Old 03-14-2025, 09:25 PM   #26
Dude68
Re: F/S OE Radio and Speaker Install Mounting Brackets, Cups and NOS Shaft Nuts
Cash app will be best Please include all parts I previously requsted.
Joey
Dude68 is offline   Reply With Quote
Old 03-15-2025, 03:20 AM   #27
Classic Bowties
Always on the hunt...
Originally Posted by Dude68 View Post
I will take one kit with brackets 1.2,3,4 and clips and screws. Joey
Joey, we have added some pictures of the GM NOS upper clutch rod to pedal lever bushings that you had asked about in our above linked (reply #25) f/s thread where the other GM NOS shift rod grommets and steel bushings were listed/offered. Your combined total due on the 4 pc. radio speaker mounting bracket and hardware setup and the NOS upper/lower shift rod grommets, NOS upper steel bushing spacers, NOS upper clutch rod to pedal bushing from the other f/s thread along with the payment info for sending of funds via CashApp has been forwarded on Sat. 03/15. Thanks, Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 03-15-2025, 05:32 AM   #28
Dude68
Mel,
Cashapp payment sent, thanks.
Joey
Old 03-15-2025, 08:45 PM   #29
Classic Bowties
Mel,
Hey Joey, the OE used 4 pc. radio and speaker mounting bracket hardware setup and GM NOS upper/lower shift linkage rod grommets and the NOS upper clutch rod to pedal bushing have been shipped off, your combined parts order went out via USPS ground advantage on Sat. 03/15 and the expected delivery day is Wed. 03/19. Thanks again for your order and let me know if we can help with any other 67-72 parts needs. Mel
Old 03-16-2025, 06:42 PM   #30
burb71
Active Member
Do you still have a complete set of brackets & possibly even the screws to mount the radio speaker?
burb71 is offline   Reply With Quote
Old 03-16-2025, 07:07 PM   #31
Classic Bowties
Yes, we can get a complete OE used #1/#2/#3/#4 radio and speaker install bracket and hardware setup headed your way, see 2nd, 3rd and 4th pics in the top post of thread for explanation of what brackets and hardware are included in the full setup, the pricing and payment options are listed in the same top post. Thanks for the inquiry, Mel
Old 03-16-2025, 08:54 PM   #32
burb71
Active Member
I'll take a complete set, with all necessary, screws if available.
I'm ready to send payment by cash app, let me know.
Also I noticed in another thread, you have all the brackets/hardware for installing a steering column, "automatic" I no longer have access to a bead blast cabinet, if you do, what would you sell a restored set of steering column brackets for? I need the complete set for both under the hood and under the dash to install the steering column.
Text or call if better for you.
Steve (239) 265-5457
Old 03-16-2025, 10:24 PM   #33
Classic Bowties
Hi Steve, we just tried sending a detailed pm but the system says that you are unable to receive any more messages until you clear some space, will go ahead and try sending you a text now. Mel
Old 03-17-2025, 10:15 PM   #34
Classic Bowties
Steve, the OE used 4 pc. radio and speaker install bracket and hardware setup has been shipped off, your package went out via USPS ground advantage on Mon. 03/17 and the expected delivery day is next Mon. 03/24. Thanks again for your order and let me know if we can help with any other 67-72 parts needs. Mel
Old 10-31-2025, 09:20 AM   #35
Hook'em
Hook'em's Avatar
Bumping to see if you have anymore radio brackets. Specifically, I need #1, 2, & 3.
Hook'em
Hook'em is offline   Reply With Quote
