Old 03-02-2025, 06:46 AM   #126
Dude68
Re: 1968 redo
Got the interior sanded and primed for paint.
Joey
Dude68 is offline   Reply With Quote
Old 03-02-2025, 06:50 AM   #127
Dude68
Re: 1968 redo
Shot the remainder of interior today. I ordered an LED clear lens dome light today.
Joey
Old 03-02-2025, 06:52 AM   #128
Dude68
Re: 1968 redo
Those above pics make the interior appear that it does not match. There are some bright LEDs shining in cab. Here is a pic of the glove box. The color in this pic shows better than these.
Joey
Old 03-02-2025, 06:57 AM   #129
Dude68
Re: 1968 redo
Painted the dash bezel today as well. I counted 10 bulbs inside dash panel. Planning to replace those with LED bulbs. The instrument panel glass looks pretty good. There are a few rusty spots on the printed surface of the tins. I am hoping they clean up.
I am waiting on the manifold clamp kit I ordered from 12bolt.com. He has some pretty fast shipping, I expect it here Monday or Tuesday. I well get the manifolds cinched down and torqued, then re-install the monojet carb. I have not been able to locate my breather. Took it off in 1992, the truck has been towed to 3 different locations since then and it got lost somewhere along the way.
Joey
Old 03-03-2025, 01:40 PM   #130
68 C10 Driver
Re: 1968 redo
Originally Posted by Dude68 View Post
...There are a few rusty spots on the printed surface of the tins. I am hoping they clean up.
Just be real careful cleaning that white painted area of the instruments, that stuff will come right off if you scrub too hard. Use a damped Q-Tip (not overly wet) and clean water, but be careful.
BTW, the interior of the truck came out great!
68 C10 Driver is offline   Reply With Quote
Old 03-06-2025, 09:29 PM   #131
Dude68
Re: 1968 redo
It was a frustrating day today. Started off wet sanding some spots on interior all the way down to 5000 then buffing. Satisfied with the outcome so started putting stuff back together. New repop vents went in and they are very difficult to operate. Handle will need to be mounted lower than the stock one, so gonna have to drill a hole. Makes it easier to open/close, but still difficult. Repop dash pad put in and cannot get the lower holes to line up. Put a big scratch to right of radio trying to line up holes pulling down on pad with a screwdriver. I am considering taking my old dash pad to the seat shop and having them re- cover it. I’m very irritated with these parts not working right. I know that’s a problem with reproduced stuff.
Joey
Old 03-07-2025, 02:52 PM   #132
68 C10 Driver
Re: 1968 redo
... New repop vents went in and they are very difficult to operate. Handle will need to be mounted lower than the stock one, so gonna have to drill a hole. Makes it easier to open/close, but still difficult...
My passenger side vent was the same, I ended up using parts off the old vent to get it to work decently, but it still isn't how I want it. I just liked the old knobs/grab handles that were original to the truck better than the repops. I think I will modify the actuating rod that connects to the vent door to get the results I want. Once I do that, I will post on my build blog.
Old 03-08-2025, 02:49 AM   #133
Dude68
Re: 1968 redo
Moved the bracket down a bit and it works better.
Joey
Old 03-13-2025, 04:06 AM   #134
Dude68
Re: 1968 redo
I have dash speaker mount and little stuff coming from Mel "classic bowties". I ordered some "cool white" LED lights for the dash panel, and then found some green ones that were cheap, so I ordered those as well. I am gonna try them both out. I read a few posts on here that said there is no recognizable difference using LEDs on the turn signal lights in dash, hi beam light, and warning lights, so I'm not going to change them. My defrost vents were broken, I could not find any blue ones to match, so I ordered black ones from LMC along with hoses and a floor vent.
The carpet and new seatbelts came in. The carpet I ordered was medium blue and is a little lighter than I wanted. The powder blue seatbelts from t korinek look sweet. Only took a week to get here.
Trying to fix the big scratch on dash. Will post update soon.
Joey
Old 03-15-2025, 03:39 AM   #135
Classic Bowties
Always on the hunt...
Re: 1968 redo
I am in need of all of these little parts that are supposed to go inside the circle on the clutch rod. Its being held in there with a cotter pin currently. All of the parts disintegrated when they were removed.
Originally Posted by pjmoreland View Post
Nice progress! Here's the clip that normally goes where you have a cotterpin in your clutch rod.
Thanks I have the clip, but seems like there was a bushing or grommet. Kinda like the linkage stuff on upper shift rod
The setup I put in my truck came out of a '67, and it did not have a bushing or grommet. Maybe they added that later.
Yes, the little white bushing is what crumbled when we took it out. Thanks.
Joey, here are some pictures of the GM NOS upper clutch rod to pedal lever bushings that you had asked about in our below linked parts board f/s thread where the other GM NOS upper/lower shift rod grommets were listed/offered. I am thinking (Like Patrick mentioned above) that this upper clutch rod bushing may have been added to your 68 at some point as we have only known and found them to be OE on the 71-72 C/K upper clutch rod to pedal lever setups, the earlier trucks were metal on metal/no bushing. Mel
https://67-72chevytrucks.com/vboard/...93#post9374993
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 03-15-2025, 04:56 PM   #136
Dude68
Re: 1968 redo
Thank You sir!!
Joey
Old 03-15-2025, 05:03 PM   #137
Dude68
Re: 1968 redo
Ran into another aftermarket part problem. I purchased an aluminum heater core and it did not come with any brackets. It’s a bit too thick, but it fits, except for the mounting brackets. Did a little modifying to the stock brackets and worked it out, the guys at Barrett-Jackson would puke if they saw this. lol.
Joey
Old 03-15-2025, 05:19 PM   #138
Dude68
Re: 1968 redo
I painted my needles today. Used some Testors spray paint I found at Hobby Lobby. They did not have flo. orange, I went with the only orange they had. I have my LED dash lights. I got a 30 pack of green 194s for $4 off Amazon suggested by a board member “awry experiment” after I ordered a 10 pack of wierd looking cool white ones from superbright LEDs suggested in a post I found on here by another board member for $28. I need to put some power to the panel to light it up to see how each of them look, then I’ll decide which ones I want to run.
Joey
Old 03-17-2025, 08:57 PM   #139
Dude68
Re: 1968 redo
Removed, painted and reinstalled emergency brake and brackets, installed green LED bulbs in dash panel. Not sure if they are dimmable. Painted wiper control arms that go under cowl. Still working on that hickey beside the radio. Lots of wet sanding here.
Joey
Old 03-19-2025, 05:08 AM   #140
Dude68
Re: 1968 redo
Wiring harness is in progress….
Joey
Old 03-19-2025, 05:10 AM   #141
Dude68
Re: 1968 redo
Radiator support is going in as well…
Joey
Old 03-19-2025, 07:31 PM   #142
Dude68
Re: 1968 redo
Got that big ole scratch taken care of!!!
Joey
Old 03-19-2025, 07:34 PM   #143
Dude68
Re: 1968 redo
Starting to look like a truck up front
Joey
Old 03-20-2025, 09:59 AM   #144
raggedjim
raggedjim's Avatar
Re: 1968 redo
Everything's looking good, nice repair on the scratch, I hate doing things like that!
raggedjim is online now   Reply With Quote
Old Today, 12:58 AM   #145
Dude68
Re: 1968 redo
The speaker stuff arrived yesterday. The truck was ordered without a radio. I have the radio delete plate. My grandpa put this Motorola am radio in, and the speaker was screwed through the speaker grill. Got some speaker mounting stuff from Mel at Classic Bowties and mounted correctly. My grandpa listened to this thing on the way to work every day. For some reason, my Dads phone does not capture good color on this truck
Joey
