Old 03-19-2025, 02:10 PM   #1
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
67 C10 Z Bar help
I have a 67 C10 that I'm putting together. I have a small block on factory mounts both engine and bellhousing. The truck according to the VIN is a factory V8. The engine and Z bar is from a 69 and has the factory ball stud mount still on it. My issue is the Z bar. The tube is 6-3/4" long not including the ball stud part and I have at most 6" from the engine bracket to the frame bracket. Was the Z bar in 67 different? I'm considering cutting the tube in half and making it about an 1" shorter, but I'd like to know for sure I don't have something wrong.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
72 GMC Suburban 1500 Super Custom. White/Med Olive/White, Parchment interior.
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
78 AM General M35A2C with winch, multifuel with C turbo, bobbed deuce on 47” tires.
dutchmanz is offline   Reply With Quote
Old 03-19-2025, 05:06 PM   #2
Jason Banks
Jason Banks's Avatar
Re: 67 C10 Z Bar help
Went and measured one I have 1967 C10 V8 truck
Tube is 5 3/8 long
Jason Banks is offline   Reply With Quote
Old 03-19-2025, 05:57 PM   #3
lil hoodlum
lil hoodlum's Avatar
The longer Z-bar may be for an inline 6 engine as the mounting point is further away from the frame.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 03-19-2025, 07:23 PM   #4
dutchmanz
dutchmanz's Avatar
Tube is 5 3/8 long
Thank you. I've searched and never saw a measurement. Only that the 6 and 8 were different. Is that one possibly for sale?
Old 03-19-2025, 07:25 PM   #5
dutchmanz
dutchmanz's Avatar
I have seen some say the longer was V8 and some say the shorter was so I didn't know for sure. Especially when I never saw a dimension listed on a verified part like Jason listed.
Old 03-19-2025, 07:29 PM   #6
HalfBrit
I just measured my z-bar at 6-3/4". Factory 307/3 spd '70 C10
HalfBrit is offline   Reply With Quote
Old 03-19-2025, 07:32 PM   #7
Jason Banks
PM Me your address and I'll ship it to you tomorrow.
Old 03-19-2025, 07:35 PM   #8
HalfBrit
Wasn't the 67-68 frame rail wider through that area? That might explain the difference
Old 03-19-2025, 08:49 PM   #9
dutchmanz
dutchmanz's Avatar
I think it was wider on its inner dimension only because it wasn’t cut out for clearance. That could still be a possibility. I know the z bar I have came out of a 69 V8 truck that I converted to a big block automatic. I always see them listed as fitting 67-72 but now I’m seeing discrepancies.
Old 03-20-2025, 04:32 AM   #10
lil hoodlum
Both of my 68's are small block motors and manual transmission. I'll measure both of them tomorrow and report back.
The V8 engine is wider than an inline 6, therefor the Z-bar is shorter on the V8.
Old 03-20-2025, 01:34 PM   #11
pjmoreland
pjmoreland's Avatar
1967 was an oddball year for the SBC Z bar. It was the same as the inline 6 Z bar, frame bracket (inward with jog) and clutch pedal push rod (straight) that year. In 1968, the SBC Z bar/frame bracket/push rod design changed. The Z bar got longer, the frame bracket was flipped around the other way and made more square shaped, and the push rod got a dog-leg shape. Here's a thread on the subject:
https://67-72chevytrucks.com/vboard/...d.php?t=847345
pjmoreland is online now   Reply With Quote
Old 03-20-2025, 02:08 PM   #12
dutchmanz
dutchmanz's Avatar
Thank you for the Excellent info! Hopefully by next week I’ll have the correct z-bar installed and can confirm what does and doesn’t fit. I think my next C10 will be a square body! 🤣 This is my second 67 out of countless 67-72 trucks. Crazy how they changed so much between the years and options.
Old 03-20-2025, 02:58 PM   #13
lil hoodlum
Disregard my information about the inline 6 Z-bar being longer. It is not, the longer bell crank or Z-bar goes with the V8.
Iline 6 motors have a different engine mounting set up amd uses the shorter bell cranks.
http://67-72chevytrucks.com/vboard/s...ght=bell+crank
Old 03-20-2025, 03:45 PM   #14
72c20customcamper
72c20customcamper's Avatar
This is what makes this site great ,the people
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-21-2025, 09:26 AM   #15
70STOVEBOLT
70STOVEBOLT's Avatar
A lot of the parts on a '67 are leftovers from the previous model run. In other words, there are a lot of "67 only" parts in the 67-72 model run.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-21-2025, 10:31 AM   #16
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 67 C10 Z Bar help
Per the 1971 parts catalog:
3913127:
Old 03-27-2025, 03:13 PM   #17
dutchmanz
dutchmanz's Avatar
Talking Re: 67 C10 Z Bar help
Big Shout out to Jason! He shipped me the correct Z bar (For Free) and I have a clutch linkage that feels like it works! Now I have to get the engine running to see if it will move on its own power since 1990.
Old 03-27-2025, 09:06 PM   #18
Jason Banks
The timing was right. I had just taken that Z-bar off the 1967 I'm working on. The truck came without engine or trans, and I'm LS swapping anyway. I figured the Z-bar would just sit in a box for years, like so many other things.
Glad it worked for you!
Old 03-31-2025, 02:24 AM   #19
'68OrangeSunshine
'68OrangeSunshine's Avatar
Here's my solution to a '68 L6 Upper Clutch Rod. It's a length of steel rod [or iron] the machinist threaded on both ends for Heim Joints.
Works great. LMC stole my machinist's idea. It will be a lot cheaper if you fab it yourself. LMC's price is exhorbitant.
