#126 |
![]() Join Date: Oct 2011
Re: 1968 redo
Got the interior sanded and primed for paint.
Joey |
#127 |
Re: 1968 redo
Shot the remainder of interior today. I ordered an LED clear lens dome light today.
Joey |
#128 |
Re: 1968 redo
Those above pics make the interior appear that it does not match. There are some bright LEDs shining in cab. Here is a pic of the glove box. The color in this pic shows better than these.
Joey |
#129 |
Re: 1968 redo
Painted the dash bezel today as well. I counted 10 bulbs inside dash panel. Planning to replace those with LED bulbs. The instrument panel glass looks pretty good. There are a few rusty spots on the printed surface of the tins. I am hoping they clean up.
I am waiting on the manifold clamp kit I ordered from 12bolt.com. He has some pretty fast shipping, I expect it here Monday or Tuesday. I well get the manifolds cinched down and torqued, then re-install the monojet carb. I have not been able to locate my breather. Took it off in 1992, the truck has been towed to 3 different locations since then and it got lost somewhere along the way.
Joey Last edited by Dude68; 03-02-2025 at 07:16 AM. |
#130 | |
![]() Join Date: Oct 2020
Re: 1968 redo
BTW, the interior of the truck came out great! |
#131 |
Re: 1968 redo
It was a frustrating day today. Started off wet sanding some spots on interior all the way down to 5000 then buffing. Satisfied with the outcome so started putting stuff back together. New repop vents went in and they are very difficult to operate. Handle will need to be mounted lower than the stock one, so gonna have to drill a hole. Makes it easier to open/close, but still difficult. Repop dash pad put in and cannot get the lower holes to line up. Put a big scratch to right of radio trying to line up holes pulling down on pad with a screwdriver. I am considering taking my old dash pad to the seat shop and having them re- cover it. I’m very irritated with these parts not working right. I know that’s a problem with reproduced stuff.
Joey Last edited by Dude68; 03-06-2025 at 09:50 PM. |
#132 |
Re: 1968 redo
My passenger side vent was the same, I ended up using parts off the old vent to get it to work decently, but it still isn't how I want it. I just liked the old knobs/grab handles that were original to the truck better than the repops. I think I will modify the actuating rod that connects to the vent door to get the results I want. Once I do that, I will post on my build blog.
#133 |
Re: 1968 redo
Moved the bracket down a bit and it works better.
Joey |
#134 |
Re: 1968 redo
I have dash speaker mount and little stuff coming from Mel "classic bowties". I ordered some "cool white" LED lights for the dash panel, and then found some green ones that were cheap, so I ordered those as well. I am gonna try them both out. I read a few posts on here that said there is no recognizable difference using LEDs on the turn signal lights in dash, hi beam light, and warning lights, so I'm not going to change them. My defrost vents were broken, I could not find any blue ones to match, so I ordered black ones from LMC along with hoses and a floor vent.
The carpet and new seatbelts came in. The carpet I ordered was medium blue and is a little lighter than I wanted. The powder blue seatbelts from t korinek look sweet. Only took a week to get here. Trying to fix the big scratch on dash. Will post update soon.
Joey |
