Old 03-06-2025, 12:21 AM   #5226
pjmoreland
pjmoreland's Avatar
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by '68OrangeSunshine View Post
Is the tail end threaded on those? Looks like it on the top one.
C- Series trucks don't have any terminal nut there.
I have one that's that length, and it's threaded on both ends.
pjmoreland is offline   Reply With Quote
Old 03-06-2025, 09:05 AM   #5227
old51sedan
old51sedan's Avatar
Originally Posted by zicc1835 View Post
installed.....
That seat made one heck of a difference, I truly believe that the interior of a really makes a vehicle as far as looks and resale value. I bet a tan dash pad would really set it off. Great choice.
old51sedan is offline   Reply With Quote
Old 03-06-2025, 09:31 PM   #5228
zicc1835
zicc1835's Avatar
I totally agree about updated interiors feel good look good and brings bigger bucks
the dash pad is on order ,,,you know how it is remembering where all the goodies are stored FOUND EM
replaced the grab handle (was a good cheap idea from the PO) the original color of interior trimmings was green
zicc1835 is offline   Reply With Quote
Old 03-06-2025, 10:02 PM   #5229
weq92f
weq92f's Avatar
I took a picture of my buddy welding up my broken exhaust...
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-06-2025, 10:16 PM   #5230
Rust_never_sleeps
Rust_never_sleeps's Avatar
I fixed my wife's 21st Century car today, and it's true:
Ford really does hate their mechanics
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 03-06-2025, 10:25 PM   #5231
weq92f
weq92f's Avatar
In the case of dealer warranty work, you could say they love them.
-Kevin
Old 03-07-2025, 01:18 AM   #5232
Steeveedee
Who Changed This?
Steeveedee's Avatar
-Kevin
Needs gauntlets that cover his sleeves. I've had enough molten steel running down on me...
~Steven
Simi Valley, CA
Old 03-08-2025, 10:20 AM   #5233
HO455
HO455's Avatar
Originally Posted by brandnew72 View Post
Real simple today. Wired in the dual needle PSI gauge lights for the airbags to the accessory ignition power, protected with fuse.
Are they like the ones on my Burban? I had one with a slow internal leak from the get go. (Which they replaced at no charge) Also they aren't the most accurate guages expect a 5lb or so difference from one needle to the other.
RIP Bob Parks.
Old 03-08-2025, 04:35 PM   #5234
'68OrangeSunshine
'68OrangeSunshine's Avatar
I never noticed on my '68 C/10. It had no threading on the rod end going thru the Clutch Fork.
Only the K/1500 Jimmy's push rod was threaded with a 1/2'' nut to retain it in the Clutch Fork hole.
So is it a stock thing -- K- vs. C- types are tapped? Or is it aftermarket, or DIY for extreme Four Wheelers?
Old 03-09-2025, 07:40 AM   #5235
brandnew72
Similar to that, yes. Has the paddle switches mounted next them as well. I'm unsure of the accuracy, but it does take a touch more air to keep the passenger side level.
https://www.jegs.com/i/EZ-Air-Ride/3...oaAkVPEALw_wcB
brandnew72 is offline   Reply With Quote
Old 03-09-2025, 05:50 PM   #5236
zicc1835
zicc1835's Avatar
all interior saddle trim installed added console good match waiting on the dash pad
Old 03-09-2025, 08:36 PM   #5237
KQQL IT
At the body shop.
KQQL IT's Avatar
Bled brakes again.
Good helper got a better pedal, still a little to much back brake but better with a Pv4 proportioning valve.
Old 03-09-2025, 10:30 PM   #5238
wpavlis
I painted the rear half of the frame. I should be putting the bed back on with the new wood in the next week or two.
wpavlis is offline   Reply With Quote
