Old 03-19-2025, 06:08 PM   #8
MikeB
MikeB's Avatar
Re: 67-72 350 4bbl hp ratings
Originally Posted by Rg500gamma View Post
When I redid the motor I tossed the dished pistons for the flat tops (9 to1 cr). Offenhauser spread bore intake with a Holley 650 mech secondary and headers routed dual exhaust
A midrange cam so I may be at 230hp
230hp may be close to realistic if you started with 200hp. Compression bump and dual exhaust should be a big help. Maybe the Holley carb and Offy intake not so much with a stock heads and cam. That's because the stock manifold with Q-jet was among the best factory combinations ever.
You might also want to Google "Chevy distributor performance curve".
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
