Old 03-01-2024, 12:08 PM   #301
68 C10 Driver
Re: 1968 C10 Stepside Restoration Project
That steering wheel is not too much different from my 65 El Camino wheel when you put them side-by-side.
@raggedjim, I like the colors you picked! Keep in mind that you will need to build out the base of the steering wheel where it meets the truck's steering column. Truck steering wheels are a larger diameter at the center. I used a product called "All Metal". It is a body filler that has metal (aluminum) in it and makes for a hard surface when done. If i remember you only need to build it out about 1/8 to 3/16 in.
68 C10 Driver is offline   Reply With Quote
Old 03-01-2024, 05:21 PM   #302
68 C10 Driver
@raggedjim:
Here is what my 65 Camino steering wheel looked like before and after I built out the base. Note where the steering wheel and steering column meet.
Old 03-01-2024, 10:34 PM   #303
raggedjim
raggedjim's Avatar
Yeap, I've been building that base up and it is just about right. I hope I can get mine to the point yours is, it's a work of art.
Amazing how similar they are! I want to find a Chevy button that will fit in the same space as the Pontiac emblem.
raggedjim is offline   Reply With Quote
Old 03-03-2024, 01:06 PM   #304
68 C10 Driver
The one for the 65 El Camino should be a match.
Old 03-03-2024, 09:56 PM   #305
raggedjim
raggedjim's Avatar
I'll look into it, thanks!
Old 04-14-2024, 08:16 PM   #306
68 C10 Driver
So this weekend's main project was to install a pole barn style car port so I do not have to work on the frame in the blazing sun this year. Great product from a local builder.
First photo is the site for the car port, just next to my shed. Second photo shows the materials when delivered. Third is a little more than halfway through the process, and last photo is the completed carport. Car port is 20 x 20.
This car port will also be where I park the truck. The garage will not be big enough to handle having it, my MG, and our classic Mini when it is done.
Old 04-14-2024, 08:54 PM   #307
zicc1835
zicc1835's Avatar
nice....
zicc1835 is offline   Reply With Quote
Old 04-14-2024, 09:17 PM   #308
68bowtie
68bowtie's Avatar
Looks great!
Old 05-06-2024, 08:31 PM   #309
68 C10 Driver
So I got out today to do some de-rusting of the frame, all the while enjoying the shade from my new car port. stripping rust off of a truck frame is not an easy task, especially when your primary weapon is a hand grinder with a wire wheel on it. Not only is it loud (had my ear protection on), but it really gets old fast. Those heavy duty wire wheels work great, but occasionally throw those wires at you. Definitely wear a face shield when doing that task.
Sprayed Rust Mort on the frame after I wire brushed it. Should not flash-rust. I will eventually use the Eastwood Rust Encapsulator and Satin Black 2k frame paint when the rust removal is done.
Old 05-06-2024, 09:09 PM   #310
zicc1835
zicc1835's Avatar
looking good lots of work been there and done that .....I cheated and had the second one I did blasted keep at it.... and your right watch them flyin wires off the wheel you may want a blacksmiths apron
Old 05-07-2024, 09:08 AM   #311
raggedjim
raggedjim's Avatar
Wire wheels, I use them but I don't like them! Nice work!
Old 10-14-2024, 07:00 PM   #312
68 C10 Driver
Finally got some time to get out and work on the frame. Had to do some rework of the area previously done due to surface rust. I got a little further, spraying with Rust Mort as I go trying to keep the rust at bay. Hoping to get the rest of the frame de-rusted, rust encapsulator applied, and the 2k epoxy frame paint applied before the cold weather sets in.
Old 10-14-2024, 07:14 PM   #313
zicc1835
zicc1835's Avatar
I know you put the port up to work under how cold does it get by you?
Old 10-15-2024, 01:13 PM   #314
68 C10 Driver
It doesn't get too cold here...late January and into February we average about 48 degrees with lows into the upper 20s to lower/mid 30s. But we have periods it will climb into the 60s for a few days at a time. Just depends.
Old 11-10-2024, 06:59 PM   #315
68 C10 Driver
Took a break from the frame and decided to strip down the bench seat. I removed the two bolts at the pivot joint to remove the seat back. Man, am I glad this truck has the seats that folds down, makes accessing the area behind the seat so much easier. I removed a butt load of hog rings and clips and was able to get the two layers of vinyl off of the seat. The foam for the seat bottom was toast on the driver's side, as were the edge springs. The springs that go front to back were broken on the driver's side, but ok on the rest of the seat, but I think they are a bit tired. While the original springs seem to be no longer available, I think I will just use the s-shaped springs like the later seats.
The frame required some welding as the front mounting channel for the springs was loose from the frame base...fixed. The seat back just has some surface rust, mostly at the bottom where the upper (back) section meets the seat bottom.
I have ordered the cotton batting for the seat back and will fit some foam to cover that, although the seat originally didn't have that. The seat back frame also needs welding at the bottom at the bottom rail and side rail weld joint
Old 11-10-2024, 08:58 PM   #316
68 C10 Driver
Here are some photos to show the areas that needed rewelding. First photo shows how the channel that the springs connect to has pulled away from the seat frame. Second photo shoes the tack welds now securing it. Third photo shows where the seat back lower rail/side frame joint has broken. That will be my task for tomorrow.
Old 01-24-2025, 10:29 AM   #317
raggedjim
raggedjim's Avatar
How's the truck coming? Hope all is well, Rg
Old 02-05-2025, 06:27 AM   #318
PowerdbyChevy79
PowerdbyChevy79's Avatar
Subscribed... Loving the build
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 02-05-2025, 09:38 AM   #319
bubbasimms
Great build,
Keep it Going!
bubbasimms is offline   Reply With Quote
Old 02-18-2025, 11:34 PM   #320
68 C10 Driver
All is well, just caught up in a busy time between work, kid's softball, and the endless parade of home projects. Thanks for asking!
Old 02-18-2025, 11:42 PM   #321
68 C10 Driver
So I finally got the seat back restored and covered. I stripped the frame of paint and rust, treated the metal, and repainted. I used the same technique for padding the seat (burlap, foam, and cotton batting) and put the new cover on. It had to sit in the sun a bit to warm-up so I could get it on nice and tight.
Old 02-19-2025, 09:35 AM   #322
raggedjim
raggedjim's Avatar
Seat back looks good, it's on my list!
Old 02-19-2025, 05:25 PM   #323
68 C10 Driver
So I looked back and realized that I never provided an "after" photo of the broken weld at the seat back lower rail and side frame from the post back on 10 Nov 2024. So here it is.
Like a few on here have said, "without photos it never happened!"
Old 03-02-2025, 07:27 PM   #324
68 C10 Driver
So in between projects, I finally finished rebuilding the seat bottom. I repaired the springs by MIG welding them, and for the seat springs that were too far gone (two in all) I substituted with the sinuous springs common to couches and vehicles of the 30s and 40s. I just tacked it in and ensured the welds were complete. It looks funny, but it will function like normal and you won't see it through the burlap, foam, cotton batting, and seat cover.
Has anyone else encountered seat springs like these? I cannot find replacements, and it takes a much thinner seat foam than what is available. Leave it to me to have the truck with the oddball seat in it. I am also thinking of making a reproduction build sheet to go into the seat like what was common back in the day. If anyone has an example of one I would greatly appreciate a photo of it to base mine on.
Old Today, 02:03 PM   #325
68 C10 Driver
So my burlap arrived, time to start getting the lower part of the bench seat ready for the upholstery. The cool part is that I found the thinner seat foam for this style seat...it is going to save me from cutting up the seat foam most common to the 1967-72 C10s. I found out that my seat is the same as what came with the 1960-66 C10s. As far as I know, this seat is original to the truck, so my guess is that during assembly they used old parts to burn through them and save money during the assembly. I don't know for sure, that is just my guess. I know that MG did that on occasion to use parts that were from the previous model yer as they could for cost savings, so why not at Chevrolet? I just know that I am not the only one with this style seat in my C10.
