Old 03-11-2025, 12:18 PM   #1
ullose272
wiring cleanup
I have a '68 GMC that over the years has had different updates and mods done, MSD ignition, Electric fans, one wire alternator. it has some electrical gremlins and extra original wires that i would like to clean up. i have a full wiring schematic, but i wasnt sure which wires could just just go away.
anyone have thoughts?
ullose272 is offline   Reply With Quote
Old 03-11-2025, 01:01 PM   #2
PbFut
Re: wiring cleanup
I just finished the electrical last month. I found the fire had destroyed most of the engine harness and some of the headlight or main harness. With HEI the engine harness is easy and only has 3 wires really needed. Purple to starter solinode, green to water temp, and I think yellow to coil. The original yellow circuit has a splice to aux pin on solinode not needed with HEI, but the lead from fire wall connector needs to be replaced if original because it's a stainless steel resistor wire. That gives you a bunch of spare ports in the engine harness firewall connector to add extra circuits. The headlight harness is pretty much full at the connector and not much to eliminate. You can drop one of the leads for battery gauge if you are using the other for volt meter replacement. If you are using battery meter, and heavy loads like fans, this is a must to add a jump from main splice to a added junction block on left side fender. Then hook all non factory loads to that added junction block. This will keep your battery gauge functioning correctly. Be sure to fuse link thatadded main splice jump. That's about it.
PbFut is offline   Reply With Quote
Old 03-11-2025, 01:10 PM   #3
PbFut
Re: wiring cleanup
Forgot the brake warning wire. It is in the engine harness side of the connector. The photo shows ecu and added fuse box. 3 wires had to be added to the factory aux hole as all the pins were used up. I have 3 added meters, 3 added indicator lights aux battery relay trigger 3 fan triggers, fuel pump and ecu.
Old 03-11-2025, 01:34 PM   #4
Willshook
Re: wiring cleanup
I did the same thing both ways on my '72; there was a bunch of old stuff and wiring associated, and new stuff I added with kinda lousy, quickly-done wiring.
I bought one of those nice full-color laminated wiring diagrams, and just started labeling stuff. Then I slowly worked through and removed unused wiring, and re-did everything I had done before with good crimps, shrink wrap and nice routing. Zip ties to clean up.
Slow and steady with a good DVOM, working through the wiring diagram.
Willshook is offline   Reply With Quote
Old 03-11-2025, 04:32 PM   #5
LS short box
Re: wiring cleanup
My .02.
I think I would replace the complete wiring harness. I've had really good luck with Painless universal 21 circuit on a few hot rods. AAW also get good reviews.
I also like to hide wires on my LS swaps. With a new wiring harness its easy to hide wires.
Pic.
Old 03-11-2025, 06:51 PM   #6
Willshook
Re: wiring cleanup
Originally Posted by LS short box View Post
My .02.
I think I would replace the complete wiring harness. I've had really good luck with Painless universal 21 circuit on few hot rods. AAW also get good reviews.
Pic.
That is absolutely stunning work!
Do you have a build thread somewhere?
Old 03-11-2025, 06:52 PM   #7
54blackhornet
54blackhornet's Avatar
Re: wiring cleanup
Key word here is One Wire.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-11-2025, 07:21 PM   #8
brandnew72
Re: wiring cleanup
I removed probably a mile of wiring out of my 72. Traced 1 and removed the extra. One at a time. It's still what I'd call messy from the PO but better. I don't like that they put the fuse box in the cab. Id rather it be in the engine bay by the original location. But it'll take some more rework to do that.
But when I do, one wire at a time lol.
brandnew72 is offline   Reply With Quote
Old 03-11-2025, 09:30 PM   #9
Bodied67
Bodied67's Avatar
Re: wiring cleanup
My .02.
Pic.
This looks killer!
69 C10 "Nosejob"
24 Raptor "Daily duty"
Bodied67 is offline   Reply With Quote
Old 03-11-2025, 09:31 PM   #10
LS short box
Re: wiring cleanup
I did a build thread on here but don't remember the name. LOL. It was a 68 C10. It was a great project. I started out with a real clean truck to begin with.
Couple things.
I moved the fuse block back from the fire wall and filled the hole. Then made a smaller hole behind the left inner fender just for the chassis wire harness. Really not that many wires that go forward and back. I ran them along the left frame rail to the rad support. Same with the rear chassis wiring along the left frame rail.
All the LS/ECM wires out behind the engine by the right cylinder head into the cab to the ECM and fuse/relay block. Fuel pump wire cross over behind the engine and then down the left frame rail with the chassis wiring harness.
My current project is a LS3 into a 80 Camaro. I ran all the front chassis wiring harness wires as they did as stock over the left fender well.
Thanks for the kind words on the 68.
Old 03-13-2025, 11:44 AM   #11
ullose272
Re: wiring cleanup
My .02.
Pic.
i do plan on doing that eventually, but it will be when i can tear down the truck, and fill the firewall and do some other stuff
Old 03-13-2025, 04:23 PM   #12
LS short box
Re: wiring cleanup
So totally off topic but?
A number of years I bought a failed LS swap 67 Nova SS. PO got totally screwed by a some what local LS swap expert. It was a real SS but the original engine was long gone.
So as I have said above I love hiding wires.
Before and after pics.
Old 03-13-2025, 04:53 PM   #13
Orefactory4x4 swb
Re: wiring cleanup
That’s some clean work… and sweet nova
Orefactory4x4 swb is offline   Reply With Quote
Old 03-13-2025, 08:51 PM   #14
LS short box
Re: wiring cleanup
Thanks for the kind words.
Every time I look at the wiring mess it just makes me chuckle. The strange thing the LS was sound. I added forged rods and pistons along with LS6 heads. I used it on another LS swap project.
The LS3 in the pic was actually a LS2 block I had sleeved and stroked to 427 cubes. L92 heads. It did just a touch under 500 hp on the chassis dyno with a very mild cam. Very fun on the street.
Old 03-13-2025, 09:45 PM   #15
Orefactory4x4 swb
Re: wiring cleanup
Oh I bet, I’ve always been a truck guy. But a sick nova like that would be a fun get in trouble car
