Old 03-11-2025, 11:42 PM   #1
Dude68
Instrument Panel Bulbs
Want to replace all the bulbs in dash with LED. Are they all the same. Found replacements on LMC. Clear is not listed but white is. Is this the color to replace. There are 10 of them
Joey
Dude68 is offline   Reply With Quote
Old 03-11-2025, 11:57 PM   #2
58 Special
Re: Instrument Panel Bulbs
I think if you have a non tilt automatic you might have trouble with using an led bulb for the one that lights the shift indicater. I think I remember someone having to change one back to incandescent.
58 Special is offline   Reply With Quote
Old 03-12-2025, 12:06 AM   #3
Dude68
I have 3 speed. Thanks I found a post on here and ordered the cool white 194 bulbs. Looks like the turn signal and bright light bulbs won’t improve with led bulbs.
Joey
Old 03-12-2025, 01:20 AM   #4
franken
Maybe check grounds and voltage to ground before swapping things.
Old 03-12-2025, 09:06 AM   #5
cj847
cj847's Avatar
As indicated above, you'll probably find many of your bulbs are good but the socket or the connection between the socket and the circuit board is corroded.
cj847 is offline   Reply With Quote
Old 03-12-2025, 11:47 AM   #6
Classics Fan
Originally Posted by 58 Special View Post
I think if you have a non tilt automatic you might have trouble with using a led bulb for the one that lights the shift indicater. I think I remember someone having to change one back to incandescent.
I recently replaced all my incandescent panel bulbs with LED and can confirm this. Also retain incandescent for the high beam indicator. I used green LED’s for all others and am very happy with the result.
Classics Fan is offline   Reply With Quote
Old 03-12-2025, 02:31 PM   #7
awryexperiment
I replaced mine with some from the jungle website. They were cheap and bright.
https://www.amazon.com/dp/B0CNVBL98Z...n_title_5&th=1
awryexperiment is offline   Reply With Quote
Old 03-12-2025, 08:13 PM   #8
Dude68
These say they are 194's in a 30-pack. I ordered some in green. Gonna see how they look.
Joey
Old 03-13-2025, 12:51 AM   #9
bwl101
bwl101's Avatar
Got pictures of the end result?
'72 C10 Long Bed Stepside
Putting my Grandfather's truck back on the road:
http://www.67-72chevytrucks.com/vboa...d.php?t=829659
bwl101 is offline   Reply With Quote
Old 03-13-2025, 03:48 AM   #10
Dude68
They have not arrived yet. The truck does not have power yet. I will need to figure out how to test the dash panel with the new lights before I install the dash.
Joey
Old 03-13-2025, 07:37 AM   #11
tim_mc
tim_mc's Avatar
I went with SuperbrightLEDs and am happy with them.
https://www.superbrightleds.com/194-...packamt-Single
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 03-13-2025, 10:36 AM   #12
Classics Fan
Here ya go. I got the bulbs from Amazon.
Old 03-14-2025, 02:31 PM   #13
68 TT
Still plays with trucks
68 TT's Avatar
Just make sure you get some that are dimmable and buy more than you need so you have spares that are the same output and color as what you used.
I put them everywhere in my 95 and they ended up being too bright in the cluster so it hindered my night vision on dark roads. The ability to dim them was critical.
No matter how long they are supposed to last doesn't mean they always will. I had several on my truck fail in a few different locations. The colors from different manufacturers are not always the same and really show up sometimes. My roof top clearance lights were always going out and the amber bulbs really showed the different colors from different makers. Same goes for the white in the cluster bulbs. Get spares so you have matching replacements.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 03-14-2025, 04:09 PM   #14
MikeB
MikeB's Avatar
Me, too. That was 3 years ago and they still work. Can't remember which style bulb I'm using for the fiber optic cable. Speaking of which, that cable is a bee-atch to route, or I'm doing something wrong.
https://www.amazon.com/dp/B071ZXTDBD
BTW, I also installed a new printed circuit. Always had trouble with even stock-type bulbs not working and had to frequently re-seat or jiggle them.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-15-2025, 01:50 AM   #15
Rust_never_sleeps
Rust_never_sleeps's Avatar
For night vision, you could switch to orange or red lights, but then your dash will look like a BMW
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 03-15-2025, 10:50 AM   #16
MikeB
MikeB's Avatar
Hey, I remember that from the days when I had a 78 320i. An OK car, but not great. That was when the A/C system (which sucked) and radio were dealer installed. I guess Europeans didn't want or need A/C back then.
Mike
Old 03-15-2025, 05:35 PM   #17
Dude68
Any suggestions on how to test the dash panel lights with the panel off. I want to try the green ones and the white ones to see which color I want to go with.
Joey
Old 03-16-2025, 03:07 PM   #18
dmjlambert
dmjlambert's Avatar
I tested mine at the kitchen table using a small 12v battery out of a UPS (computer uninterruptable power supply) and using alligator clip test wires. Here is the diagram of the panel.
Connect the neg terminal of the battery to a case screw using one of the test wires. Connect the pos terminal of the battery to another test wire and touch the free end of the test wire to whichever place of the instrument cluster connector that you want to light up. Be careful not to touch the pos wire to the case of the instrument cluster. I used a business card inserted between the printed circuit and the metal of the case right at the opening for the instrument cluster connector to make sure I didn't touch the alligator clip to the case. As you can see in the diagram, terminal 8 is illumination, terminals 9 and 10 are direction signals, terminal 11 is hi-beam indicator.
My suggestion is be careful and don't go poking around on other terminals trying to light up other things unless you know what you're doing or you may fry some gauges or fry circuit board traces. You can see the traces of the circuit board, make sure you can see the traces are going to the bulbs you want to light up.
hi-res click here
Old 03-17-2025, 08:27 PM   #19
Dude68
I got my bulbs in. The superled bulbs in cool white looked good, but the green bulbs from Amazon are the ones I went with. I snapped a pic and it was too fuzzy, but it looks just like the post above by classicsfan. Thanks to dmjlambert for the idea. I used a battery charger to test the lights.
Joey
Old 03-18-2025, 06:33 AM   #20
jjzepplin
jjzepplin's Avatar
Now this looks like the shift indicator is well lit! Are they dimmable?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-18-2025, 09:22 AM   #21
Dude68
I do not know yet I have not attached the headlight switch
Joey
Old 03-19-2025, 04:31 AM   #22
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I used Yorkim Bulbs, I believe the number was T10, and they have been in the dash for 6/7 years now with no burnouts.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 03-28-2025, 10:25 PM   #23
Dude68
Green ones looked the best
Joey
Old 03-29-2025, 09:53 PM   #24
Dude68
My turn signal lights in dash panel worked when I tested them initially, then stopped. I changed bulbs and they still do not work. I may order a new circuit panel. Dash lights are good.
My generator light comes on when key is turned but not oil light, temp light or brake light. I can't remember if these lit up when the truck was started.
Joey
Old 03-29-2025, 11:30 PM   #25
dmjlambert
dmjlambert's Avatar
I believe oil light, temp light, brake light should light up as a bulb test during crank, but I am not 100% certain on that. I'm more familiar with the gauge cluster that doesn't have temp or generator lights. Generator light should be incandescent to have it tell you about overvoltage as well as under voltage and the polarity can swap on that bulb which incandescents don't care about, LED not appropriate for that position (or any position other than illumination in my opinion). I suggest insert conventional incandescent bulbs in turn signal positions and also make sure the front parking lights are flashing with turn signals correctly, before bothering to replace something like the printed circuit with a brand new chinese printed circuit that may be inferior. These are just my suggestions. In a previous post I gave the wrong diagram and pinouts for testing because the info I gave was about a gauge cluster not warning light cluster.
