepplin's Avatar
Yes there are three lines. The return would fill the bucket but where does the pump get the original fuel to send through the return line? The pump itself would have to be immersed in fuel initially or have fuel sloshing around enough in the tank to get to the pump/bucket right? Is something missing from this pump?
Old 03-03-2025, 08:21 AM   #170
jaros44sr
jaros44sr's Avatar
The white basket is sitting on the bottom of the tank with a full tank of fuel so it will be submerged I believe the springs on the rods help to push it down to the bottom
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-03-2025, 01:25 PM   #171
jjzepplin
jjzepplin's Avatar
I guess I'll have to lengthen those rods to get it down to the bottom of the tank.
Old 03-03-2025, 07:24 PM   #172
jaros44sr
jaros44sr's Avatar
I cut the rods and used brass compression nuts and sleeves, for the appropriate size of the rods
SAFETY FIRST
AS usual, off topic
Jim
Old 03-03-2025, 08:47 PM   #173
jjzepplin
jjzepplin's Avatar
Do you have any pictures?
Old 03-05-2025, 09:45 AM   #174
jaros44sr
jaros44sr's Avatar
I’ll see what I can find
SAFETY FIRST
AS usual, off topic
Jim
Old 03-05-2025, 12:17 PM   #175
jjzepplin
jjzepplin's Avatar
I fussed around with the fuel pump this morning and took the bucket off of the shafts. It seems there are other holes in the bucket that the shafts can go through to make it straight and not off to the side. Are the shafts stainless steel? A rare earth magnet sticks to them but just barely.
I also cut my plastic tank mount to fit my stainless rings just perfect. Now I have to make a gasket.
