#126 |
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Tank filler and two vents are welded in. I used leftover 1.5 inch stainless exhaust tubing from my Honda chopper exhaust build for the filler. The vents are just stainless 3/8 90 degree barbs that I got off Amazon. I pressure tested and welded up any holes before I added these three so I know that the tank will be leak free once I add a viton seal to the sending unit and fuel pump module. It appears that the stinking teflon does not seal well. The viton sheet should solve that. I still have to fab up either tank straps or tabs to hang the tank. I am leaning toward tank straps like factory. I have three pieces of 1/8 in thick stainless bars that are 1.5 in wide x 48 in long. I can bend them up and drill a couple holes and be done.
The only thing left to weld is the 5/8 in filler neck vent. Hallelujah! Some of my welds are not too bad. Others are not great but oh well. |
#127 |
![]() Join Date: Dec 1999
Enjoy seeing the progress. Keep at it!
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#128 |
