Old 01-20-2025, 01:07 AM   #1
fencerspinley
1963 GMC c20 to 4x4
Hello I figured I should start a build thread as a place to put all my questions during the because I for sure have a bunch of them.
After selling my 66 c10 I bought a super clean 1963 GMC c20 camper special awhile back with the intention of building a 4x4 truck.
One of my main goals is to maintain the factory frame and just fab new suspension parts to the 2wd frame. I don't like the way body swaps look with the extra body lift you usually have to have. Seems simple enough seeing as how to gmc trucks already came with rear leafs.
With that I got to the drawing board made a list of everything that was important and got started.
-Maintain factory frame and body mounts
-Use as many off the shelf parts as I can
-Easy and mostly bolt on
-Convert to 67-72 leaf springs
I've for the most part got all the suspension done and am working on engine placement (one of my many questions).
As it sits now the engine is reallyyyyyy close to the firewall. This truck originally had a v6 and an sm420 but I know that 4x4 trucks had very little clearance on the firewall. I'm going with an LS and sm465 and want the stick to go in the factory hole in the floor so I'm pretty sure the engine is where it has to go. Any help with that is appreciated.
Hopefully the pictures show up. I have a lot that I can share. I'm going to keep posting as I go but I'll have a bunch of questions I'm sure. Let me know what you think. If you have any question and I'll do my best to answer them.
fencerspinley is offline   Reply With Quote
Old 01-20-2025, 02:38 PM   #2
caseyjones
Re: 1963 GMC c20 to 4x4
Awesome project and that truck is crazy-clean. I don’t have any advice on the motor other than “if it fits it ships.” Looking forward to seeing more…
caseyjones is offline   Reply With Quote
Old 01-20-2025, 06:06 PM   #3
fencerspinley
Thanks! It sat under a carport its entire life.
I’ll try to get pictures of how close the engine is to the fire wall and hopefully someone with a factory 4x4 can chime in with actual measurements. The transmission lines up with the hole but I think the heads may be too tall. I’m not sure though. I designed the engine crossmember to have similar measurements to a popular aftermarket 67-72 one.
Old 01-21-2025, 12:15 AM   #4
fencerspinley
More pictures
Old 02-24-2025, 11:36 AM   #5
TJ's Chevy
TJ's Chevy's Avatar
Definitely a build I wanna see! I have a 64 GMC that I want to convert to 4x4. Did you build the leaf spring brackets as well?
Old 03-03-2025, 03:36 PM   #6
fencerspinley
Yeah I drew all the brackets in CAD and had them laser cut and then I welded them together. I’m just getting to the point where the bed is back on and I’m test fitting a full LS to see if my engine mounts are right. I don’t have a factory 4x4 truck to go off of so everything is measured from my buddies 72 and cross referenced with mine. I’ll post some more pictures tonight of how it sits now.
Old 03-03-2025, 04:03 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Nice! Is your steering box from a 67-72 truck as well as the front axle?
I have a 73 k20 frame I'm debating on either swapping my 64's body onto or using the springs and perches from the frame to swap onto the 64's frame.
Old 03-03-2025, 05:35 PM   #8
fencerspinley
The steering box is from a late model square body so it has metric fittings to hopefully match the metric fittings on the LS power steering pump. The front axle is from a 1991 3/4 ton suburban so it’s a 10 bolt and not a Dana 44. The only “67-72” part on this truck are the leaf springs. I wanted to keep the factory frame because that way all the body mounts are the same and there’s no need for a body lift or anything. I’d be more than happy to work out a deal on a set of the leaf spring mounts once I’m sure they work right.
Old 03-04-2025, 12:25 AM   #9
fencerspinley
More pictures and how it currently sits with the bed on.
Old 03-06-2025, 11:47 AM   #10
TJ's Chevy
TJ's Chevy's Avatar
Dang she's gonna be tall! Looks good though!
Old 03-17-2025, 09:41 AM   #11
fencerspinley
I got the engine set in but it’s a little too close to the firewall than I would like. I know factory 4x4 trucks had the engine sitting way back but I’m not sure how close is too close. Does anyone have a factory 4x4 truck with a 4 speed that they could pull some measurements on?
