Old 02-06-2025, 01:38 PM   #26
BRL
BRL's Avatar
Re: Leaking Fuel Pump Diaphragm?
Originally Posted by IT Cowboy View Post
Can someone explain the electric fuel pumps to me like I am a 3rd grader...
I went to YouTube videos for inspiration, of course the pump isn't working yet and I'll toss in a fuel pressure regulator if necessary.
Wiring that stuff up under the dash was another adventure.
Love it LockDoc, I'll look into the heavy duty version.
My Sister got me one of those flashlights that clip to the bill of a baseball cap and I don't know how I ever lived without one.
The bill kept bumping into everything though so I broke out the scissors.
BRL is offline   Reply With Quote
Old 02-06-2025, 08:57 PM   #27
dmjlambert
dmjlambert's Avatar
Can someone explain the electric fuel pumps to me like I am a 3rd grader. Are they connected to a relay and the ignition so that is how they come on and what keeps it from just flooding the carb if you turn just the ignition or a pumps switch on.
The carb does not get flooded with an electric fuel pump or mechanical fuel pump because the carburetor has a float in a bowl connected to a needle and seat valve that shuts off the incoming supply of fuel. Pretty much just like a toilet tank shuts off incoming water when the tank is full. If that piece is working correctly, the carburetor only lets in enough gas to fill the internal bowl. The needle and seat and sometimes the float are some of the items typically replaced during a carburetor rebuild.
Old 02-06-2025, 09:02 PM   #28
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
OK durr, like a gravity fed motorcycle tank and carb
1972 C10 Custom Deluxe Highlander 402
2019 Toyota Tundra SR5
2018 Jeep Wrangler Sport
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-06-2025, 10:24 PM   #29
BRL
BRL's Avatar
Sorry about that IT Cowboy, I'm in no position to explain that stuff to anybody.
Old 02-06-2025, 10:43 PM   #30
Steeveedee
Who Changed This?
Steeveedee's Avatar
It's entirely possible for the scenario you asked about to happen. The fuel just doesn't come through the carburetor- and is actually a worse situation. It is unbelievably rare, but I've seen it...and in the case of a bad needle and seat or float, much less of a problem, unless someone just leaves the engine running. I've seen crankcase oil dilution from that, too.
~Steven
Simi Valley, CA
Old 02-08-2025, 02:00 AM   #31
BRL
BRL's Avatar
That's exactly what I was looking at.
Years ago I had a really nice '69 Nova with the deluxe trim and the wrong year rally wheels.
One day I noticed fuel dripping out of a bad mechanical fuel pump through a weep hole in the pump and of course replaced it.
That tank is located way in the back under the trunk and under the frame and who knows if any fuel flowed into the crankcase before I caught it, didn't know enough to check the dipstick level.
Now picture a 20 gallon gas tank essentially turned sideways behind you up in the cab, well above the frame and a leaking fuel pump with open access to your engine crankcase and your garage floor.
Old 03-09-2025, 02:59 AM   #32
BRL
BRL's Avatar
Getting ready to try to figure out the fuel line routing to my electric pump.
Thought it might be too close to the transmission crossmember but a short piece of rubber fuel hose will slide right over the top of the crossmember to meet a hard line.
...so far so good.
Pinched the short rubber fuel line from the tank to the beginning of the hard line with vicegrips and cut the line.
Fuel started pouring all over me and the floor?!?
Thought it was just residual fuel in the line from the mechanical pump up front so I allowed it to drain out...but it continued.
Turns out I cut the fuel line on the wrong side of the vicegrips and the tank was draining out all over me.
Decided right there and then that I don't want a woodstove in the garage for heat and I'm done tinkering for tonight.
Old 03-09-2025, 02:25 PM   #33
Papa Smurf
Active Member
I put a carter fuel pump on my big block with quadrajet and the pressure was too much and caused it to flood out. Put a 3# pressure rgulator on it and it works fine.
72 Sierra Grande 2500 BB
72 Sierra 2500, 42K miles, factory buckets
72 Cheyenne 20
72 Chevy SWB, Factory BB, Leaf Spring
Papa Smurf is offline   Reply With Quote
Old 03-09-2025, 04:15 PM   #34
BRL
BRL's Avatar
Good to know thanks.
The Carter P4070 is supposedly putting out between 4-8 psi and will be feeding a Edelbrock 600 cfm model 1405 (I think) so it might or might not need a regulator in the end.
Should be interesting if I get my lazy tail up to the garage and continue installing the dang pump.
Old 03-09-2025, 05:00 PM   #35
IT Cowboy
IT Cowboy's Avatar
My 72 has a mechanical pump with a return line. If I put a pressure regulator on the feed line to the carb will the pump handle the "back pressure" or do I need to plumb in a return T from the carb supply line to the pump return line and put a check valve in there too. I think my return is 3/8
Old 03-09-2025, 11:14 PM   #36
BRL
BRL's Avatar
Went to remove the hard line that goes from the tank to the mechanical fuel pump that runs along inside the frame, and all went well except for that last clip which of course is hidden in the most inaccessible place on the truck.
There probably is a simple technique for removing that clip but I don't know what it is.
Spent about 2 hours fighting with that stupid thing with every feasible tool I could come up with in my toolbox until finally it broke free from the frame.
I'm taking the rest of the evening off.
Old 03-09-2025, 11:45 PM   #37
LockDoc
The Older Generation
LockDoc's Avatar
Not only is it hard to get to but you can't see in there either....
Leon
Old 03-10-2025, 01:34 AM   #38
BRL
BRL's Avatar
I figured if you replied at all it would go something like: "You big dummy, all you gotta do is...
I appreciate the sympathy and understanding, that thing was a nightmare!
Old 03-10-2025, 02:12 AM   #39
BRL
BRL's Avatar
Ok, I really am in the market for one of these babies!
