Re: Should I have a sway bar on a bagged truck.
The nature of air bags is to be a progressive spring, meaning that as the outer corner compresses the spring rate will go up. Essentially a sway bar does a similar thing. But, s someone else said, if you have a sway bar run it.
Are you running on the low end of the recommended air pressure? Your ride height would dictate your air pressure, and if you are running a low ride height or a lighter vehicle your air pressure should be lower, which might mean a lighter progressive spring. I would think you would need a sway bar more in this instance. I know even with my heavy duty 3/4 ton springs the sway bar made a BIG difference when I added it. What shocks do you have? I put Ridetech adjustable shocks and that made as much of a difference in my opinion because I could adjust them how I preferred my ride. This might be a better option for the already progressive air bags.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=6680032016 GMC Sierra K1500 1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817 |
| Bookmarks |
