#326 | |
![]() Join Date: Mar 2011
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 Last edited by zicc1835; 03-04-2025 at 08:11 PM. Reason: more |
#327 |
The CA version of evaporust works good. I use it and have no issues with it. I haven’t heard of a different version for CA, but that wouldn’t surprise if there was a CA version.
#328 |
![]() ![]() Join Date: Jan 2005
#329 |
![]() Join Date: Oct 2012
Decent weekend of progress.
First project was to install the side mirrors. When I bought the truck, It had big ole towing mirrors installed. Those got removed and all the holes were filled when I was working on the body. So new holes had to be drilled for the cleaner/smaller sleeker side mirrors. Hopefully I got the placement correct. I was just going off some images of other C10's with similar mirrors. Once the side mirrors were installed, I spent quite a few hours building, disassembling, and re-building the doors/vents/windows. Took me a while to figure out the order of operations but I finally nailed it down on the 4th attempt on the driver's door. ![]() Once I got the vents, glass and seals installed, I got the door panels and armrests bolted in. I went with some cheaper LMC all black panels. They fit ok, I did need to give them a little trim on the top and bottom edges to get them to fit into the recessed area of the door. Nothing major, just a little flap disc to mow it down. I haven't put the door handle or window crack on yet in case I need to get back into the door from some reason. I did a little wire clean up behind the dash and got the gauge panel bolted in for hopefully the last time. The Autometer gauge panel is a nice piece but the connections to the dash are less then desirable. The holes for the light and wiper switch are strange in that they're not keyed to hold the switches in place. I made it work and used the old metal bezels to finish it off. Last piece of door work was getting the key cylinders installed and locking level clipped in. The final items left for the interior are floor insulation, carpet, and seats/belts. A radio will come after the truck is a driver and then Vintage A/C sometime after a while. Moving my attention back to the exterior in the coming week. I'm finally ready to put the bed on and make this look like a complete truck again for the first time in 20 something months since blowing it apart. Once the bed is bolted down, I can bolt up the tailgate and hook up the Boyd's gas tank to the filler neck and put some go juice in the tank. The rear lights are the last bit or wiring I have left. I have already tested the wires for turn/brake/park lighting and everything looks good, they just need some connectors crimped and bulbs. I finally did try and crack the engine over, something I hadn't down since starting the wiring harness project. Went to turn the key to give it a bump and nothing ![]()
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#330 |
Your truck is looking really good!
#331 |
chevy truck fan
scott, nice work!! the weekend wasn't too bad to be in the shop!... I may have missed it? but I am interested in what you used for the cab floor coating(?)...
thanks!! |
#332 | |
Thank you! Moving through the to-do list making progress to the finish.
I'm still going to lay down some Dynamat for additional sound insulation under the carpet.
#333 |
Scott, I really like the mirror setup! My truck had the same god awful towing mirrors as well. Seeing yours, I have decided to do the same thing. I also like the door panels and was contemplating the same thing. Would you recommend the LMC panels?
Clay
Clayton Sikes Peoria, Arizona 1967 Chevy K20 Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272 |
#334 |
They're exactly what I thought they would be for $80 for the pair. Like I mentioned, I had to trim them a little bit on the top and bottom, but that wasn't a huge deal. It just looked like a little extra material that didn't get clipped off when they were stamped. All the bolt holes on the bottom, armrest, door handle, and window crank all lined up with no issues. Maybe someday my interior will get more attention and something more custom, but for right now they worked perfect.
#335 |
chevy truck fan
scott, thanks for the reply, did you decide to use for any heat related or sound concerns? or was just "extra"? also did you by chance make it out towards my neck of the woods for the "reunion truck show" in chandler on saturday??
#336 |
Just some extra sound insulation. I didn't know there was a show. Was it any good?
#337 |
chevy truck fan
Scott, I will probably lay some down on my floor as well. I am really wanting to make sure it is heat insulated for the summertime
![]() the reunion truck show is a smaller version of Dino's.. just number wise though. the quality of trucks is top notch. last year I talked to the current (at that time) owner of "HAZEL" and quite a few SEMA trucks as well ![]() ![]() |
#338 |
The bed has rejoined the rest of the truck. The boy and I did some work yesterday afternoon. After rigging up some 2x8's under the frame rails and some 2x6's hung perpendicular via some Simpson hangers, we used the engine hoist to lift the bed. It worked fantastic. The C10 has a little bit of a "Cali Lean" to it
![]() I also bolted in a radiator overflow tank I got from Summit. It's for a 1975-79 Nova/Skylark (insert Marissa Tomei ![]() I just need some 2" fuel rated hose and 5/8 vent hose for the tank to filler neck and we can start it up.
#339 |
She's looking like a truck now Scott! I like that overflow idea as well! It is nice and clean. I am going to order one for mine as well!
Clay
#340 |
chevy truck fan
scott, man!! she is looking really nice. i like the bed lift... and using simpson ties too!! it can be used in Cali. ...
#341 | ||
Thanks for the offer on the hose, I actually just picked one up @ Speedway on my lunch. I might have bought some bucket seats too ![]()
#342 |
wow great progress you are motivating me my friend and so is the weather turning here in the EAST ...great workmanship and ideas shared on this build thank you
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#343 |
Thanks, I took a lot ideas from others on this board and brought them to my build. It's great to have the encyclopedia of C10's at my fingertips here on the forum.
#344 |
Like I mentioned yesterday, I picked up some new bucket seats from Speedway. On my way home I snagged a center console from a seller on Offer up. Got home and had to throw them into the cab. I'm really liking how it's looking so far. The console gives it an extra seat, storage, and cup holders. I'm still messing around with the heights, once I get that dialed in, I'll fab up a frame to mount the seat sliders to and bolt it down in the original spots on the floor.
After sitting in my mockup location, I realized I messed up the location of the side mirrors. The driver side is in ok position, but the passenger is a little too far forward making it a little difficult to see the mirror from the driver's seat. I wanted to get the doors buttoned up, so I drilled to holes and mounted it. In hindsight, I needed to wait until the seats got in before drilling holes in doors ![]()
#345 |
Those seats look right at home in your truck. Did they come with mounting brackets?
#346 | |
Yes, they each came with a set of sliders that bolt to the bottom of the seat frame. Here is the link to them It was actually cheaper for me to buy these buckets then buy a new set of foam pads, a simple Vinyl cover, and new set of tracks (my old ones were toast and jammed up and didn't slide) for my old bench frame. Speedway has a floor mount they sell for 67-72 but it's a little $$$ for what it is. Also I knew I wanted a late model console and would have to fab up the mounts to fit everything. I first saw these seats in their YT build series
#347 |
Not a bad price at all overall, especially compared to original buddy bucket seats. You can't even get a completely trashed set for that amount.
