Old 02-26-2025, 07:06 PM   #1
Classic Bowties
Always on the hunt...
F/S OE SBC Short W/P Brackets and A/C Pulley Setup
The below pictured parts were removed from a 1972 small block 350 donor truck, these are OE used short water pump pulleys for a/c and p/s applications, you will receive an upper two groove w/p pulley 646AH, a lower two groove inner crank pulley 043BA and a lower single groove outer crank pulley 232BB. The pictured add on outer 232BB crank pulley for driving the p/s pump only pairs up and aligns with the single groove p/s pump pulley 325DJ, so check your pump pulley out. If needed, we can also add/supply the small block 7 pc. a/c compressor mounting bracket set, we will ship either #1, #2 or all combined for $20. in the CONUS. If interested, online funds can be sent via Zelle and CashApp, Credit/Debit Card over the phone or Check/Money Order by mail. Mel
#1 } OE used 3 pc. a/c application water pump, inner crank and p/s add on outer crank pulley setup. $150.
#2 } OE Used 2 pc. alternator mounting bracket setup. $85.
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 03-08-2025, 11:05 PM   #2
Classic Bowties
Re: F/S OE SBC Short W/P Brackets and A/C Pulley Setup
Bringing these short water pump SBC parts back up ttt...
