Old 10-23-2024, 01:38 PM   #1
straight6chevyguy
straight6chevyguy's Avatar
Rear portion of hood not closing?
Hello everyone been working on my new to me 78 c20
The truck was my uncles up until his passing.
I've mainly been working some of the bugs out but one thing that's really bothering me that I need to get fixed is the hood. The rear portion doesn't want to close all the way.
And if you try to push it down it just pops back up. Not sure if this is a common problem or not or if my hinges are bad or what they don't seem to be bent or anything.
Curious what you guys think.
I should add that it wouldn't be too surprising if my uncle put different hinges on from another truck that may not even be correct. They look correct though.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 10-23-2024, 03:24 PM   #2
RustyPile
RustyPile's Avatar
Re: Rear portion of hood not closing?
Hinge is attached too high at the fender.. Loosen the lower bolt and lower the hinge.
RustyPile is offline   Reply With Quote
Old 10-23-2024, 03:41 PM   #3
straight6chevyguy
Ok thanks I'll give it a shot, that actually did cross my mind.
Gonna post a couple pics of the hinges just because but I'm pretty sure there the correct ones.
The funny thing is that both sides of the hood are the same way not sure why my uncle would have left it like this but he had a way not fixing little things like this until he really felt like it.
I'll try to readjust them this afternoon
Last edited by straight6chevyguy; 10-23-2024 at 03:46 PM. Reason: Forgot to add pictures
Old 10-24-2024, 11:24 AM   #4
straight6chevyguy
Well yesterday I tried to readjust the hinges but was not able to make any improvements I'm thinking they were already set all the way back.
Not sure what's going on.
Gonna take the hood off and try and see if there's anything obvious going on that I can't see with the hood on.
Old 10-24-2024, 04:51 PM   #5
RustyPile
RustyPile's Avatar
I haven't done much work of this type on the square body trucks, so I may be "off base" here. There are two hood styles for these trucks.. The early ones ,'73 - 75 had exposed wipers and a cowl of sorts.. '76 had hidden wipers and a different hood.. Is it possible your
uncle installed the early hinges??
Old 10-24-2024, 05:30 PM   #6
kglowacky
i have a78 hinges look the same. BUT My hood doesn't pop up as much but it does go up a half inch on one side. I think I need new hinges. That is what I think you may need
kglowacky is offline   Reply With Quote
Old 10-24-2024, 07:36 PM   #7
ron350
ron350's Avatar
Straight6 thanks for starting this thread it made me go out and spray oil all over my hinges and springs. Just a little oil really makes a difference.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old 10-24-2024, 10:48 PM   #8
3drburb
If you are doing this alone, you may be better off oiling the hinges, removing the inner fenders, loosening all the bolts on the hood and hinges then close the hood to get it where it fits the best, then tighten it up as much as you can from underneath.
3drburb is offline   Reply With Quote
Old 10-29-2024, 01:15 AM   #9
Pontiac1976
Pontiac1976's Avatar
Use rust buster lube first work it in. Then oil the hinges well on all the rivets both side of the rivets open close the hood about 1/2 way up and down. Once it starts to loosen up go little bit higher till it smooth.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 10-29-2024, 12:08 PM   #10
straight6chevyguy
Thanks guys for all the input I have been busy with another project and haven't had time to look into deeper yet. Will update you all when I get a chance to actually look at it again.
Old 10-29-2024, 10:27 PM   #11
cadillac_al
I have seen hoods stick up 1/2" - 3/4" before but yours looks totally fubar.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-31-2024, 01:08 AM   #12
Richard
Easier with a helper for this, a prop rod may be used as well. An adjustable prop rod would make it easier by yourself. Loosen the hinges from fenders. One person push all the way up on hood at latch point. Other person tightens hinges while hood is being pushed up. If this does not fix the problem, hinges most likely need to be replaced.
Richard
Old 10-31-2024, 01:18 AM   #13
straight6chevyguy
yeah for real, it just bugs the heck outa me I dont' care so much about the the trucks ugly paint I just gotta get this hood fixed lol.
Yes I have tried this already (had a helper) no improvement so yeah more than likely I need new hinges.
Old 10-31-2024, 03:32 AM   #14
franken
Adjust the front hinge fender side down.
Old 03-22-2025, 12:49 PM   #15
straight6chevyguy
Ok, so new henges were the fix!
Just cheap henges of eBay. On the new heng for the drivers side I had to file out the adjustment slot some to get it to adjust back far enough to get the back of hood to close all the way on that side. But after taking the hood off and on a few times and several adjustments I've got it looking halfway decent now...
Old 03-22-2025, 01:25 PM   #16
GSP7
GSP7's Avatar
Oil the hinges....
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
