Old 01-29-2017, 12:48 PM   #1
Mhussnatter
Hood bow tie emblem idea 69-70
Just figured I would share with the group. I am sure I am not the first to do this but I think it came out pretty cool. When I got my truck the blue plastic piece inside the emblem was all busted to pieces so I removed all the pieces which and found that the previous owner did not take it off prior to the 1/2 azz paint job he put on the truck so the original blue showed through. I didn't want to leave the emblem hollow anyway as water and dirt etc would get trapped in there. I removed it and then used it to trace out a template then transferred that to some aluminum and cut it out with some tin snips. I was kind of stuck on how to secure the aluminum piece inside the emblem....thought about soldering but then after some research decided that was not a good idea. Most of the tabs inside the emblem had broken off. I eventually decided to use some job weld and clamped it in place while the epoxy set up. Easy project that didn't cost much at all.
Mhussnatter is offline   Reply With Quote
Old 01-29-2017, 12:49 PM   #2
Mhussnatter
Re: Hood bow tie emblem idea 69-70
Here is the before
Old 01-29-2017, 12:51 PM   #3
Mhussnatter
And the after...
Old 01-29-2017, 01:51 PM   #4
kcsa75
kcsa75's Avatar
Cool. I'm not normally a fan of this kind of stuff, but yours looks good.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 01-29-2017, 01:58 PM   #5
BigBen702
Looks really good I may have to copy your idea for my 70 stepside
BigBen702 is offline   Reply With Quote
Old 01-29-2017, 09:34 PM   #6
Gromit
Sweet! Thanks for sharing that Mhussnatter!
I've been thinking on what to do about my cracked blue plastic hood emblem too for a while now but hadn't come up with anything yet and I was resisting just ordering a repop from LMC
Your solution looks great and an excellent idea and in the spirit of smart DIY since it's got some extra soul over the repop.
I do want to keep my original blue color but you gave me the idea to look how to do that after doing what you did and I found two different things - the first one was 3M Blue reflective tape that is UV and heat resistant; so that looked better than what I have and could be layered on your aluminum idea.
But then I found something that I think might be even better than the 3m film which is glass microbeads, mixed with a transparent blue tint to match the exact OEM color; and then laid down on that aluminum backing just like you showed; and then maybe even filled with a clearcoat with a hypodermic like our Dentist member showed us with the emblems.
Here is an example youtube using the glass micro beads:
https://www.youtube.com/watch?v=WhV33Lzpxrg
or just search for this video title on youtube:
Making reflective paint with glass beads. Guerra Paint & Pigment Corp. NYC
I would still need to figure out what size beads would look most correct to look most like the factory Chevy hood emblem.
I think in the video she is just using an emulsifier like glycerol or polysorbate-80 or lecithin and mixing with regular old PVA glue but maybe someone can chime in. She has her own names but probably just to sell their own product.
Thanks again for posting! Good idea and well done.
Gromit is offline   Reply With Quote
Old 01-29-2017, 11:26 PM   #7
yuccales
yuccales's Avatar
I think that turned out good.
yuccales is offline   Reply With Quote
Old 01-29-2017, 11:32 PM   #8
70cst
70cst's Avatar
Matches well ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-30-2017, 01:26 AM   #9
James the III
Cool, maybe match the center to the body color.. so it doesn't look like a billet add on..
Either way I like it...
James the III is offline   Reply With Quote
Old 02-01-2017, 03:05 AM   #10
Carlitosway
thumbs up, great idea
Carlitosway is offline   Reply With Quote
Old 02-01-2017, 07:24 AM   #11
GR8-68
GR8-68's Avatar
I like it, great idea and it looks great
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-07-2017, 06:47 PM   #12
chris86
chris86's Avatar
How do you get that thing on and off
chris86 is offline   Reply With Quote
Old 07-07-2017, 07:36 PM   #13
toolboxchev
Another round of applause for your fabrication prowess.
toolboxchev is offline   Reply With Quote
Old 07-07-2017, 07:58 PM   #14
bill3rail
bill3rail's Avatar
Thank you! I just noticed yesterday that mine looks a bit crackled and need to look into making it look better.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 03-14-2025, 09:56 AM   #15
Luke87gt
Luke87gt's Avatar
I’m also curious on this, anyone know
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 03-14-2025, 10:41 AM   #16
IT Cowboy
IT Cowboy's Avatar
Humm, I wonder if that badge could be taken off and then filled with a blue resin. IT might be a challenge, though, since it looks curved. The OPs solution and cutour looks nice and much better than I would have been able to do.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 03-14-2025, 11:46 AM   #17
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
One can buy blue anodized aluminum sheet to match the blue of the cracked plastic piece.
https://www.google.com/search?q=alum...hrome&ie=UTF-8
~Steven
Simi Valley, CA
Old 03-15-2025, 09:51 AM   #18
Rich69shortfleet
Maybe not an easy option, but I actually prefer deleting the badge altogether. It looks tacked on in a strange spot. It belonged somewhere in the grill but the 69-70 grill never made a place for it.
I put an aftermarket cowl hood on my 69 and it did not have predrilled holes for the badge which is good because I'm leaving the badge off altogether. The same could be accomplished with a stock hood by using a 71/72 hood.
Rich69shortfleet is offline   Reply With Quote
