Old 02-26-2025, 11:49 PM   #1
kwmech
SPID help
Putting info together to have a spid made for my GMC. I cannot find any designation regarding a 157'' wheelbase. Any help?
Old 02-27-2025, 01:33 AM   #2
402Bowtie
402Bowtie's Avatar
Re: SPID help
What year gmc?
On the spid, I think you would see reference to 157" in two spots:
1) the "w/base" entry at top of spid
2) the model number. Specifically, I think you would see "64" in the sequence which correlates to 157" wheelbase.
See the attached pic for an example (69 gmc found here). Also, here is a reference point for model numbers... While it doesn't call out 157" wheelbase I think you have enough info to put the pieces together.
402Bowtie is offline   Reply With Quote
Old 02-27-2025, 03:10 AM   #3
kwmech
Re: SPID help
Thanks, that helps. I see by that vin that truck has the V6. Mine used to be a Class B motor home with quite a few options involved. The coach part of it was all rotted with water damage and cut off the frame
Old 03-03-2025, 07:45 PM   #4
cbeerman
Re: SPID help
Here is your model number from the GMC parts book
CM3640V
cbeerman is offline   Reply With Quote
