Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-04-2025, 11:13 AM   #126
NDM
Re: Bucketlist Blazer -Restomod build 6.6liter L8T
Tank filler and two vents are welded in. I used leftover 1.5 inch stainless exhaust tubing from my Honda chopper exhaust build for the filler. The vents are just stainless 3/8 90 degree barbs that I got off Amazon. I pressure tested and welded up any holes before I added these three so I know that the tank will be leak free once I add a viton seal to the sending unit and fuel pump module. It appears that the stinking teflon does not seal well. The viton sheet should solve that. I still have to fab up either tank straps or tabs to hang the tank. I am leaning toward tank straps like factory. I have three pieces of 1/8 in thick stainless bars that are 1.5 in wide x 48 in long. I can bend them up and drill a couple holes and be done.
The only thing left to weld is the 5/8 in filler neck vent. Hallelujah!
Some of my welds are not too bad. Others are not great but oh well.
NDM is offline   Reply With Quote
Old 03-05-2025, 02:09 AM   #127
Richard
Enjoy seeing the progress. Keep at it!
Richard
Old 03-05-2025, 02:08 PM   #128
NDM
Thanks. I am hoping to have the tank installed and plumbed this weekend. By next week I should be able to drive it.
Old 03-06-2025, 04:08 PM   #129
NDM
Super happy! I bought a cheap ( not really) press brake from harbor freight just so I could make 1/8 in 304 stainless tank straps. I just need to drill the holes and I can hang the tank. My sheet metal brake was not up to the task and kept making radiused bends on my test piece. Glad I tested it before ruining my 48 inch long straps.
I am seriously debating adding a -8AN drain port to the tank. I would attach a long -8AN tube to it to allow me a drain line directly into a gas can or bucket. I have the stainless bungs and it would only take s couple minutes to weld up. The tube would be secured high up above the tank. I could just add the port and use a cap. That would work too.
Old 03-07-2025, 07:31 PM   #130
jaros44sr
jaros44sr's Avatar
Being able to drain the tank is always a good idea just MHO
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 03-07-2025, 08:49 PM   #131
NDM
Yeah. I am just tryinhg to decide where I want to put it. Front, side, rear, centered,etc. The -AN 8 port will allow any debris that could get stuck in the tank to be flushed out too.
Old 03-13-2025, 10:08 PM   #132
NDM
Last minute addition. I added the -8AN fitting to the front passenger side of the tank to allow easy draining when needed. There will be either a cap installed or a fitting with tube ran high up. The tube will allow me to drain fuel right into a gas can whenever I want to. It will normally just sit unused. I really debated this but decided that having the ability to drain the tank easily is better than not having the ability. This way I can get 99.99% of the fuel out when I need to. The aluminum surrounding the bung is drawing heat out of the hot welded metal.
An additional benefit is that if I wanted to or needed to, the return line could be plumbed here since it is at the very bottom and would be submerged. That would allow me to run a third fuel pump if I ever wanted to run a gazillion pounds of boost! Lol!
I posted a quick video to youtube for folks that are looking for an answer of what to replace their broken or lost factory u-bolt for the tank straps. Posting it here in case someone finds their way to my build. This is also a place for me to document my journey. I still look back at my old builds to find answers to things that I built a long time ago.
http://https://youtu.be/EkmTsehdTZA?si=8c6rPq0VkqEU833T
Old 03-14-2025, 10:45 PM   #133
jaros44sr
jaros44sr's Avatar
Nice work now is the time to check for leaks
SAFETY FIRST
AS usual, off topic
Jim
Old 03-15-2025, 01:05 AM   #134
NDM
I pressure checked the tank multiple times. I found a few and welded them up.
The tank has moved up from the basement. I used neoprene rubber adhesive strips from amazon to line my custom tank straps and the area that will butt up to the frame. I cut the 2 inch strips down to 1 inch to fit the 1.5 inch straps. This also turned my 2 in x 10 ft of rubber into 20 ft x 1 in. Costs $17.98 for the roll.
I debated adding sound deadener to the tank but decided that it would be worth it to avoid noise from the tank when empty. I had the deadener so better to get it done now than find out that I need it later and have to remove the tank. I did a good job of prepping and rolling the deadener in areas that will be covered by the frame or floor. I used heat to get it as flat as possible. The deadener did cover some of my pretty welds too :ROFLMAO::LOL: so that is a plus!! They were air pressure tested so I know that it should not leak.
I have to whip up the AN lines, add the ground wires, secure the wiring and then I can raise the tank into its new home. I will have to mount the regulator and connect the lines. Basically I should be plumbed by the end of the weekend.
Decided on routing the fuel down the drivers side because the passenger rail has alot of stuff on it due to the transfer case. Drivers side only has the wiring for the rear lights and the fuel gauge.
The tank is in and sits within the truck departure angle. Does not look too bad either. I did have to remake my bolts for the straps. The other ones were an inch too short. I used all stainless this time though to avoid having to waste time painting them. It took me 4 min to make.
I do need to dent my filler tube a tad as it contacts the floor. Talk about a game of millimeters! I may be able to move it back a tad.
Old 03-16-2025, 09:50 AM   #135
NDM
I caught the plague! Woke up with fever, headache, chills and a terrible sore throat. I slept almost half the day away but got myself out of bed to attend my son's basketball playoffs. I stayed away from people. We got beat by 2 points in the bracket before the final game.
All that said, I was able to motivate myself to embrace the suck and mount the fuel pressure filter/regulator and install the AN fittings. Other than hooking up the vents and filler neck, plumbing is complete. Next step is wiring the pumps and relays. Hopefully I wake up feeling up to the task.
Changed my mind on the location. I ran down the passenger side and there is a big loop in all the hoses on top of the tank to allow me to lower the tank without disconnecting the lines. Hopefully I won't have to chase any leaks. That would suck.
Old 03-18-2025, 12:49 AM   #136
NDM
No photos today but I got the fuel pumps 90% wired. The main pump is 98% done and the 2nd pump is 82% complete. I tested the main and the secondary. I should not need the 2nd pump if I run pump gas vs E85.
I am honestly getting tired of working on this thing. Between work, life and family time, I am really tired. The burden of the Blazer on my brain is distracting me every day and I am losing steam. I have no choice but to finish so I must keep going. I look forward to not working on it for a while. For a hyperactive old kid like myself that is saying something too! I do not usually run out of energy. Maybe my perpetual power supply is finally starting to give out. 47 years of endless energy. Not a bad run.
If I were to add fuel to the tank, it should run. I have to add power steering fluid, coolant, re-install the trans pan and add trans fluid, hook up the new and old starter wires and finish the tank vent lines.
I also need to add oil to the transfer case, install the drive shafts, change front and rear axle gear oil and new gaskets. Install the grill and bumper and a serious leak check for everything.
It is like days work if I was not so distracted by work stuff.
Old 03-18-2025, 03:10 AM   #137
Richard
Congratulations on the work moving forward. Looks like you have a path forward. Hope you get past the bug. You have more stamina than me. When I am working a lot I find it difficult to move forward at a steady rate. Thankfully for me it has been slow at the body shop and I have made a lot of progress in the last few weeks.
Richard
Old 03-20-2025, 10:03 PM   #138
NDM
These two videos have been sooooo motivating along the way. White C10 with the same motor as I have. I am not sure if he is cammed and stuff like me but the results should be similar but with the ability to do 4wd takeoff! I have watched these on repeat probably 100 times each!
It does not help that I dream of living in the southwest!
This is the website link to that c10. Looks pretty factory install to me. That means that even though I will have 8 inch more tire height, I should also have over a hundo more power to make those babies spin.
https://totalcostinvolved.com/testim...holas-vincent/
https://www.youtube.com/watch?v=gaew0Ia0JRI
https://youtu.be/X_aZ5tX3d38
Old 03-21-2025, 01:42 PM   #139
jaros44sr
jaros44sr's Avatar
Looks like you have some leaf spring bushing repair in your future maybe spray some penetrating fluid on it now….
Nice work on the tank straps. How’d the clamps turn out?
SAFETY FIRST
AS usual, off topic
Jim
Old 03-21-2025, 01:44 PM   #140
NDM
Phase 2 includes 4 links with Johnny joints. I will lube them for now though. Thanks.
Old 03-21-2025, 03:57 PM   #141
NDM
Needed to run-
-fuel
-power steering fluid
-tranny fluid
-coolant
Needed to drive-
-fill diff
-fill transfer case
-install driveshafts.
-install cowl with antenna
-install grillwith lights
-install bumper with lights
-Secure the air filter/make a box for it
Non essential stuff to do-
-Run exhaust past axle and out the back
-wiring cleanup inside the cab.
-add a 6l90E dipstick
-belly pan beneath the fuel tank
I will 100% be hearing this thing run again within the next 24 hours. I need to let the Ecu and motor talk to each other for a while to learn each other. I will cycle everything and look for leaks.
I plan to drive this thing by the end of the week!
Old 03-23-2025, 01:13 AM   #142
NDM
Filled the power steering reservoir., Trans fluid, coolant, and added 2 gallons of fuel. I had my son standing by with a fire extinguisher and when I went to start it, I realized that the main vehicle fuse had popped. Likely due to all the work. I did some tests to make sure that there is no shorts anywhere and did a prime with the secondary fuel pump straight to the battery. I will not be able to start it until I grab a couple of the fuses tomorrow morning. I could jump it across the terminals but I would rather have another fuse pop to warn me of any potential problems. The good news is that there is no leaks so far other than my goof up where I put too much tranny fluid in. I forgot that I need to start it, let it warm up and work the fluid through the cooler lines. OOps!! I cleaned the bloody mess up and popped the plug in to avoid any more leakage.
If all goes well tomorrow, I should be able to run it and let it start learning. It is too bad about that fuse. I was looking forward to hearing the roar again.
Needed to drive-
-fill diff
-fill transfer case
-install grill with lights
Old 03-23-2025, 11:41 PM   #143
NDM
I bought a new starter since my buddy at the store cut me a deal. It helped alot but there is still something wrong. I do not seem to be getting spark. I think it is a crank issue but will troubleshoot with holley possibly tomorrow. I am so bummed out that I have not been able to start it. I had it running on the engine stand so it has to be something small and silly. I have fuel pressure. I upgraded my starter wires to 0 guage since the tiny 6 ga was warm during crank. The engine grounds are 0 ga. The battery and alternator is 0 ga. Wtf??? I loaded the tune into the ecu again.
Oh well. Maybe tomorrow then.
Old 03-24-2025, 12:49 PM   #144
NDM
We have liftoff! I have a noise to investigate which I think is a power steering noise but I will remove the belt to isolate whether it is a motor noise or pully noise.
If all goes well, I will record the video and upload.
a few moments later-------
YEEESSSSSSSSSSSSSS!!!!!!!!!!!!
No motor noise other than louder dual springs. The rumble is SICK! Feels like a big block rumble. I can breathe a little now.
Old 03-24-2025, 05:54 PM   #145
NDM
Good news/bad news
Good news- Found my noise and it is not the power steering or the alternator.
Bad- apparently the water pump was damaged in the donor's accident or possibly there is something inside the pump because it is the source of the noise. They are not too expensive but I have to basically tear the whole front of the motor off to replace it.
This was the donor so I cannot be too mad about it. I should be able to have one quickly but I have to strip all the hoses off and hopefully not drop all of my expensive coolant. Should not take more than a couple hours with the coolant drain.
Old 03-24-2025, 05:55 PM   #146
NDM
Water pump will be here tomorrow. I can still start it but just not for too long. Here is a short video as proof.
https://youtube.com/shorts/xfJ3r2TsB...vX2Yc_jjzBD8GZ
Old 03-26-2025, 12:07 AM   #147
NDM
Next issue. The truck warms up slow but once it does, the temp shoots way up there. It is a brand new water pump and the radiator that I was using with the small block. I know I need to run a shroud to allow the fan to suck alot of ir through the radiator but the temps are not acceptable. For now I can let the fan run wild at 80% duty cycle but I gotta get this sorted. I will order up a lower thermostat. The factory one is like 200 degrees.
So the truck is running and learning. I plan to get the driveshafts in and button it up enough to drive this weekend. This is a great time. Finally I have success.
Another issue is the flex fuel sensor does not seem. To be sensing the ethanol. I am sure there is a simple wiring reason. I will find it.
Did I mention that this thing rumbles like a big block? It is fantastic!
Old 03-26-2025, 08:38 AM   #148
NDM
After a little research this morning, I realized that the temps should not be a problem. GM designed these things to run around 210 degrees +/- 10 degrees. I am used to motors running around 180 to 190 degrees. I am going to return my fan settings to normal and just monitor it. The higher temps apparently are good for engine longevity and economy. It is hard to wrap my head around it but I will accept it.
I am going to start putting everything back together so I can finally pull it out of the garage.
Short list-
Diff cover and fluid
Transfer case fluid
Driveshafts
Grill
Bumper
Secure some wires
Cowl
Old 03-26-2025, 05:12 PM   #149
NDM
Wow! I swear, I am not really stupid......but I goofed up and figured it out today. I was looking at the coolant thinking...."why is that so thick?". I never saw 50/50 mix coolant that was so thick. I looked at the bottles and ....EUREKA!!! I grabbed concentrate dexcool bottles and not 50/50 mix. I drained the coolant out of the radiator and mixed a little more distilled water than what came out of the radiator to make what should be close to 50/50. I burped the coolant for the third time. Now I barely cracked 202 degrees with the motor idling for a while. If I really want it to run under 200 I could change the stat but I think I am okay with it where it is.
I am going to try to fast track the remaining work tonight so I can drive it. The ecu and motor are pretty well married now in stationary conditions. Now I need to drive it so it can learn further through the rpm range.
Old 03-27-2025, 09:28 PM   #150
NDM
Short list to drive-
Install the grill
Install the bumper
Install the cowl.
Bolt down the seat
Technically I could bolt the seat in and drive it but I am being a good boy!
At this moment, I am so nervous and also on the verge of exploding from excitement! I have planned for years. I have spent an assload of cash. I have literally had blood, sweat and tears from getting stuff in my eyes. I am very ready to feel the dopamine hit from this project!
